Lower cost Bilstein option! - Page 8 - LotusTalk - The Lotus Cars Community
 15Likes
post #141 of 178 (permalink) Old 12-22-2016, 07:30 PM
Integrator
MRDANGERUS's Avatar
Originally Posted by petemon View Post
Let me throw this out there, please tell me if I'm in the ballpark.
I have Spax shocks and want to replace the stock springs.
I run the car normally with stock wheels, I have Proxes4s (245/50-16) on the rear and R1Rs (225/45-15) on the front. The fronts are stickier to mitigate understeer and I'm pretty happy with the balance.
There's way too much body roll with the current setup and I can't get the front down as low as I want. I do like the ride quality for normal street driving and want to avoid an overly harsh ride.
Next year I plan on tracking the car. I have a set of Ronal 17/18 wheels that I may put R-comps on for track days.
I'm thinking Eibach springs, 2.5" ID, 12"-275lb/in Front and 12"-300lb/in Rear. Does this sound about right?
Pete,
I'm curious... how did it work for you? Any observations to share w/ us?
MRDANGERUS is offline
post #142 of 178 (permalink) Old 02-02-2017, 10:01 AM
Integrator
MRDANGERUS's Avatar
post #143 of 178 (permalink) Old 02-02-2017, 10:24 AM
Vulcan Grey's Avatar
Originally Posted by MRDANGERUS View Post
Gaz-Matic shocks come with upper spring support "hats", which rest on the bottom face of the shaft rubber mount. If you replace OE springs w/2.5"ID coil-overs, if used with "hats", you don't need any isolators.
But (!) you're losing 1.5" of the spring length.
Are those meant for the Esprit? Those spring cone adapters for 2.5" springs look like they don't allow the chassis to take the load of the spring... the problem with that is the bushings at the top of the shock will be responsible for all of the load to the springs... This is not good. For the Esprit you really need a 2.5" spring perch adapter that allows the chassis to take the load from the spring as it was intended.
an adapter like this is what the Esprit requires.
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #144 of 178 (permalink) Old 02-02-2017, 11:11 AM
Integrator
MRDANGERUS's Avatar
Yep,you're right.
These black "hats" were useless. Initially, they looked like purposeful parts.
Kept 3" dia springs at the back, so I didn't need any adapter.
Front 2.5" springs may need a centering adapter to prevent top from "walking".
post #145 of 178 (permalink) Old 02-02-2017, 01:26 PM
Loren's Avatar
Sorry, mine have been working for almost 9 years.
Loren is offline
post #146 of 178 (permalink) Old 02-02-2017, 01:47 PM
your what?
Gaz with 2.5" coil springs? Do you have photos of how the spring fits?
The 89SE-93SE chassis will not fit 2.5" rear springs without some sort of adapter.
Travis
post #147 of 178 (permalink) Old 02-02-2017, 02:09 PM
Loren's Avatar
Polybushed top mount into the stock flange. 2 1/4 springs on adjustables.
AVOs ( had two leak over the past few years) 350 pound in rear, 300 in the front.
Loren is offline
post #148 of 178 (permalink) Old 02-02-2017, 02:24 PM
Loren's Avatar
No "walking" on the front, no bush failings on the back.
Loren is offline
post #149 of 178 (permalink) Old 10-18-2017, 07:42 AM
AceVentura's Avatar
Question Bilstein option
Originally Posted by LantanaTX View Post
`I have been watching Ebay like a vulture and was able to get a pair of the Bilstein's for the rear for $105 shipped! I will buy the coilover conversion kit after the shocks arrive and I measure the length of the tube. I believe I will need a kit with the 5 inch long threaded tubes. coilover conversion kits for Bilstein can be had for $37 plus 16 shipping for each shock. I am finding springs for $20 each. It looks like the rear springs will be 12 inches long and 2.5 inch ID.
I was also able to find out what is on my car now. The springs are marked KW 70-250. I called KW and they said my rear springs are 400 pound linear rate springs! No wonder it is rock hard! KW suggested 200# front and 220# rear. They said upping the rear a little over the front will reduce understeer and make the car handle more nuetral. Thoughts?
It looks like the completed rear setup will cost a total of $252. I should be able to do the fronts for about the same. If I end up with a complete setup for the car for around $500 I will be very pleased. If the valving needs work, there are plenty of race shops that can re-valve a Bilstein for me.
UPDATE:
Just found and bought a great coilover conversion kit made for Bilstein shocks. Cost for a pair was $87.53 shipped, with springs, I am now down to $232.53 for a complete rear set up.
