v8 alternator swap - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 08-17-2019, 06:29 PM Thread Starter
v8 alternator swap
i am adding extra load to my car and i remember that there was a nearly bolt on upgrade off a Caddy - can't remember which one - I believe it was a Bosch unit - can anybody let me know the origins and then i can look up the part and specs - have a larger unit that will put out a whopping amount of power - but have to mod the housing so if there ever a failure it could be a issue
Thanks
tricky_dickey is offline
post #2 of 4 (permalink) Old 08-18-2019, 04:02 AM
Sent you a PM
2002 Lotus Esprit
25 Anniversary #50
tmusc is offline
post #3 of 4 (permalink) Old 08-18-2019, 07:47 AM
Cadillac Catera....the 'econo' Caddy that was really just a pig Chevy with lipstick
EYERACE is offline
post #4 of 4 (permalink) Old 08-18-2019, 09:27 AM
While the Cadillac Catera alternator has more output, the conversion is not so much to increase the output as it is to gain reliability and easy availability (and save a little money). If you are significantly increasing the load on your electrical system you must also consider the wiring, the battery, over-current protection, and other things besides just putting a bigger alternator on. While you won't have to modify the car to use the Catera alternator, I wouldn't call it a bolt-on installation. You need to modify the alternator a bit and to get it into position you need to lift the motor.
David Teitelbaum
jtrealty is offline
