X-180 CAMS, MOP, SLA & related issues - Page 2 - LotusTalk - The Lotus Cars Community
 7Likes
post #21 of 38 (permalink) Old 09-19-2017, 08:40 AM Thread Starter
Integrator
MRDANGERUS's Avatar
MRDANGERUS is offline
post #22 of 38 (permalink) Old 09-19-2017, 04:12 PM
Dreaded Prior Owner
snowrx's Avatar
I'd like to see a sealed, low rpm version of Suzuki's mechanisim for belt driven cam motors. Nut'in fancy, but would give you a different timing at high rpm w/o electronics or hydraulics.
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #23 of 38 (permalink) Old 09-19-2017, 04:31 PM
Dreaded Prior Owner
snowrx's Avatar
Suzuki is driving a chain at 13,000 rpm or so in an oil bath, for us one would have to make a belt pulley as a enclosed can with a seal at the rear that held these parts, likely with larger weights/lighter springs to work at our much lower rpms.
snowrx is offline
post #24 of 38 (permalink) Old 09-19-2017, 08:01 PM Thread Starter
Integrator
MRDANGERUS's Avatar
post #25 of 38 (permalink) Old 01-01-2018, 11:44 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Do you have a PN or model number of the bike?
post #26 of 38 (permalink) Old 01-01-2018, 02:43 PM
Dreaded Prior Owner
snowrx's Avatar
The feature was introduced on the 2017 Suzuki GSX-R1000, a top of range sportbike. Porabably be implemented to other displacements/models as they go through product cycles
snowrx is offline
post #27 of 38 (permalink) Old 06-09-2018, 06:25 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #28 of 38 (permalink) Old 06-09-2018, 08:49 AM
greenisGood's Avatar
Which car Mr D S4s?
greenisGood is online now
post #29 of 38 (permalink) Old 06-09-2018, 08:52 AM
BTW I thought it was "a scalded cat", or "a striped ape"
post #30 of 38 (permalink) Old 06-09-2018, 12:42 PM Thread Starter
Integrator
MRDANGERUS's Avatar
Originally Posted by greenisGood View Post
Which car Mr D S4s?
S4s!
"Ape" sounds more outrageous, just visualize such an event, ROLFMAO!
greenisGood likes this.
post #31 of 38 (permalink) Old 11-24-2018, 03:46 PM Thread Starter
Integrator
MRDANGERUS's Avatar
Which car Mr D S4s?
Now, I have 106/104 MOP on both cars. Early exhaust opening sends more energy (pressure) to the turbine=faster response.
post #32 of 38 (permalink) Old 11-25-2018, 06:56 AM
I'm curious why, when you were in there anyhow, you stuck with a black belt instead of the blue?
post #33 of 38 (permalink) Old 02-02-2019, 08:07 PM Thread Starter
Integrator
MRDANGERUS's Avatar
I have used the PO's old belt for swapping pulleys and repetitive "dry fitting". After finding the sweet spot, I changed to blue belt. I tried to avoid inflicting a damage to the new belt.
DaveS4s and greenisGood like this.
post #34 of 38 (permalink) Old 02-14-2019, 06:18 AM Thread Starter
Integrator
MRDANGERUS's Avatar
"Slight" dot misalignment on the cam pulleys translates to 2x crank discrepancy.
If you're off by 1 tooth = huge consequences to the engine!
1 tooth on cam pulley = 9degrees of cam rotation = 18 degrees of crankshaft rotation.
1/2 T = 4.5 deg @ cam = 9 deg @ crank
1/4 T = 2.25 [email protected] = 4.5 deg @crank
post #35 of 38 (permalink) Old 02-14-2019, 08:27 AM
2Many Cars's Avatar
Forgive my stupidity but doesn't that imply the pully has only 20 teeth? (18 degrees x 20 = 360 degrees). It seems like there are way more than 20 teeth on all the pullies.
Edit: On reflection I guess this would make sense if the crank pully has roughly 80 teeth and the cam pullies 40 teeth. Is that about right?
2Many Cars is offline
post #36 of 38 (permalink) Old 03-13-2019, 06:30 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Esprit 4cyl 910 engine cam pulleys have 40 teeth, 9 degree pitch.
9 deg on the cam corresponds to 18 deg of the crankshaft rotation.
1 T cam pulley = 9degrees of cam rotation = 18 degrees of crankshaft rotation.
post #37 of 38 (permalink) Old 03-13-2019, 09:03 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Perhaps this type of sealed sprocket could be adapted? There are several of them on eBay, but I never had Volvo or Toyota, so I leave the practical assessment to others.
2001 VOLVO S40 VARIABLE TIMING SPROCKET CRANKSHAFT TIMING ADJUSTER GEAR W/ SOLENOID - this sprocket has 42 teeth (Esprit has 40), so the new sprocket needs to be made.
Last picture shows Toyota GT
post #38 of 38 (permalink) Old 03-13-2019, 10:31 AM
Dreaded Prior Owner
snowrx's Avatar
And you would need to extensively modify the cam carrier to allow a separate oil feed through the cam to the pulley via the solenoid. Also would need to check oil pressure needed to operate the VVT pulley, the 910 often runs pretty low oil pressure.
snowrx is offline
