Very heavy to turn heater controls - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By jtrealty
  • 1 Post By beinmymirror
post #1 of 10 (permalink) Old 06-14-2019, 10:51 AM Thread Starter
DennisCarmen's Avatar
Hi everybody. The heater controls on my '90 Esprit SE, the two large ones (hot/cold & direction), are really, REALLY heavy to turn. Sometimes I almost have to use my 2 hands to make them turn. Is that normal? If not, what can I fix/check? Cables? Valves? Vacuum? Thanks!
DennisCarmen is offline
post #2 of 10 (permalink) Old 06-14-2019, 11:11 AM
2Many Cars's Avatar
They shouldn't be that hard to turn. You most likely have a bend or kink in the cables. Pull out the panel and make sure the cables have clear, relatively straight runs. Also check at the far ends to be sure the runs are clean there too. My bet is the cables behind the control panel are getting bent when the panel gets pushed into place. This needs fixing or eventually you'll break the plastic knobs.
2Many Cars is online now
post #3 of 10 (permalink) Old 06-14-2019, 02:53 PM
greenisGood's Avatar
They do turn harder than any modern car though.
greenisGood is offline
post #4 of 10 (permalink) Old 06-14-2019, 05:05 PM
When you get in there, a shot or 2 of silicone lubricant on the inner cable can also help loosen things up. It should not take more than 2 fingers to turn the knobs.
David Teitelbaum
carbuff likes this.
jtrealty is offline
post #5 of 10 (permalink) Old 06-23-2019, 01:37 PM
My car sneezes
gmendoza's Avatar
If the knob is hard to turn, chances are your heater control valve is sticking. If you try to force it, there's a strong chance you'll kink and break the cable.
'03.5 Final Edition Esprit ~ 5.7lbs/hp; mildly modded - 430rwhp, 353rwtq
'65 Karmann Ghia, '80 930, '89 928 S4, '92 Corrado, '02 Maserati Coupe, '06 Murcielago
www.fquick.com/gmendoza
https://www.youtube.com/channel/UCPI...bwPaEI4JFbyCrA
gmendoza is online now
post #6 of 10 (permalink) Old 06-23-2019, 03:49 PM
beinmymirror's Avatar
Had a similar problem also. Ended up cutting a larger access hole in the bonnet firewall for access to the heater valve. Replaced it with a new valve. After removal of the old valve I was able to loosen it up for use as a backup.
beinmymirror is offline
post #7 of 10 (permalink) Old 06-23-2019, 04:31 PM
Is this something you have a photo of? I dont get any heat and I think I need to access the valve and get it moving again. I have not tried yet but it looks tight up there.
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #8 of 10 (permalink) Old 06-23-2019, 04:45 PM
I'll take a picture tomorrow of the bigger access panel and the valve.
Stay tuned.
carbuff likes this.
post #9 of 10 (permalink) Old 06-23-2019, 06:18 PM
Here are the 3 steps of removing the new aluminum access panel to the heater valve. Obviously the hole is bigger than the stock opening. It's still an adventure getting the valve out given the small opening. The 4th picture is a picture of the old heater valve.
The new valve did differ a bit in configuration but still fit fine.
carbuff likes this.
post #10 of 10 (permalink) Old 06-24-2019, 06:06 AM
My car sneezes
gmendoza's Avatar
Many times you can bring the valve back to life by running CLR through the heater matrix
