Where to buy: aluminum brake handle, door sills and the air-con knobs. - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 03-13-2010, 09:08 PM Thread Starter
pchop's Avatar
Can anyone recommend a good source for aluminum brake handle, door sills and the air-con knobs seen on the 2002/03/04 Esprit? How easy are these parts to retro fit onto an 00 Esprit?
pchop is offline
post #2 of 5 (permalink) Old 03-21-2010, 06:17 AM
Paul S's Avatar
Try www.lotusespritworld.com, they have them shown in the modification section.
Paul S is offline
post #3 of 5 (permalink) Old 03-21-2010, 08:25 AM Thread Starter
pchop's Avatar
Originally Posted by Paul S View Post
Try Lotus Esprit World, they have them shown in the modification section.
I already looked at that, but mod is a aluminum sleeve (not the OEM aluminum brake handle) which I'm not really a fan of.
I did manage to have Lotus of Newport order an OEM one for me.
pchop is offline
post #4 of 5 (permalink) Old 04-09-2010, 07:15 AM
A dealer can order the sill plates, knobs and brake handle... I've bought several sets over the years. The brake handle is an easy one... even a girl did one on her own V8 ;-) Pull and Push (in that order).
The knobs are simple.. for the center two! The outer shafts will need to be filed down for a larger flat spot to fit the allow knobs. One of the shafts that need to be filed down is plastic so be careful.
Also, there are two versions of the alloy knobs... the setscrew was relocated later to provide more bite on the shaft and it centers better than the early version.
Sill plates have an adhesive backing with a peel away strip... I've done several sets of these. I like to put a masking tape guide first to center the sill plate, then make a masking tape hinge on the outer edge of the sill plate so it's held in position and I can flip it over and remove the backing, then flip it back and use a wooden roller to press it down firmly.
Regards, KM
2000 Esprit V8
2008 Elise SC
floobydust is offline
post #5 of 5 (permalink) Old 04-09-2010, 11:55 AM
d9e
Check out lotusgarage.com, they've got a good selection of parts
d9e is offline
