WHAT TRANSMISSION COULD REPLACE UN1 ? - Page 5 - LotusTalk - The Lotus Cars Community
 3Likes
post #81 of 106 (permalink) Old 06-02-2015, 12:09 PM
The 016 is a decent gearbox but it does have several drawbacks. Supply is dwindling, 99.99% of the parts in it are not available anymore and aftermarket support is non existent. 5th gear is not supported and tends to flex under abuse which results in a stripped fifth gear (and since you can't buy a new 5th gear..). It's max torque rating in a racing environment is 350-400 ft/lbs. There have been many examples them stripping third gear and first gear at these power levels.
SCottmandu is offline
post #82 of 106 (permalink) Old 06-02-2015, 12:30 PM
Vulcan Grey's Avatar
How about a cheap F1 7 speed sequential Xtrac? They have 2 at ~£1333
An XTRAC 7-Speed Sequential Formula 1 Gearbox, Serial Nos. 1044 RB003 in A Green Packhorse with T
An XTRAC 7-Speed Sequential Formula 1 Gearbox, Serial Nos. 1044 RB009 in A Green Packhorse with T
Plus spares
Maybe I should buy one of these, I really want to do an Elise GT1 some day!
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #83 of 106 (permalink) Old 06-06-2015, 07:42 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Scott,
How about Audi 01E tranny?
Is it longer than 016?
Could you provide with a gear ratios available (chart, perhaps)?
MRDANGERUS is offline
post #84 of 106 (permalink) Old 06-26-2015, 03:53 PM
I have installed a 6 speed quaife in my 2003 Final edition.
Donzi is offline
post #85 of 106 (permalink) Old 06-26-2015, 04:23 PM
which one? i was toying 61G but it was too expensive
ragingfool35 is offline
post #86 of 106 (permalink) Old 06-26-2015, 04:32 PM
I am using a QBE25g with a 6-speed sequential gearbox . I am using a quaife bell housing made for the esprit V8. Stock clutch, master and slave cylinder.
Donzi is offline
post #87 of 106 (permalink) Old 06-27-2015, 07:30 PM
what was the $?
post #88 of 106 (permalink) Old 06-29-2015, 06:52 AM
stugilmour's Avatar
Noticed last week our local Esprit friendly independent is in the process of installing the Cayman six speed in a V8. So far he has made up a bell housing conversion plate that is about 1 1/2" thick, presumably to get the output shafts spaced correctly. I believe he has a CNC file for the plate. I think it will use the Porsche clutch. Sorry I don't understand the details too well, but can let you know how it works out. I understand the project is proceeding, but the pace appears a bit leisurely.
Stu
Stu
Calgary AB
'69 Elan Plus 2
'00 Esprit V8
'87 BMW M6 & '84 BMW R100RT
stugilmour is offline
post #89 of 106 (permalink) Old 06-29-2015, 07:10 AM
MidLifeZ's Avatar
Stu
THAT I WANT TO SEE! Hopefully could be modified to use with non V8 cars as well.
Looking on ebay see used for sale from $1500 to $5000
Kenny; Dallas Tx
1995 Lexus SC300 - SOLD
1990 Nissan 300ZX - SOLD
1990 Nissan 300ZX Twin Turbo - SOLD
1996 Porsche 911 Cab - SOLD
1989 Porsche 928 S4 - SOLD
1994 Lotus Esprit S4
Test pipe, Ramspott & Brandt center exit exhaust, 2002 center exhaust valance, Alunox performance exhaust manifold, Spax coilovers with Eibach front springs, Elise steering wheel
MidLifeZ is offline
post #90 of 106 (permalink) Old 08-23-2015, 07:00 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Stuart,
Any updates on the project?
Porsche 987 987c Cayman S Manual Transmission looks pretty compact to me, but the bell housing is POA.
OAL is 27.5" give or take an 1/8"
Bell housing flange surface to output flange centerline is 6.7"
There is no low hanging differential sump either( flat bottom) so clearance below it is non-issue
Some of the specs for a Cayman S g87.21 from caymanclub.net forum:
1st 3.308
2nd 1.950
3rd 1.407
4th 1.133
5th 0.972
6th 0.822
final 3.875
70 mph w/26" tire gives 2882 rpm in 6th.
