No stop for first gear all of a sudden? - LotusTalk - The Lotus Cars Community
 9Likes
  • 1 Post By Seraph
  • 1 Post By Seraph
  • 1 Post By Erik L
  • 4 Post By Erik L
  • 1 Post By jtrealty
  • 1 Post By lotus4sfm
post #1 of 15 (permalink) Old 07-16-2019, 06:18 PM Thread Starter
All of a sudden the lever does not stop when you pull to the left to slide into first. It still goes into first fine but you have to sort of "hunt" for it.
Do you all think its at the back on the translator or something in the shift lever mechanism?
It feels like maybe a stop broke or fell off?
I will look into it further this weekend.
Any clues appreciated.
94 Esprit S4 - Silver
[email protected]
Erik L is online now
post #2 of 15 (permalink) Old 07-16-2019, 09:25 PM
My car sneezes
gmendoza's Avatar
time to pull the shift boot and see whats going on. Could be the reverse inhibitor. Can you go into reverse without lifting the collar?
'03.5 Final Edition Esprit ~ 5.7lbs/hp; mildly modded - 430rwhp, 353rwtq
'65 Karmann Ghia, '80 930, '89 928 S4, '92 Corrado, '02 Maserati Coupe, '06 Murcielago
www.fquick.com/gmendoza
https://www.youtube.com/channel/UCPI...bwPaEI4JFbyCrA
gmendoza is offline
post #3 of 15 (permalink) Old 07-17-2019, 06:19 AM
S4s
Seraph's Avatar
There is a plastic piece that bumps up against a stop to prevent going into reverse. It can wear down along with the aluminum stop. I had to add a couple washers to raise my stop. Here is a video of my issue.
LotusBloke likes this.
Jim S.
1995 Esprit S4s
Seraph is offline
post #4 of 15 (permalink) Old 07-17-2019, 06:41 AM Thread Starter
I bet that is exactly my issue.
I think I will order the new plastic piece that raises for reverse lock out - it was pretty tired last time I looked at it.
Also shim the stop up. I wonder if that little plastic finger broke off.
[email protected]
post #5 of 15 (permalink) Old 07-17-2019, 03:16 PM
pete inno's Avatar
I have the same issue. A couple of quick fixes that I have tried worked for a while but eventually have failed. Seraph, I didn't realize that the block itself can be raised, thanks, good call, I'll give it a shot. Erik, let us know if the part is still available. For some reason I thought it was unobtainium.
Pete
94 S4
pete inno is offline
post #6 of 15 (permalink) Old 07-17-2019, 04:32 PM Thread Starter
https://www.sjsportscars.com/parts-a...SJ082F0011.htm
Here it is at SJ
There is another plastic piece they show on the website that looks like it could be suspect. Have to see what kind of shape that is in when I pull the lever this weekend
[email protected]
post #7 of 15 (permalink) Old 07-17-2019, 07:50 PM
pete inno's Avatar
Yikes, $84 shipped for that piece of plastic! I'll see if raising the block works first. Thanks Erik, glad to know I can get it if I need it.
Pete
94 S4
post #8 of 15 (permalink) Old 07-17-2019, 08:20 PM
S4s
Seraph's Avatar
I'm pretty sure that JAE just got a fairly recent supply of the metal stop too IIRC.
Erik L likes this.
Jim S.
1995 Esprit S4s
Seraph is offline
post #9 of 15 (permalink) Old 07-18-2019, 03:27 AM Thread Starter
Gearlever Assembly Overhaul Kit
This would probably be a "good idea" to install while in there. I will have a look at the plastic bits this weekend and see if they look worn. I have a suspicion that they have been replaced and the long term wear on the reverse lockout plastic piece and the metal piece discussed and shown in the video above are my issue.
I wish JAE had a searchable parts section on the website, I am so used to looking for parts like that now. Picking up the phone is so inconvenient...I guess I need to work on being more social. :-)
[email protected]
post #10 of 15 (permalink) Old 08-05-2019, 06:24 PM Thread Starter
The culprit was the plastic bush for the reverse lockout.
I ordered a new bush from JAE and a rubber lower gaiter while I was at it.
I think the bush was ~$40.
Pretty easy job to change out, especially since I have been in there before. Shifts better than it did, I think the old bush was flopping around.
Oh, when I first bought the car reverse could not be selected, it turned out the little "strap" in the center of the shift lever that connects the reverse pull collar down to the plastic bush had broken. I devised a repair with a piece a threaded rod because the "strap" is not available. Anyway, JAE told me that they have developed a replacement strap and it is being tested. Apparently the straps are breaking on a regular basis and the only previous repair was a replacement shifter assembly $$$
carbuff, DaveS4s, Seraph and 1 others like this.
[email protected]
post #11 of 15 (permalink) Old 08-06-2019, 05:53 AM
When you see something like this you should go through the whole thing meaning you should inspect the translator and all of the associated linkage for other loose, missing, or worn parts. At the very least everything should be cleaned up and lubricated.
David Teitelbaum
Erik L likes this.
jtrealty is offline
post #12 of 15 (permalink) Old 08-06-2019, 06:20 AM Thread Starter
Great advice /\
I forgot to look at the other parts in the shifter rebuild kit mentioned above. Still have the interior panel off so I have to look for those specific parts and see how they look and where they are located.
[email protected]
post #13 of 15 (permalink) Old 08-06-2019, 08:17 AM
Not sure if these pictures will help you , have more . Had the same issue on my S4s.
Seraph likes this.
lotus4sfm is offline
post #14 of 15 (permalink) Old 08-06-2019, 09:33 AM Thread Starter
Oh yeah all those plastic doohickies are probably toast. My car shifts well though.
IS that gold colored plate over the shifter hole in the pic factory or did you add that? I thought those were aftermarket but that looks like a factory piece.
[email protected]
post #15 of 15 (permalink) Old 08-06-2019, 01:36 PM
They are from the factory. So far the S4s is 100 % stock
