Shifter Assembly - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 04-14-2019, 11:59 AM Thread Starter
Shifter Assembly
Can anyone tell me how to remove the shifter assembly on a 02? What trim pieces have to come off and in what order do they come off?
2002 Lotus Esprit
25 Anniversary #50
tmusc is offline
post #2 of 4 (permalink) Old 04-14-2019, 02:15 PM
Do you have the service notes?
I can take a pic of the page if it would help.
I think its the same as my 94.
1.) trim piece pulls up - velcro maybe?
2.) 4 screws hold cover - this pulls up with shifter leather bag thing - untie string so it slips over shift knob
3.) remove the screws that hold the rubber boot over the shifter.
4) remove pinch bolt - gently open pinch piece just a tad and it slides out.
There might be another step in there I am forgetting.
Note the shift knob does not really come off - friction fit. Avoid removing if possible.
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #3 of 4 (permalink) Old 04-14-2019, 02:23 PM Thread Starter
I have taken apart a 93 before and it's made different from the 2002.
2002 Lotus Esprit
25 Anniversary #50
tmusc is offline
post #4 of 4 (permalink) Old 04-15-2019, 02:43 PM
Add Lightness's Avatar
It's a bit different on the revised interior cars. This is from foggy memory, but should be more-or-less correct:
- Mask anything around your console that you don't want to beat up with tools.
- Remove the two phillips screws holding on the fuel release / touch key / brightness cover on the console
- Remove cover (slotted at one end)
- Remove the electrical guts and wiring from underneath (easy, self explanatory when you see it)
- Lift the cover that holds the leather shifter boot
- Once inside out, you can loosen the tie and remove it if you want
- Remove the screws holding the circular rubber noise isolation boot in place (this step is not strictly necessary, but it's easy, as I recall)
The next section is tight work, but it can be done:
- remove the 10 (?) bolts that are along the perimeter of the metal mounting plate. Some of these are close-quarters because they are near the console, but you can take them out patiently with an open-end wrench.
- After that metal closing plate is gone, you will see 4 nyloc nuts with noise isolators under them. Remove those and lift the shifter assembly out. It is not necessary to remove the two bolts holding the reverse lockout in place.
- After lifting the shifter out, the two remote shift cables will need to be removed before you can take it away to your work bench.
Good luck!
Jake
Add Lightness is offline
Similar Threads
FS: Shifter assembly and assorted shifter related parts Jmoses77 Parts For Sale 7 02-27-2017 12:50 PM
WTT: Saffron Yellow T-Top Assembly for Hardtop Assembly KirkScheidt Trade 2 10-16-2011 02:06 PM
FS: Letsla- Lotus Elise Exige Shifter Linkage Assembly sooley Parts For Sale 2 05-19-2010 10:56 PM
FS: Shifter assembly bear01011 Parts For Sale 3 09-08-2009 09:12 AM
FS: Shifter Assembly bear01011 Parts For Sale 2 05-13-2009 04:39 AM
