I think I need a tranny - Page 2 - LotusTalk - The Lotus Cars Community
 11Likes
post #21 of 22 (permalink) Old 05-14-2019, 06:27 AM Thread Starter
Laser Bob's Avatar
Thanks Harry. I'm looking forward to receiving it. Just curious, do you have any kind of estimate on ETA to Glenn?
DD- '97 Ford E350 diesel van
Toy- '83 Esprit
Laser Bob is offline
post #22 of 22 (permalink) Old 05-14-2019, 07:19 AM
Originally Posted by dsvitesse1 View Post
Benefits of HML reversed CWP for Lotus Esprit.
Lotus Esprit has the Citroen SM gearbox with Lotus bell housing.
The Maserati Merak has the engine in the back, like the Lotus Esprit, with the gearbox behind the engine, but since the engine spins the same direction as the Citroen SM, the Merak uses the same CWP but the crown wheel is flipped to the opposite side (which required a change in the differential and gearbox casting) but the pinion is still driving on the drive (concave) side of the crown wheel teeth, rather than the coast (convex) side of the crown wheel. Otherwise the Merak would have had five reverse gears and one forward..... The Lotus engine is set up like the Merak (engine in front of the transaxle), but the Lotus engine spins the opposite direction from the SM/Merak so Chapman used the SM transaxle out of the box. That means the Lotus engine is driving on the coast side of the ring gear and it means the thrust vector of the pinion adds to the thrust vector of the helical gears (which loads the case bearings). It was a quick and dirty solution, but not a good design for longevity. The HML CWP is a mirror image of the SM/Merak CWP, so the pinion is driving on the drive side of the crown wheel...
cheers,
Harry Martens
IOW the Merak engine runs backwards, like a bunch of the older Honda motors, which is a different and weird engineering solution
dsvitesse1 likes this.
exigegus is offline
Similar Threads
Need help with engine and tranny crush washers. jsottile Powertrain (Engine, Transmission, etc) 1 06-09-2011 06:58 AM
Think you've seen it all?? Think again... Dave Other 17 12-23-2007 08:18 PM
Need help quick! How much tranny fluid should I use jlj3394 General Discussion (Lotus related) 7 11-01-2007 04:43 AM
Tranny cooler / tranny crunch exige s sonnythebull General Discussion (Lotus related) 7 07-25-2007 12:46 PM
Eurospec tranny vs USA? Randy Chase Lotus Elise 1 09-12-2003 11:19 AM
