HVAC Vac line - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 04-28-2019, 02:26 PM Thread Starter
wilkrod's Avatar
HVAC Vac line
Hi all,
Searched all my documents, but can't find where the line from the HVAC vac joins to the main vac line from the pump. I have installed an electric vac pump for the brakes, and need to finish up by installing a tee to the HVAC system, but can't find where to join it in.
Thanks
Jeff
wilkrod is offline
post #2 of 3 (permalink) Old 04-28-2019, 03:46 PM
Wingless Wonder
carbuff's Avatar
Jeff,
Did you need to know where the vacuum comes from on cars WITH the OEM belt-driven pump?
If so, that is at a "Y" connection above the RH gas tank. (On the thin, hard plastic lines) One plastic line goes down to the engine bay and the OEM pump, one to towards the front for the HVAC controls, and another rearward to the various engine control devices.
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #3 of 3 (permalink) Old 04-30-2019, 09:21 AM Thread Starter
wilkrod's Avatar
Got it!
Atwell,
Thanks much for the memory jog, found it, now I can plumb into the new Vac system.
You would think after 24 years with this car, I would remember where everything is.
Regards
Jeff
wilkrod is offline
Similar Threads
WARM UP REGULATORS/CPR, BOOST+VAC SENSING MULTI-PORT FUEL ENRICHMENT ? MRDANGERUS Lotus Esprit 29 11-24-2018 05:17 PM
Fix your HVAC Blower without cutting the firewall and no heater / HVAC removal DIY Randy J A/C, Heating and Ventilation 9 06-11-2018 09:15 AM
Looking for brake line specs or brake line fabricator luxige Suspension (including wheels, tires, brakes) 11 10-22-2014 07:26 PM
HVAC box drain line routing? Sunnie A/C, Heating and Ventilation 2 02-06-2011 06:20 PM
Vac vs press brake bleeding choi0706 Maintenance and Repairs. 6 05-02-2010 06:56 AM
