Intercooling Bosch injected, non-chargecooled engine - Page 4 - LotusTalk - The Lotus Cars Community
 1Likes
post #61 of 123 (permalink) Old 08-15-2015, 02:43 PM
Integrator
MRDANGERUS's Avatar
I'm adding 1 gallon coolant reserve tank, just above the pump, to keep her wet and happy.
MRDANGERUS is offline
post #62 of 123 (permalink) Old 08-15-2015, 04:43 PM
Pump? Wet and happy?
...are we still talking about cars?
2016 Chevy Cruze, manual
1987 Lotus Esprit Turbo HCi
2005 Elise
1981 DeLorean, manual, EFI conversion
delomike1049 is offline
post #63 of 123 (permalink) Old 08-15-2015, 06:26 PM
Integrator
MRDANGERUS's Avatar
post #64 of 123 (permalink) Old 08-18-2015, 07:13 PM
Integrator
MRDANGERUS's Avatar
post #65 of 123 (permalink) Old 08-21-2015, 06:57 AM
Integrator
MRDANGERUS's Avatar
It would be nice to know the effectiveness of the CC.
To monitor that, one may install a dual temperature gauge, measuring intake temperatures before and after chargecooler. Two-in-one gauge is a nice space saver.
VEI Systems offers a variety of gauge combinations tailored to all customer needs
See below and pick:
D1-Series Gauges - VEI Systems
post #66 of 123 (permalink) Old 08-30-2015, 05:57 AM
Integrator
MRDANGERUS's Avatar
Just an idea:
Stock V8 HE, (36" wide x 8.75"x 1.75 deep), sporting 4,960 sq.in of cooling surface,
with
5x Delta AFC1512DG (killer) fans (1.8A/ea in steady state).
I hope they will package. If not, we'll seek other alternatives.
post #67 of 123 (permalink) Old 08-30-2015, 06:45 PM
Lorenstump's Avatar
John, I feel you may be building a hovercraft...lol
Lorenstump is offline
post #68 of 123 (permalink) Old 08-30-2015, 07:36 PM
Integrator
MRDANGERUS's Avatar
post #69 of 123 (permalink) Old 09-28-2015, 07:54 AM
Integrator
MRDANGERUS's Avatar
Cold pipe received a layer of insulation.
Both pipes follow the contour of the chassis.
post #70 of 123 (permalink) Old 09-30-2015, 06:19 PM
Integrator
MRDANGERUS's Avatar
Good buy:
eBay item number:
251295728938
Alcoa Aluminum Seamless tubing 5052-O 1 inch OD X .065 wall thickness X 12 feet. comes in 12 foot tubes, can cut for shipping 6’ (wholesale is $62.00), they sell at 24.00 for 12 feet.
You need two 6' pieces.
post #71 of 123 (permalink) Old 11-05-2015, 07:06 AM
Integrator
MRDANGERUS's Avatar
post #72 of 123 (permalink) Old 11-15-2015, 07:15 AM
Integrator
MRDANGERUS's Avatar
Charge cooler circuit is is a very good candidate for Evans EC53001 water-less coolant use.
Small volume of the system will keep the cost at the reasonable level ($42/gal).
post #73 of 123 (permalink) Old 01-16-2016, 10:41 AM
Integrator
MRDANGERUS's Avatar
Ooooops!
I retract the above assumption.
Thank you Loren for pointing it out!
Evans works better in high temperature environments, like engine cooling.
post #74 of 123 (permalink) Old 01-28-2016, 11:30 AM
Integrator
MRDANGERUS's Avatar
post #75 of 123 (permalink) Old 01-28-2016, 01:16 PM
Lorenstump's Avatar
John, OMG no! That's the absolute hottest place in the engine compartment.
post #76 of 123 (permalink) Old 02-04-2016, 08:04 AM
Integrator
MRDANGERUS's Avatar
Here is an excellent and cheap HE which could be adapted as a CC radiator:
Ford TRANSMISSION oil cooler PN# AT4Z-7A095-B
Fits: 1. Ford Edge 2007 2008 2009 2010 ALL ENGINEs
2. Lincoln MKX 2007 2008 2009 2010 ALL ENGINEs
OEM #: AT4Z7A095B, or Partslink #: FO4050149
All aluminum, available on US eBay or Amazon for $99-147
post #77 of 123 (permalink) Old 02-18-2016, 06:19 PM
Dreaded Prior Owner
snowrx's Avatar
I picked up one of the Ford AT4Z-7A095-B coolers, and it's actual dimensions are:
22.5" X 5.7 X .8" for the main body, actual core area frontal area is 20" X 5". Total width with fittings and mount pegs is 7.5"
It comes with 1/2" ID quick connects, which unscrew to offer what looks to be M18 x 1.5 female threads. Ebay has AN or barb fittings which should screw right in.
Nice and thin, with 12 cross tubes and fairly fine fin pitch. Wish I had room for two of them up front, but my oil cooler, a/c condenser and plumbing don't leave me much to work with in front of the radiator.
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #78 of 123 (permalink) Old 02-19-2016, 07:05 PM
Integrator
MRDANGERUS's Avatar
I'm glad you're happy with this one.
If you have a single, centre mounted oil cooler, you may get rid of it and install two coolers horizontally, just behind fog lights. Open up this space at the front for your HE.
Use 1970-1981 Firebird/ Trans Am fender air extractors as air scoops.
That's what I'm planning to do.
post #79 of 123 (permalink) Old 02-20-2016, 06:48 PM
Dreaded Prior Owner
snowrx's Avatar
I'm thinking about oil cooler relocation, but have considerable mental stiction after just wrestling new oil lines to that location and not wanting to cut them up for new plumbing.
Deleting the inoperative A/C seems more attractive some days, as the lines take up an inordinate amount of space!
snowrx is offline
post #80 of 123 (permalink) Old 03-02-2016, 05:54 PM
Dreaded Prior Owner
snowrx's Avatar
Follow up on the Ford cooler. While from the outside it looks like it has big manifolds at the ends, from the inside you can see the the manufacturer let the fin tubes slide in and block much of the manifold area. This will restrict the flow quite a bit. Perhaps some are better assembled than others, but they're only built to flow 3/8" worth of transmission fluid.
Might need to parallel two of these to get enough flow?
snowrx is offline
