Turbocharger recommendations - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By snowrx
post #1 of 12 (permalink) Old 02-05-2019, 04:18 AM Thread Starter
DennisCarmen's Avatar
Hi everybody. After installing free flowing intake and exhaust, Red Race chip from Marcus, electric chargecooler pump, etc., to my '90 SE I think my turbocharger itself is becoming a limiting factor. After some spirited pulls, my boost level gets cut of or drops, so I think my inlet temp. is getting to high from the turbocharger working to hard, eventhough my chargecooler stays cool to the the touch with my electric pump. What would you guys recommend to do to the turbocharger to get longer sustained boost? Or any other recommendations? Thanks!
DennisCarmen is offline
post #2 of 12 (permalink) Old 02-05-2019, 06:13 AM
greenisGood's Avatar
You may want to read some of what John Welch has written on this subject before just throwing money at something. Good stuff, and John has real world experience. Alunox markets, (or they used to ?), a double size chargecooler. Some have made their own over sized chargecooler. It's a deep subject. You can go as far as you want and pretty much spend as much as you want!
WC Engineering : Comparing Turbo Specs
Uprated Charge Cooler for Lotus Esprit Turbo
greenisGood is offline
post #3 of 12 (permalink) Old 02-05-2019, 10:43 AM
Also read through what John Welch has to say under "performance parts, Lotus Esprit SE, Turbocharging system components, Ceramic Ball bearing Turbo"
He talks about the stock configuation only being able to SUSTAIN (as in continuous) 247HP. With Ceramic ball bearing Turbo, can sustain 357HP
WC Engineering : Lotus Esprit : Ceramic Ball Bearing Turbo
post #4 of 12 (permalink) Old 02-05-2019, 02:16 PM
Some options on your side of the pond if you have not seen them:
P.U.K. Esprit Racing
(click on products and then "Turbo")
Here is another option in the states:
Esprit Turbochargers - ATS Racing
If I had the budget I would look really hard at the John Welch option shown in post above. Maybe someday
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #5 of 12 (permalink) Old 02-05-2019, 05:20 PM
Welch recommends the GT3071R, at least when I bought one 5 years ago. The new Gen2 GTX3071R is probably a better choice now that it is available. If you are still using the stock ECU, even chipped, you won't get much benefit other than faster spool though. John walked me through the order via phone while I was online ATPturbo.com. The GTX series has integrated surge protection. Yeah give him a call, its well worth it.
many owners also use the GT3071R.
PS he doesn't sell that old BB refit anymore
ragingfool35 is offline
post #6 of 12 (permalink) Old 02-06-2019, 08:29 AM
GT3071r is the best aftermarket turbo choice for our cars. GTX3071 won’t be of any more (relevant) benefit. The GTX wheel takes longer to spool up and it’s gains are (very), marginal over the GT wheel. Specially because of our limitations on boost amount. So if you are chasing the fastest spool and the most gains GT3071R. Adding a Alunox header and twin scroll turbine with dual Waste Gates will be the very ultimate. Of course at that point adding a bigger watercooler will be the next reasonable step.
Good luck!
JG
myespritgt is offline
post #7 of 12 (permalink) Old 02-06-2019, 11:45 AM
Dreaded Prior Owner
snowrx's Avatar
Twin Scroll option
I wanted a twin scroll, internal wastegate turbo on my '85 EFI setup and all I could find was the Borg Warner EFR 6258 unit. Boost response is fine with an Alunox exhaust manifold and 2.5" exhaust, with 10 psi (all I'm using at present) on hand about 2750 rpm. The compressor map looks to be biased a bit towards higher pressure ratios so probably plenty of headroom for those so inclined and maybe not the most efficient at lower pressures. I really don't know how the A/R on the turbine side compares to a single scroll, the numbers look bad but it spools great with the light weight wheels and ceramic bearings. Never been on a dyno, can't give any numbers, just throwing it out there for folks to look at-
The draw back is that it uses a T4 turbine flange inlet and a 3" V-band turbine outlet and would require an adapter for most manifolds and a different down pipe inlet. Far from a bolt-on unit, but did not matter to me as I was re-working everything to go from cast iron and carbs to stainless and charge cooled EFI anyway, and liked the built in BOV and boost solenoid, and a stainless turbine housing just looks cool.
http://www.turbos.borgwarner.com/fil...R%206258-G.pdf
Erik L likes this.
