V8 Transmission Assembly Help - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 09-06-2019, 11:34 AM Thread Starter
Red face V8 Transmission Assembly Help
I have a V8 transmission that is dis-assembled. It was driven without fluid (not by me) and a transmission shop took it apart. They claim that there is no obvious signs of damage and I got this pile of parts in trade for a good box that I sold them. Last transmission I fixed was a from a Triumph TR6 circa 1980 so... can anyone provide something to help me put it back together other than the parts list diagram? Also what should I look for in terms of damage? In addition, I have an upgrade kit and LSD that I want to put in it.
Thanks,
Guy
toomanyespritsguy is offline
post #2 of 5 (permalink) Old 09-06-2019, 01:13 PM
esprit888's Avatar
Thanks,
Guy
Guy
I have the manual for that box, its a copy but i can send it down if you want to copy it to PDF?
2001 V8 TT
esprit888 is offline
post #3 of 5 (permalink) Old 09-06-2019, 02:59 PM
So when you are done with it you should sell it to one of your forum buddies :-)
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #4 of 5 (permalink) Old 09-06-2019, 04:39 PM
You have to inspect the gears for scoring, the bearings for bluing, the case for cracks. Replace the carrier bearings. The syncros should be replaced and all of the springs because they may have been overheated. The crown and pinion probably took the worst damage so start with them. If possible inspect the debris, if any, in the case. Separate the ferrous from the non-ferrous. If there is more ferrous than non-ferrous the box may be beyond salvaging. If the dif is all that is bad then you may be OK because you are swapping it out for the LSD. Depending on how long it was driven the spider gears in the dif may be all that is garbage. If you have any missing or damaged parts you may not be able to reassemble it, many of the parts are NLA. Inventory all of the parts as you inspect them. Some parts may be obtainable from Harry or Delorean vendors. While the trans is different in the Delorean there is some commonality in some parts. Of course you must replace all of the gaskets and seals. The box is certainly worth trying to save but if you need a lot of parts like gears, be prepared to spend a lot of $$$$$. First step is to see what's missing and then see what is beyond reuse. Find out if you can get the bad, missing parts and if you can what they will cost. Good Luck, you will need it.
David Teitelbaum
jtrealty is offline
post #5 of 5 (permalink) Old 09-08-2019, 01:44 PM Thread Starter
Thanks for the replies.
Guy
