91 4 cyl water pump - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 04-23-2010, 08:55 AM Thread Starter
91 4 cyl water pump
We have a 1991 Esprit 4 cyl in the shop now needed water pump replacement. Not finding Lotus in our labor guide. Any idea how much time to charge for this job?
FallCreek is offline
post #2 of 3 (permalink) Old 04-23-2010, 06:14 PM
First time working on an Esprit but experienced mechanic, I'd guess 8 hours
Jim
1995 S4s
lotus4s is offline
post #3 of 3 (permalink) Old 04-24-2010, 09:06 AM
Vulcan Grey's Avatar
The pump can be rebuilt (seals and bearing replaced in same housing with a press and an oven). A pump replacement is ~$600 with a core.
Removal and replacement is not too bad from mostly below. Must remove vacuum pump for better access. Hardest part will be putting it back on the block without messing up the sealant. Draining, refilling, and bleeding air from the cooling system is the biggest time chunk.
It definitely takes less time the second time... After you develop the tools and techniques.
Have a look here Picasa Web Albums - lotusse - Lotus water pump
Basically
1)drain coolant
2)remove triangle brace
2.5)remove AUX belts (ALT, AC, WP+vacc)
3) remove vacuum pump, need hex driver to reach one bolt
4)remove Oil pump pulley (requires loosening timing belt, so I would lock it in place to preserve timing on the intake and exhaust cam. Oil pulley timing does not matter.)
5)remove 4 hose connections to water pump
6)unbolt and remove water pump
replace/rebuild waterpump
7)reseal WP with anerobic sealant or a gasket and hylomar
8) attach hoses, pretty difficult actually
9)put oil pump pulley back on
10) tension timing belt (use correct Burroughs gauge, Clavis acoustic gauge, Gates Krikit KR1, or laptop+Tune!it+microphone) each with their own procedure.
11) replace vacuum pump
12)replace AUX belts
13)replace triangle brace
14)refill coolant
15)bleed air from coolant
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
