Turbo GT3071 upgrade? - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By ragingfool35
  • 1 Post By MRDANGERUS
post #1 of 10 (permalink) Old 03-16-2019, 05:36 AM Thread Starter
uklad99's Avatar
Question please!
So if faced with the cost of rebuilding the original Garrett T3 from my 93SE, should I consider replacing it with a GT3071 which I also have?
The 3071 also needs rebuilding so either way I'm going there.
Changing from a Journal bearing turbo do I require anything else for a Ball bearing install?
I'd prefer not to change the Chargecooler for a larger one at this time. I know this has been done by some other members.
My car was chipped by PO who couldn't remember where it came from but it's not a super high performance one.
Guessing original ECU.
Aftermarket BOV.
I have aftermarket primary injectors from Five "O" Racing, the original secondary ones and I'm using the K&N air filter.
Headers to CAT all original, aftermarket muffler tail pipe.
I've given the above details as I've read the ECU, fuel flow, exhaust flow will all go out of wack and these other areas have to be addressed at the same time??
I'm not looking to push the performance envelope here, I'd be very happy to see a modest performance improvement and maybe with the exception of the secondary injectors I really don't want to change anything else just at the moment.
So can I just change the turbo for now and would it be worth it?
Thank you!
93.5 ES
uklad99 is offline
post #2 of 10 (permalink) Old 03-16-2019, 02:05 PM
Integrator
MRDANGERUS's Avatar
MRDANGERUS is offline
post #3 of 10 (permalink) Old 03-16-2019, 05:58 PM
a ball bearing turbo requires an oil restrictor. This fits my GT3071R
ATP-OIL-021*** -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor******** *** *** *** *** *** *** *** * 1******* $12.00*
uklad99 likes this.
ragingfool35 is offline
post #4 of 10 (permalink) Old 03-16-2019, 07:25 PM Thread Starter
uklad99's Avatar
Yes Mr Dangerous I forgot the "R" so GT3071R
I think AR50. Trim I'm not sure about.
93.5 ES
uklad99 is offline
post #5 of 10 (permalink) Old 03-17-2019, 08:54 AM
Integrator
MRDANGERUS's Avatar
FYI:
https://motoiq.com/nerd-o-scope-hone...turbochargers/
IMO, GT3071R, at PR=~2.0, is too close to the surge line (onset of boost may be delayed). Even 56 trim looks not too bad, but 58 is dicey.
I think you'd be better to send your old turbo to CompTurbo and ask them to rebuild it with water/oil 3x ball bearing CHRA,
their own Inconel 713C 10 Bladed Turbine Wheel,
ask for billet comp wheel and max out your compressor to Super 60, it'll look "stock" and flows 34lb/min,
or
let them attach their own compressor, but not larger than .46 a/r.
Do not machine the exhaust exducer port, this area is too thin and prone to cracking.
CT Turbo has 30% off sale in March
Cheers
John
post #6 of 10 (permalink) Old 03-17-2019, 08:57 PM
Integrator
MRDANGERUS's Avatar
Garrett GTX2860R Gen II Dual Ball Bearing Turbo
Latest development Gen2 turbo -another possibility instead of rebuilding "old technology" turbo:
https://www.turbokits.com/Turbo_Char...ng_Turbo/6356/
post #7 of 10 (permalink) Old 03-20-2019, 06:43 PM Thread Starter
uklad99's Avatar
Thanks Mr Dangerous I'm educating myself as I go down this path sorry to say much of the technical spec you sent is beyond me at this time. Certainly turbo lag is one of my complaints although it's fun when the power comes on, it reminds me of my 2 stroke motorcycles riding in the powerband many years back. I do get that this might not be the best fit. I was sort of hoping to make it work based on the fact I already have it. If I were to upgrade/repair the old T3 new go ball bearing and Turbine wheel could I expect/notice a performance improvement?
Also if I were to go bigger chargcooler and secondary injectors, billet turbine for the 3071 would that be enough to consider it?
93.5 ES
uklad99 is offline
post #8 of 10 (permalink) Old 03-21-2019, 12:08 AM
Remember to look at the fuel pressure regulator and the fuel pump as well, if you go to a larger turbo.
On the Sport300 Lotus used a larger turbo, another ecu, a better pump in the right hand tank and a modified fuel pressure regulator. They kept the chargecooler standard, apart from a 10mm cut off on the inlet side, to adapt the larger turbo.
On a secondary note, the following may be of interest to you, if you upgrade the turbo:
An adjustable fpr may be the way to go for you. Also, at that point you may want a better exhaust manifold, say an alunox one, which flows very well. They are at their 3'rd generation, so they do optimise over time. This flows far better and can follow any upgrade you may do, now or later. Then comes the cat, which should at least be investigated for flow, as they get old and bits fall off and restrict the exhaust, which may have consequences. I used a slightly larger more free flowing cat and it's stil street legal and cleans the exhaust gas and pass inspection.
In connection to this, you may want to look at the mechanical chargecoolerpump, which could be changed for a more reliable electrical one. Lot's of threads with a discussion on that topic.
At that time you do want to install better brakes, if not already Some good Guys over in the UK developed a kit to remove the abs system, as the old one installed seems to develop some problems over the years, for example because of not changeing brake fluid every year or every second year. The later abs system as on the 2 Liter GT3 had a more modern faster better reacting system.
You may of course, have done all of the above already.
Let's hear what you decide on and to what effect.
Cheers,
Redfox
redfox is offline
post #9 of 10 (permalink) Old 03-28-2019, 01:27 PM Thread Starter
uklad99's Avatar
Mr Dangerous trying to understand the AR and trim numbers on Turbos the info you sent on the GTX2086 is it the same specs as the pic I will enclose please?
93.5 ES
uklad99 is offline
post #10 of 10 (permalink) Old 03-28-2019, 06:19 PM
Integrator
MRDANGERUS's Avatar
This turbo is "too big". It will give you a sudden (and late!) onset of boost at the higher rpm range. Good for racing/track. Your street driving will not be pleasant, power delivery will be quite abrupt making the car difficult to drive "in Town" (acting like ON-OFF switch).
As a reference, the ultimate 4-cyl Lotus s4s has 0.48 ar turbine cover and 0.42ar comp and it runs like a scalded cat.
Here is a simple explanation of the A/R ratio:
https://gcg.com.au/component/rsticke...and-a-r-sizing
Trim explained: http://www.dieseladdict.com/turbo-wheel-trim/
and flow requirements specified
http://www.wcengineering.com/article...maps.html#wce1
FYI: Sale here. https://www.turbokits.com/Turbo_Char...charger/11455/
uklad99 likes this.
Similar Threads
Turbo upgrade GTX2863R 275 Turbo Forced Induction 4 10-04-2015 06:43 PM
Injector upgrade for turbo 275 Turbo Forced Induction 5 09-14-2015 01:13 PM
PAINTING CENTER CONSOLE + SHIFTER BOOT UPGRADE + AUXILIARY POWER OUTLET UPGRADE DIY lotuselise06 Interior/Exterior 3 12-02-2012 07:52 PM
Turbo Esprit airbox "upgrade" - Is there such a thing? s2mikey Lotus Esprit 11 10-14-2010 10:15 AM
Exige Stereo Upgrade - PART II - FREE UPGRADE INCLUDED! Imolas54 Audio, Video, GPS, Radar Detectors & Other Accessories 15 12-23-2006 08:43 PM
