WHAT TRANSMISSION COULD REPLACE UN1 ? - Page 6 - LotusTalk - The Lotus Cars Community
 3Likes
post #101 of 109 (permalink) Old 04-05-2018, 08:15 AM
Only question here is how much are you willing to spend???
1. Audi - tends to be the least expensive. Sub $5K for a workable 6 speed 01e, for example. Good for up to 450hp/tq with reasonable treatment. Scott at Advanced Automotion can pull this together for you. Advanced Automotion
2. Porsche - more expensive. Sub $8K-10K for a workable 930 box. Good for a chunk more hp/tp than the "breathed on" 01e (perhaps 500-550).
3. Others - quite expensive. ZF seems to be the most commonly available with good parts supply and some repair/support. Most of these options are in the $10K-20K+ range.
It's easy to talk a big game about how this or that transaxle can easily handle big HP....right up until you have to write a $15K check for one.
Who here has paid $15K+ for a transaxle?
Beerman is offline
post #102 of 109 (permalink) Old 04-09-2018, 04:05 PM
The 2 workable solutions for someone to actually offer a kit for Esprits to replace a UN1, rather then each person having to custom fabricate a solution each time are:
Option 1 the cheap, plentiful and robust enough for this application is the Audi FWD 6 speed boxes.
Option 2 is making the Boxter gearbox work in here. Way cheaper then the vintage Porsche options previously used. Plentiful enough and already designed to be mid engined transaxle. Can handle the power, upgrades available, lots of clutches etc...
Whoever offers the first bolt on kit for either of these options would result in a bunch of orders at first and then a continuous stream of ongoing ones as the years went on.
uklad99 likes this.
Foxedupone is offline
post #103 of 109 (permalink) Old 05-17-2018, 08:20 PM
[QUOTE=Beerman;5774705]Only question here is how much are you willing to spend???
Who here has paid $15K+ for a transaxle?[/QUOTE---------------------------
I know this isn't the right place to put this, but I couldn't find how to post a new question. I have a Vixen RV that uses a Renault UN-1 Transaxle, having a 4.11 final drive. Mine blew up and I cannot find another one. Is there another transaxle I can use in my Vixen? It must be rear engine/pusher configuration, not mid-engine. My new "built" BMW engine stripped out the ring and pinion and blew 5th gear right out the back case. Any help would be highly appreciated. [email protected]
RevJerry is offline
post #104 of 109 (permalink) Old 10-21-2018, 06:26 PM Thread Starter
Integrator
MRDANGERUS's Avatar
How about 2005 Porsche 911 Carrera 3.6 RWD 997 Manual 6 Speed Transmission G97.01 ?
Anyone?
MRDANGERUS is online now
post #105 of 109 (permalink) Old 03-07-2019, 04:57 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Possibility: Porsche G50/52 ?
Food for thought only:
How to shorten G50 tranny, details:
Converting long G50 into short g50 - Pelican Parts Forums
http://slc-wiki.squarespace.com/porscheg50
The G50/52 gear box from the later 964 could take 360HP and I can imagine some tuner taking it to 400HP. Each new version of the G50 was improved on from the 1987 which in 88 got a new fork etc.
many of them are being put into midengine kits cars like the FF GTM Mulsanne or the Ultima. For midengine, the gearbox needs to be inverted to run the other way around. It requires moving the drain and vent to the opposite side of the gearbox. Also, if the gearbox has a pump and internal oiling it also requires moving the pickup of the pump to the opposite side as well.
The other modification is a hefty billet side cover, which even on the turbo and other 9" ring gear boxes is nice to have.
Spec for G50/52
964 (965) Turbo 1991-94
5-speed fully-synchronized transaxle
Manufactured by Getrag
Plate-type limited-slip differential available
Rod shift
Single-plate clutch
Gear ratios:
1st gear: 3.154
2nd gear: 1.789
3rd gear: 1.269
4th gear: 0.967
5th gear: 0.756
Ring and pinion: 3.44, 9" ring gear
post #106 of 109 (permalink) Old 03-07-2019, 08:36 AM
The problem with the air cooled transmissions I think is that they are very expensive and getting more rare. I think you can buy a boxster trans for $1500? A rebuild able G50 is probably north of $7K - rebuilt over $10K?
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #107 of 109 (permalink) Old 05-29-2019, 05:11 PM
Originally Posted by ragingfool35 View Post
here is Donzi's setup
That makes me weak in the knees
[email protected]
Erik L is offline
post #108 of 109 (permalink) Old 06-14-2019, 02:59 AM
Check this out. Its pretty long but I wonder. I never looked at a picture of one carefully.
I think the companies that work on these can do almost anything with them to them - tons of options.
https://www.corvetteforum.com/forums...k-package.html
This example is an expensive track version but I think run of the mill units are cheap.
hmmmm I would think that if this was an option the kit car crowd would use them. Maybe they are just too long?
[email protected]
Erik L is offline
post #109 of 109 (permalink) Old 06-14-2019, 06:29 AM
I think think the backset of the axles is totally inappropriate if I am looking at it correctly
exigegus is offline
