ChargeCooler effectiveness test - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 06-22-2019, 09:47 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Shocking results, look at this
Cheap vs expensive chargecooler shootout experiment
side by side testing with my super technical experiment of cheap vs expensive chargecoolers My vlogging gear Main camera - http://amzn.to/2tbhL5B Wide angle lens - http://amzn.to/2tNaUx1 Fast lens - http://amzn.to/2sTkYVj Bendy tripod - http://amzn.to/2u8TlqE On camera mic - http://amzn.to/2tbjRCs Off camera mic - http://amzn.to/2tbhW0R Colin ...
www.youtube.com
MRDANGERUS is offline
post #2 of 6 (permalink) Old 06-22-2019, 06:53 PM
greenisGood's Avatar
Love the accent! Who says science isn't fun!!!
greenisGood is offline
post #3 of 6 (permalink) Old 06-23-2019, 12:05 PM
Dreaded Prior Owner
snowrx's Avatar
That's the $99 cooler I integrated into my intake manifold. I didn't worry to much about the perfect cooler design as I was going from no cooler at all, but the large water capacity and bulk of aluminium probably help vs the small cooler he was testing against. The pressure drop should also be less on the Ebay unit with it's 4x10" cross section across the flow.
I'm guessing that his testing with such a low flow rate might not scale to real world engine conditions, but a bigger cooler is going to have an advantage regardless. On my car this core cuts my peak Turbo out temps in half, maxing at maybe 35C MAT
snowrx is offline
post #4 of 6 (permalink) Old 06-24-2019, 06:36 AM
Project Addicted
Jcslocum's Avatar
Can you share a picture of your setup?? Did you change pistons to forged?
Jonboy
1984 Esprit Turbo "Vivian"
Jcslocum is offline
post #5 of 6 (permalink) Old 06-24-2019, 07:13 AM
I was thinking a larger airflow would be a better test. If the cheap intercooler had poor airflow it might look better in a test with unmeasured flow. If it was pulling heat out the coolant should have gotten hotter, I would think
exigegus is offline
post #6 of 6 (permalink) Old 06-24-2019, 09:53 AM
Dreaded Prior Owner
snowrx's Avatar
Build thread is here, current manifold towards the end;
https://www.lotustalk.com/forums/f16...squirt-339834/
Yes, I'm running JE forged pistons.
snowrx is offline
