Check Engine Light On- HELP - LotusTalk - The Lotus Cars Community
 5Likes
  • 5 Post By DaveS4s
post #1 of 7 (permalink) Old 02-27-2019, 01:29 PM Thread Starter
DaveS4s's Avatar
Last night,I was driving home and I got a Low Coolant indicator and the Yellow check engine light. I was about 5 miles from home so I just kept going and kept my eye on the Temp gauge . The engine temps stayed in the normal range . The next morning I checked the Header tank and it was a little low , so I topped it off and started the Esprit, thinking that should do it, But NO. Both lights are still on. Espritmon gives me QD-B and Freescan gives me 26-B. I tried clearing the faults , but they come back , I all so tried disconnecting the battery, no help. I hope the Forum Guys can point me in the right direction .
DaveS4s is offline
post #2 of 7 (permalink) Old 02-27-2019, 05:23 PM
Vulcan Grey's Avatar
The float sensor on the S4s and V8 with the plastic tank is known to stick. Clean the float. Check three wiring too.
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is online now
post #3 of 7 (permalink) Old 02-27-2019, 06:44 PM
Take the header tank off and wash it out with hot water. Make sure the float for the sensor moves freely. When the tank is not full, the scum that floats on top gums up the sensor. Keep the header tank filled to the proper level. If it is low you have leaks and you should find and fix them.
David Teitelbaum
jtrealty is offline
post #4 of 7 (permalink) Old 02-28-2019, 03:04 AM Thread Starter
DaveS4s's Avatar
How do you clean the float? I removed it , but it's enclosed tube with the float inside. It rattles when I shake it.
DaveS4s is offline
post #5 of 7 (permalink) Old 02-28-2019, 06:47 AM
post #6 of 7 (permalink) Old 02-28-2019, 08:39 AM Thread Starter
DaveS4s's Avatar
Thanks Vulcan Gray , I sent a PM to Add Lightness asking how you repair the coolant switch , hope he gets back to me. Just an up date: I put the float assembly in my Ultra Sonic cleaner with soapy water for 4 minutes , dried and blow it out with shop air and reinstalled No Help. I disconnected the wires to the float switch and started the Esprit, no check engine light and no coolant telltale light. Freescan shows No Error Codes---- so I think my float valve switch is Tango Uniform.
DaveS4s is offline
post #7 of 7 (permalink) Old 03-18-2019, 12:22 PM Thread Starter
DaveS4s's Avatar
I just would like to thank Vulcan Gray for posting the link to the repair post by Add Lightness, and a Big Thank You to Add Lightness ( Jake 98 V8 ) for contacting me and walking me through the repair . The S4s is back on the road .
DaveS4s is offline
Similar Threads
Check, Double Check, Re-Check Man of Steel General Discussion (Lotus related) 2 11-06-2013 06:28 PM
Help- Check engine light Code P0453 clarkk Check Engine Codes 2 10-03-2012 04:47 PM
Check Engine Light - Any Help Out There? Zen Dude Check Engine Codes 10 08-29-2011 10:32 AM
Help, Check Engine Light is on lesql General Discussion (Lotus related) 9 12-13-2009 01:48 PM
Check engine light help charliex Other 16 08-14-2008 10:08 AM
