Head Gasket - Page 6 - LotusTalk - The Lotus Cars Community
 49Likes
post #101 of 102 (permalink) Old 09-06-2019, 10:22 AM
Dreaded Prior Owner
snowrx's Avatar
Originally Posted by jtrealty View Post
If you did have a gasket failure it most certainly could be the "nip" not to spec. Do you by any chance have the measurements from the last head job? Not only is there a spec on the necessary minimum and maximum, there is a certain amount allowed between each cylinder and it has to be in an ascending order.
David Teitelbaum
I can't find my notes with the nip measurements, but I do remember spending some time juggling the new JAE provided liners to get the most even taper with my block. I think the service notes show a lower number than Changes recommends for iron liners (.004").
I'll check them again when I pull it apart.
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #102 of 102 (permalink) Old Yesterday, 07:29 PM
Dreaded Prior Owner
snowrx's Avatar
Pulled the head, and the gasket failed in the same spot, top of the cylinder on the intake side of #3 and 4.
When I went to zero my nip gauge, I realized it was not totally flat, so no nip #'s yet.
Disassembly torque on the head nuts seemed low, at about 50ft/lbs to release the nut, but I have no frame of reference on how much they relax with heat cycles and gasket compression, let alone the thread lubrication situation. It went together with at least 90 ft/lbs and ARP lubricant. Hate to think I need to re-torque the nuts after break-in...
CC'd the head (37cc) and piston recess (27cc) @ TDC and with gasket volume I think that gives me a 8.39:1 static compression ratio.
snowrx is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
