Head Gasket - Page 4 - LotusTalk - The Lotus Cars Community
 50Likes
post #61 of 103 (permalink) Old 05-18-2018, 05:09 AM
greenisGood's Avatar
Curious what you had Swain do for your bearings? Doesn't change clearances appreciably?
greenisGood is offline
post #62 of 103 (permalink) Old 05-18-2018, 07:53 AM
You can't make this up
Jenna'sEspritTurbo's Avatar
Originally Posted by mieczkow View Post
More progress. Got my rod and crank bearings back from Swain Tech so I was able to finish off the bottom end. Tomorrow the head and cam towers go back on!
Purty that is
Jenna'sEspritTurbo is offline
post #63 of 103 (permalink) Old 05-18-2018, 01:07 PM Thread Starter
mieczkow's Avatar
Swain Tech puts on a slick teflon-like coating they identify as "PPM". It adds about .0001 to the surface. I've used it on piston skirts and am very pleased with the results.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #64 of 103 (permalink) Old 05-18-2018, 01:17 PM
Wingless Wonder
carbuff's Avatar
Hey Tom,
I have an old bottle of Slick 50 that you can have. It will save you money, LOL.
Laser Bob and AceVentura like this.
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #65 of 103 (permalink) Old 05-18-2018, 01:55 PM Thread Starter
mieczkow's Avatar
Head is back on with ARP studs. Everything is coming together nicely so far.....
Gallagher, DaveS4s and AceVentura like this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #66 of 103 (permalink) Old 05-21-2018, 06:54 PM Thread Starter
mieczkow's Avatar
More work today. Got most of the front end reassembled. Cams go back on tomorrow ......
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #67 of 103 (permalink) Old 05-22-2018, 01:29 PM Thread Starter
mieczkow's Avatar
Progress continues. Cams reassembled, new seals, float checked, everything cleaned and smothered in assembly lube. Tomorrow the valves get shimmed and the cams bolted down. Definitely seeing light at the end of the tunnel....
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #68 of 103 (permalink) Old 06-02-2018, 01:42 PM Thread Starter
mieczkow's Avatar
Valves shimmed. Ready to install the belt tomorrow and then begin bolting on the remaining stuff. Hopefully I'll have the engine back in sometimes next week.
Gallagher and AceVentura like this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #69 of 103 (permalink) Old 06-03-2018, 09:06 AM
AceVentura's Avatar
Cool Engines for the ages...
Your photos (and Travis') have been a big help to illustrate where all of the ancillary parts fit.
Forgive me, but...the Esprit inline four is one of the strangest looking engines I have ever seen.
But then again, I thought my Spyder's engine was strange.
-Rich in Carlsbad
1990 Lotus Esprit SE
"A little nonsense now and then is relished by the wisest men." Roald Dahl
AceVentura is offline
post #70 of 103 (permalink) Old 06-05-2018, 05:17 PM Thread Starter
mieczkow's Avatar
Definitely starting to look like a Lotus engine again.... Hope to have it back in the car by next week.
Laser Bob, DaveS4s and greenisGood like this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #71 of 103 (permalink) Old 06-15-2018, 03:31 AM Thread Starter
mieczkow's Avatar
Ready to attach the UN-1 today. Engine back in the car next week.....
Gallagher likes this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #72 of 103 (permalink) Old 06-15-2018, 05:00 AM
Laser Bob's Avatar
Tom- I've been following your thread and getting an idea of what's happening to my car. Thanks for all the pictures, they're a big help
DD- '97 Ford E350 diesel van
Toy- '83 Esprit
Laser Bob is offline
post #73 of 103 (permalink) Old 06-15-2018, 02:22 PM Thread Starter
mieczkow's Avatar
Put the tranny and engine back together today and finished a little prep work in the engine bay. Will be giving Chris O'Kelly a call this week to get him over to be my second set of hands to put the car and engine back together. Hope to be driving it home before the week is up.
lotus4s, Turbo R and Gallagher like this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #74 of 103 (permalink) Old 06-19-2018, 08:11 PM Thread Starter
mieczkow's Avatar
Chris dropped by this evening and helped put the lump back in the car. Tomorrow I begin hooking everything back up.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #75 of 103 (permalink) Old 06-25-2018, 04:53 PM Thread Starter
mieczkow's Avatar
More hooking things up - halfshafts are done, coils, plug wires, down pipe and new O2 sensor, slave cylinder, etc. I also installed my remote oil filter set-up today. Since I was replacing the old oil cooler and oil cooler lines with new lines fabricated with stuff from BAT I decided to go with a remote filter. No more horizontal oil filter and consequent leaking all over the engine every filter change. Plus the new set-up uses an HP4 size filter, so a little more filtration and a little more oil in the system. Thank you Sanj for providing all the info on the fittings and hardware .
Tomorrow all the wiring harness goes back to work and the shifter cables get attached and adjusted and exhaust system re-attached. I'm thinking start-up for the engine is likely Thursday.
DaveS4s likes this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #76 of 103 (permalink) Old 06-25-2018, 06:29 PM Thread Starter
mieczkow's Avatar
Here's the new sandwich plate.... And you can see the top of the new filter mount in the lower right in red.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #77 of 103 (permalink) Old 06-27-2018, 04:26 PM Thread Starter
mieczkow's Avatar
Almost there! Need to hook up the shifter cables, put the exhaust back on, put the boot back in and she is ready to start. I pressure tested the cooling system and it passed with flying colors. Hopefully I'll be driving the Lotus home tomorrow 😉
greenisGood likes this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #78 of 103 (permalink) Old 06-29-2018, 01:14 PM Thread Starter
mieczkow's Avatar
Well, it's ready to start. Finished everything off today. Since the battery has sat idle for a couple of months I have it on the smart charger and the plan is to start the engine tomorrow morning. Used the Airlift to fill the coolant system and noticed I had a little oil drip because I failed to snug down the exhaust cam valve cover. I used a hand pump to fill the engine with oil because I wanted to be certain the new oil cooler and lines were filled. It created enough pressure to drive oil through the engine and up to the cam towers. After sitting over night some oil was seeping out of the valve cover seam.
I will shoot a little video of the start up and post it.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #79 of 103 (permalink) Old 06-29-2018, 05:39 PM Thread Starter
mieczkow's Avatar
Here's the pre-start picture with everything completed and ready to go.
2Many Cars likes this.
Tom Mieczkowski
1989 Esprit Turbo
mieczkow is offline
post #80 of 103 (permalink) Old 06-29-2018, 07:12 PM
2Many Cars's Avatar
Looking good!
2Many Cars is offline
