CitroŽn g/box Crown Wheel and Pinion - Page 6 - LotusTalk - The Lotus Cars Community
 65Likes
post #101 of 229 (permalink) Old 01-17-2017, 11:50 AM
Wingless Wonder
carbuff's Avatar
Originally Posted by 2001 Esprit View Post
My LSJ project is nearing completion (4 cylinder supercharged Ecotec 2.0L engine) and expect it will be around 300 hp and 260 ft lbs
Hey Dean, you should post (in a separate thread) the progress of the '86. It's been a while.
IIRC you already cyro'd many of your gearbox components?
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #102 of 229 (permalink) Old 01-18-2017, 07:22 AM
greenisGood's Avatar
[QUOTE=MRDANGERUS;5255474]Update:
The total cost is $1800/set.
In addition to this:
Cryogenic Tempering is $150
My shipping to you (US and territories) $25
Mr Dangerous, I'm new around here but i'm continually stunned by your knowledge of things mechanical! Is your back round engineering?
I probably missed it but is there a minimum # of orders needed for crown wheel and pinion sets? The reason i'm asking is because I would really like to get in on it, but I can't right now for the finances, hopefully soon! How many have committed up to now?
greenisGood is offline
post #103 of 229 (permalink) Old 01-19-2017, 06:47 PM Thread Starter
Integrator
MRDANGERUS's Avatar
Mr Green,
Yes, you guessed right.
Thus far, I have 6 people interested. I'd like to get 20 or more.
Price is higher than the "regular" SM/DS CWP, but the difference is in strength and materials.
New design had one main objective: to make parts indestructible. Cost was a secondary concern.
greenisGood likes this.
MRDANGERUS is offline
post #104 of 229 (permalink) Old 04-03-2017, 08:29 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Group Buy Update:
Design has been finalized and roll-tested.
New, bespoke tooling is required for these parts.
Can not start tooling without a firm commitment.
Thus, I'm starting to accept deposits of $206/set ( $6 is for payPal fees, unless you're sending it via a "family" option)
Please, send the down payment to my PayPal at [email protected] (NOTE: there is no O in dangerUS!)
We need a minimum of 15 orders.
Time for action!
post #105 of 229 (permalink) Old 04-25-2017, 09:12 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Thus far, I have 5 people on the list.
Please sign in.
Renndog: Your email address no worky. Please write again, I'm gettingan error message, see below:
[email protected] ([email protected])
Your message couldn't be delivered because an email server outside Office 365 reported an error that it couldn't relay your message. It's likely that the email server isn't correctly set up to receive and relay messages from your domain. To fix this, forward this non-delivery report (NDR) message to your email admin.
post #106 of 229 (permalink) Old 04-26-2017, 02:52 AM
dsvitesse1's Avatar
Hi, before you go on, I would like to share that I am about to order a new batch of 50 -100 ring and pinion sets for Citroen SM. ( Same as for Lotus Esprit. Much stronger than original.
This info is from manufacturer.
Hi Harry.
We will use FORGED material ,the same we used for lancia delta group A.
We will make Hpg-s grinding , wich improves the pattern.
Parts will be klingelnberg , it means comparing a gleason bevel gear with same size and module the klingelnberg is 30% stronger.
With 50 euro more i can make a coating anti friction.
Cheers,
Harry Martens Limmen.
dsvitesse1 is offline
post #107 of 229 (permalink) Old 04-26-2017, 03:50 AM
Wingless Wonder
carbuff's Avatar
Harry,
Thanks for supporting all the users of the Citroen transmission for many years!
Is the anti-friction coating worthwhile? Wouldn't it wear off in a few thousand miles?
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #108 of 229 (permalink) Old 04-26-2017, 03:52 AM
You can't make this up
Jenna'sEspritTurbo's Avatar
[QUOTE=dsvitesse1;5386418]Hi, before you go on, I would like to share that I am about to order a new batch of 50 -100 ring and pinion sets for Citroen SM. ( Same as for Lotus Esprit. Much stronger than original.
What is the total cost on these USD
Jenna'sEspritTurbo is offline
post #109 of 229 (permalink) Old 04-26-2017, 12:50 PM
Dreaded Prior Owner
snowrx's Avatar
I assume, Harry's being for made the SM, they will still drive on the coasting side of the tooth in the Esprit?
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #110 of 229 (permalink) Old 04-26-2017, 01:33 PM
dsvitesse1's Avatar
Originally Posted by carbuff View Post
Harry,
This coating is superfinish .
It is to avoid the usury of parts .
You have more chance to avoid pitting.
Superfinish is not a coating like a print, it is a procedure that does not wear .
cheers,
www.ds-vitesse.com
post #111 of 229 (permalink) Old 04-26-2017, 01:35 PM
dsvitesse1's Avatar
Originally Posted by snowrx View Post
I assume, Harry's these being for made the SM, they will still drive on the coasting side of the tooth in the Esprit?
Correct. But stronger cwp.
cheers,
www.ds-vitesse.com
post #112 of 229 (permalink) Old 04-26-2017, 09:08 PM
dsvitesse1's Avatar
Hi, price will be around 1,5K euro.
cheers,
www.ds-vitesse.com
post #113 of 229 (permalink) Old 04-27-2017, 09:12 AM
Dreaded Prior Owner
snowrx's Avatar
So about $1,650 USD. (Plus the wild world of shipping rates and variable customs penalties)
What tooth ratio would these be?
snowrx is offline
post #114 of 229 (permalink) Old 04-28-2017, 12:38 AM
dsvitesse1's Avatar
OEM. 8/35. 1:4.375
cheers,
Harry Martens
www.ds-vitesse.com
post #115 of 229 (permalink) Old 05-12-2017, 08:06 AM
MRdangerus- I just sent you a email. Sorry I didn't see your post on here earlier!
fmsports is offline
post #116 of 229 (permalink) Old 05-16-2017, 08:07 AM
Dreaded Prior Owner
snowrx's Avatar
OK, I'll take a chance on this getting off the ground @ $1800 a set. Sent a deposit today.
If I spend a chunk on a spare, the original should outlast me, right?
snowrx is offline
post #117 of 229 (permalink) Old 05-16-2017, 09:32 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #118 of 229 (permalink) Old 06-19-2017, 08:32 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Initiative is still going strong. No change in the direction/intent of the project!
List for the "Indestructible CWP" is still open!
Small price to pay, knowing that even if you replace your CWP with "new used" Citroen DS parts, the fix is only delaying the inevitable failure.
Definition of Insanity: doing the same thing over and over again and expecting different results.
Albert Einstein
LOL
post #119 of 229 (permalink) Old 07-23-2017, 10:26 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #120 of 229 (permalink) Old 07-24-2017, 07:56 AM
Dreaded Prior Owner
snowrx's Avatar
Thanks for persisting, The G car will never be as fast as it looks with transaxle worries behind the driver!
Jenna'sEspritTurbo likes this.
snowrx is offline
