Removing rear brake proportioning valve - LotusTalk - The Lotus Cars Community
post #1 of 1 (permalink) Old 04-29-2019, 05:17 AM Thread Starter
My new ABS delete - brake master cylinder/servo system has an adjustable proportioning valve. I would like to remove the rear factory valve and replace with an "off the shelf" tee if possible.
Has anybody done this and has any insight?
Wondering what flares Lotus used there.
Wondering if there is enough slack in the lines to bolt in an off the shelf tee with slightly different dimensions.
I am thinking I need to plan on cutting the flares off and re flaring to std 45 degree but that will shorten the lines even more.
Maybe I need to look a just installing new lines from the new tee to where the hard lines join the flex lines on the suspension.
Thx
94 Esprit S4 - Silver
[email protected]
Erik L is offline
Similar Threads
Removing Vacuum Switching Valve (VSV) for BOE intake install Smoky Maintenance and Repairs. 0 06-23-2018 05:09 AM
Stock Brake Proportioning Info/Ratio? codingparadox Suspension (including wheels, tires, brakes) 15 08-12-2014 04:07 AM
FS: Elise Fuel Pump/Sender, Vent Valve, Roll Over Valve Lotus 07 Parts For Sale 3 06-09-2014 01:52 PM
Removing the Valve Cover. (For CAM checking) ANIMAL Powertrain (Engine, Transmission, etc) 5 05-16-2010 08:32 PM
WTB brake caliper and engine valve cover @po_crew Parts For Sale 2 03-25-2009 05:18 AM