Latest update: Just worked a deal for springs at only $10.00 each! They are from Nascar Driver Dave Blaney's son's race car. They are getting out of the class they are in and selling everything. they have a huge stockpile of spare parts new and used. I bought what I needed for all four shocks for $40 plus $20 shipping. I now have bought everything I need to complete two rear coilover Bilstein shocks for $222.53 and already purchased the springs for the front. The fronts will need another pair of coilover kits for 87.53 plus shocks that I can buy new on Ebay at any time for $150 a pair. If I don't find a better deal for the front shocks, the fronts will end up costing 267.53 which comes to only $490 for all four shocks!!
Hello,
I have a couple of questions on the lower cost Bilstein upgrade:
Will the Bilstein shocks & coil-over kit fit the '90 Esprit SE?
Will I have to replace my springs with a coil-over kit for Bilstein?
Is there a part number for the coil-over kit specific to the Lotus Esprit?
-Rich in Carlsbad
1990 Lotus Esprit SE
"A little nonsense now and then is relished by the wisest men." Roald Dahl
AceVentura is offline
post #150 of 178 (permalink) Old 10-18-2017, 06:20 PM
Integrator
MRDANGERUS's Avatar
Yes
Yes
and Yes, If you want the "original" Bilstein combo, see part numbers here: Esprit Damper Programme 2006
You can buy Eibach springs on Amazon much cheaper.
SE OE spring rates: 166 lb/in front, 157 lb/in rear
AceVentura likes this.
post #151 of 178 (permalink) Old 10-18-2017, 09:58 PM
AceVentura's Avatar
Lightbulb Esprit SE/S4s shock absorbers
Yes
Yes
Thanks for all of the information & the Bilstein shock absorber link Mr. D. I'm not familiar with Eibach springs. But thanks for the tip.
-Rich in Carlsbad
post #152 of 178 (permalink) Old 10-19-2017, 07:25 AM
AceVentura's Avatar
Question Lower cost Bilstein option for Lotus Esprit SE/S4s
This listing for a pair of rear shocks for the Esprit SE doesn't quite fit the "lower cost Bilstein option" thread's intent originally posted by LantanaTX.
Am I missing something? Secret handshake perhaps?
Damper, Bilstein
Replaces A082D4174F. Sold as a Pair ONLY, Bilstein $1150.
-Rich in Carlsbad
post #153 of 178 (permalink) Old 10-19-2017, 07:02 PM
Integrator
MRDANGERUS's Avatar
Did you miss the qualifier "If you want the "original" Bilstein combo"?
Now you know why Lotus Owners started looking for various lower cost options, LOL.
Start reading this thread from the post #1.
Thread is long, and "it is all there" ...
Several Members came up with creative alternatives. Pick whichever you like.
post #154 of 178 (permalink) Old 11-16-2017, 09:15 AM
Integrator
MRDANGERUS's Avatar
Damper, Bilstein
Yes,
Looks like the prices almost doubled in the last 5 years. Dunno-wy...
post #155 of 178 (permalink) Old 11-16-2017, 07:43 PM
sleekgt's Avatar
Yes,
It's not quite that high - it's 1819 BP or USD$2407.
When I was looking in 2011, it was about USD$2100.
Search for 'lotac suspension' and click on that link.
Eddie B
87 Esprit 'SLEEK GT'
sleekgt is offline
post #156 of 178 (permalink) Old 11-17-2017, 06:41 AM
AceVentura's Avatar
Lightbulb Lotac Suspension
This listing for a pair of rear shocks for the Esprit SE doesn't quite fit the "lower cost"
Damper, Bilstein
Replaces A082D4174F. Sold as a Pair ONLY, Bilstein $1148.12
This is the 'adjusted' price for the SE. Reality sets in.
Total products (tax incl.) £2,183.48
Total shipping (tax excl.) £13.22
Tax £366.11
Total (tax incl.) £2,196.70
-Rich in Carlsbad
post #157 of 178 (permalink) Old 11-17-2017, 07:06 AM
for that price... I would get the Nitrons on TLF
Travis
post #158 of 178 (permalink) Old 11-17-2017, 08:34 AM
Wingless Wonder
carbuff's Avatar
Just curious, what is JAE offering these days, and for how much $$$?
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is online now
post #159 of 178 (permalink) Old 11-20-2017, 09:16 PM
Integrator
MRDANGERUS's Avatar
Damper, Bilstein
Tax £366.11
We in US are not a subject to VAT tax, so take 366.11 off!
Have you tried contacting Gaz Matic?
https://www.gazshocks.com/products/dampers#gazmonotube
post #160 of 178 (permalink) Old 11-20-2017, 11:20 PM
The rear Bilsteins (part no. LOTAC05405, covers most of the '85 onwards 4 cylinder models) are £535.35 excl. VAT for a pair at SJ's.
sailorbob is offline