158 mph @ 6500 rpm
LSD-s are available for this tranny, too.
post #91 of 106 (permalink) Old 03-29-2016, 11:20 AM
petemon's Avatar
Happened to run across this while randomly searching the interweb. Not looking to swap mine at this point but thought someone might find it interesting as I've never seen anything about a Subaru transmission swap.
Design - Factory Five RacingFactory Five Racing
https://www.factoryfive.com/wp-conte...Conversion.pdf
These guys apparently modify Subaru running gear as a replacement for VW rear-engine apps...
Subarugears
I love how the guy from subarugears.com hacks the center differential case apart with an angle grinder.
Pete
'91 Esprit SE - Purchased 10/2013
'88 MR2 Supercharged
'91 MR2 NA
'86 MR2 - Sold
'74 914 - Sold
petemon is offline
post #92 of 106 (permalink) Old 03-29-2016, 12:19 PM
There's a guy here in CO who owns a Lotus Sport 260, who runs a Subaru transmission specialty shop. I talked with him a bit about modifying a subaru transmission for an Esprit.
Travis
post #93 of 106 (permalink) Old 03-30-2016, 10:02 AM
Dreaded Prior Owner
snowrx's Avatar
The later Subaru 6 speeds seem to survive behind 400+hp STi motors, but I wonder what life is like with all the torque going through only one diff/ring & pinion set. We'll have to keep our eyes on the 818 crowd as they start to throw the easy power at their new toys. A big plus would be the ready availability of these units, and parts!
This reminds me that I forgot to drop my old WRX short block & transaxle into my Esprit engine bay for a test fit while the 910 was out. CRS
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #94 of 106 (permalink) Old 06-25-2016, 02:16 PM
Dreaded Prior Owner
snowrx's Avatar
After measuring my spare Subaru 5-spd, I see the axle to tailpiece dimension is 26"+, which would put the shift linkage exiting about in the middle of my rear valance, and the existing mounts well to the rear of the Lotus chassis loop. Not even close.....
snowrx is offline
post #95 of 106 (permalink) Old 07-30-2017, 11:21 AM Thread Starter
Integrator
MRDANGERUS's Avatar
I think it's prudent to re-start the discussion w/info on gear ratios.
FYI: http://www.mendeolatransaxles.com/about-us.html
File Type: xls Audi VW 012 & 01W transaxle data simplified.xls (41.5 KB, 47 views)
Turbo R likes this.
post #96 of 106 (permalink) Old 08-01-2017, 05:47 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Originally Posted by Beerman View Post
Yes, the 016's are all the same except for ratios. There are certain 016's which have much better ratios than others. The one I have is coded AAZ which is a pretty good ratio set.
Yes, it's a beefy transaxle, particularly with an LSD installed. My 331 SBF has about 400 hp and 400 tq. It should be fine so long as there's no drop clutch burn out starts.
Yes, selector shaft is on the left. I have a shifter mechanism from a GT40 replica which uses cable shift so I'll have to run cables to the left of the 016. Shouldn't be too tough.
I'll be using 930 porsche CVs and modified axles - should be plenty tough enough. The 930 CV's have a good range of useable motion.
I'll keep things posted here as the project moves forward
??? Any updates on your project???
post #97 of 106 (permalink) Old 08-15-2017, 05:52 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #98 of 106 (permalink) Old 08-17-2017, 10:42 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #99 of 106 (permalink) Old 09-13-2017, 04:09 AM
Onlooker
Roboto Esprit's Avatar
Hey I been looking. I might have an audi 5 speed box sorry not the six back home I pulled out of a fwd for my old a6. The thing is pretty darn short. Ill see if its still at the shop. If its there Ill have the guy measure it as well as get rid of my old rover block sitting under his bearing press.
I really was hoping to see more info on the quaife as I was thinking about that route. Im already tired of the cables not
performing like a solid ink set. I keep missing first gear. A shift gate would solve all of my isseues but I hate the fact that I have a super car with a 5 speed and a b rated set of materials. If it blows Ill let you guys know what I can make fit as I cant afford to have the esprit down for long.
Ill call my buddy tonight on what box it is and the lenght. you can pick em up for like 500$
Any takers on either make me an offer. low is fine.
1990 SE.
Mod's: BPV capsule & throttle jack delete with all the vac lines shortened to the source and capped.
Kida special straight through muff.
Knn washable filter.
Roboto Esprit is offline
post #100 of 106 (permalink) Old 04-05-2018, 02:07 AM
here is Donzi's setup