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #8 of 12 (permalink) Old 02-06-2019, 02:22 PM
pan
How about Garrett G25-550 or G25-660?it should be better than 3071, but the downnpipe and turbo flange have to be modified.
pan is offline
post #9 of 12 (permalink) Old 02-07-2019, 08:39 AM
Are stainless steel ball bearings up to the heat on the exhaust side of the turbo as ceramic ball bearings?
post #10 of 12 (permalink) Old 02-16-2019, 06:47 AM
Integrator
MRDANGERUS's Avatar
You are right! Ceramic ball bearings are much better.
Also, step further, triple ball bearing design takes care of the axial loads. https://www.compturbotechnology.com/turbo-technology
Stay away from ChiComNetics = non-reliable duplicates, sub-standard materials.
See one of my older threads on the subject. Stay away from resalers, deal directly with Manufacturers, like Turbonetics, BW, Garrett or Comp Turbo.
Insist on 2 years warranty.
Here is something to ponder: Comp Turbo is the most innovative turbo maker, always on the leading edge of technology https://www.compturbotechnology.com/technology
https://www.compturbotechnology.com/our-ct-r-line
P.S. It is prudent to discern between the mere hear-say sound bites and actual empirical impressions of the end user!
MRDANGERUS is offline
post #11 of 12 (permalink) Old 03-21-2019, 06:46 AM
Integrator
MRDANGERUS's Avatar
Twin-Scroll Turbo options (new)
I was looking for this post for a while. I'm glad I found it.
This is FYI only: Great article explaining advantages of the twin-scroll turbos
https://dsportmag.com/the-tech/twin-...-great-divide/
https://zilvia.net/f/showthread.php?t=460807&page=8
IN ADDITION: there is a new T-S BW Variable Scroll turbo on the market (although too "big" for our Esprits)
EFR7163-J(VTV)
It may be too big for street, but it suppose to have much better low end performance!
This technology (variable turbine geometry) has been around in the OEM and diesel industry for years, but never had a huge presence in the aftermarket.
What does it do?
When the valve is open, it forces exhaust gases/pulses into one of the scrolls of the turbine housing.
When the valve closes and returns to center (after peak boost is achieved), it allows exhaust gases/pulses to free flow and utilize both scrolls of the turbine housing ? much like any current twin scroll setup.
What does it yield?
By effectively reducing the turbine housing A/R when the valve is closed, you can expect quicker spool and TQ gains at low engine speeds.
There should be no downsides or losses at higher RPM's as it retains same split pulse volute design of current EFR turbine housings.
For 4cyl Esprit EFR6258-G map looks right on the money.
https://www.jegs.com/images/photos/1...50turbomap.jpg
If you want to run higher boost EFR6758-G is right for you
https://www.jegs.com/images/photos/1...88turbomap.jpg
FYI: Sale here. https://www.turbokits.com/Turbo_Char...charger/11455/
post #12 of 12 (permalink) Old 03-28-2019, 07:13 PM
Integrator
MRDANGERUS's Avatar
Comp Turbo has a great technology, but their sales department is very difficult to deal with. In last 5 years they went trough 3 sales reps and...
they still suck!
Similar Threads
Is my turbocharger working 84EspritS3 Lotus Esprit 3 07-20-2010 07:18 AM
Video how to modify a turbocharger's internals 25psi_Elise_Killer Forced Induction 3 05-01-2009 09:27 AM
Screw this turbocharger business. Sell me a rocket. andykeck Other 8 04-12-2006 01:20 PM
Turbocharger kits Iceman- Powertrain (Engine, Transmission, etc) 2 03-04-2006 07:28 AM
Delays for the turbocharger, darnit. Mean TT Powertrain (Engine, Transmission, etc) 65 01-07-2005 05:41 AM
