X180 IMPROVEMENTS - Page 25 - LotusTalk - The Lotus Cars Community
 42Likes
post #481 of 495 (permalink) Old 09-16-2018, 07:11 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Changing to the electric high volume/hi pressure pump lowers charge cooler temperature. Avoid Bosch xxx 002 weak pump. On this diagram, Bosch 392022010 is the first acceptable pump, all below = junk.
Chargecooler resistance dotted line determines where your pump would like to work.
Be sure to double insulate at least the bottom and side of the exchanger with layer of Thermo-Tec insulation and Nimbus GII hard shield, sold by Merlin Motorsports or DemonTweeks.
MRDANGERUS is offline
post #482 of 495 (permalink) Old 11-12-2018, 06:25 PM Thread Starter
Integrator
MRDANGERUS's Avatar
All who have a large 3" OD exhaust with 6" dia round Langford resonator, don't have to "improve" anything!
I have inserted an endoscope to inspect the guts of the system and discovered that the resonator (not muffler!), is a 3" trough-and- trough part with perforated inner tube, no baffles. It looks very similar as an inside of the Magnaflow resonator. I don't know if it is a fiberglass or steel wool media.
Nothing to improve here, except weight, perhaps.
All later 90+ MY had an oval muffler, 33 lbs anchor.
FYI: how to overcome a drone
Here are links to the best threads I found:
https://www.hotrodders.com/forum/i-d...ne-154608.html
and
https://www.rodauthority.com/tech-st...on-strategies/
https://www.performancetrucks.net/fo...-drone-489463/
post #483 of 495 (permalink) Old 11-14-2018, 08:13 PM Thread Starter
Integrator
MRDANGERUS's Avatar
Rear Hub Bearings, Esprit w/inboard brakes
Reference: post #139 of this thread.
FAG545495AD Wheel Bearings are made in Slovakia.
It x-ref to SKF 99905303500 (blue seal) made in Germany = better metallurgy and reliability
redfox likes this.
post #484 of 495 (permalink) Old 11-16-2018, 08:47 AM Thread Starter
post #485 of 495 (permalink) Old 11-22-2018, 05:12 AM
Originally Posted by MRDANGERUS View Post
I found out that no matter what the outside of the blanket is made of, the inner side burns out fast if it has only stainless mesh and bare fiberglass.
I found a much better Lava Titanium blanket (olive green inside and outside), which has a silica fiber on the inside.
So far-so good, it keeps the compartment temperatures reasonably moderate.
Search on eBay for: 1320 T3 Titanium Turbo Blanket Heat Shield Barrier Turbocharger Cover Lava
So I guess this $19 version is the one that burned out really quickly?
https://www.ebay.com/itm/Universal-T...item2ab5253292
94 Esprit S4 - Silver
[email protected]
Erik L is offline
post #486 of 495 (permalink) Old 11-25-2018, 09:48 AM Thread Starter
Integrator
MRDANGERUS's Avatar
post #487 of 495 (permalink) Old 12-12-2018, 08:25 PM Thread Starter
Integrator
MRDANGERUS's Avatar
Why The Comp Turbo R-Line compressor wheels outperforms
Just FYI:
They certainly have a great products!
I heard, that the customer service is slow, but their innovative technology is worth the wait.
12/11/2018 Comp Turbo Technology is proud to announce the availability of the new CT-R line of compressor wheels. The new R line has proven increases in hp output by up to 15% . The R line compressor is 7-14 vaned and features a thin slim hub to maximize airflow and extended tip technology for increased efficiency at higher pressure ratios. The R line compressor technology was designed with larger exducer diameters which will increase hp output at higher engine speeds. The complete R line compressor technology is now available on our complete line of CT turbochargers. Please visit us at compturbo.com and or contact us at [email protected] for further information regarding the new R line.
https://www.compturbotechnology.com/turbocharger-line
post #488 of 495 (permalink) Old 01-15-2019, 09:51 PM Thread Starter
Integrator
MRDANGERUS's Avatar
post #489 of 495 (permalink) Old 03-21-2019, 06:15 AM Thread Starter
Integrator
MRDANGERUS's Avatar
Why you want Twin-scroll Turbo?
FYI:
Great article explaining advantages of the twin-scroll turbos:
https://dsportmag.com/the-tech/twin-...-great-divide/
https://zilvia.net/f/showthread.php?t=460807&page=8
If I remember it well, Snowrx is the first Esprit Owner who has installed Borg Warner twin scroll turbo on his "Red Rocket"?
post #490 of 495 (permalink) Old 03-21-2019, 10:43 AM
Dreaded Prior Owner
snowrx's Avatar
Having that color blindness thing again? British Racing Green
Also I would not call it a "rocket", (or race it against my Subaru). I went with the EFR turbo as it looked to be the best option for responsiveness, and I wanted to convert to an internal wastegate to add lightness and simplicity. I'm not willing to bet my transaxle against rocket-like levels of boost.
Gimme a Audi or Boxster transaxle and the laptop could probably throw on another 75 hp....
mieczkow likes this.
1985 BRG Turbo Esprit
Chargecooled w/Megasquirt EFI
snowrx is offline
post #491 of 495 (permalink) Old 03-21-2019, 12:35 PM Thread Starter
Integrator
MRDANGERUS's Avatar
OOOPS! I stand corrected, the Green Bollide, that is!
Have you made any improvements to your tranny? At least Quaife and/or my reverse cut CWP, (LOL), distributed by Harry?
post #492 of 495 (permalink) Old 03-21-2019, 02:50 PM
Dreaded Prior Owner
snowrx's Avatar
[QUOTE=Have you made any improvements to your tranny? At least Quaife and/or my reverse cut CWP, (LOL), distributed by Harry?[/QUOTE]
I put in the Quaiffe with new carrier bearings, added a magnet to the drain plug, replaced the circlip, added the big crank pilot bearing, rebushed the linkage, and gave you a Paypal deposit on your CWP project!
Bollide is a bit too close to the truth, as the last head gasket failure gave a hot fart that ignited some roadside grass! My wife therefore prefers Dragon.
snowrx is offline
post #493 of 495 (permalink) Old 03-21-2019, 05:20 PM
In board brakes are so damn cool!
[email protected]
Erik L is offline
post #494 of 495 (permalink) Old 06-17-2019, 08:24 PM Thread Starter
Integrator
MRDANGERUS's Avatar
When you replace the clutch Slave CYL, mount it "UPSIDE DOWN", with the bleeder at the top. It makes bleeding much easier.
Wilwood Master Cyl are internally anodized, which makes them last longer.
See#25 here https://www.lotustalk.com/forums/f16...37/index2.html
post #495 of 495 (permalink) Old 07-20-2019, 06:08 PM Thread Starter
Integrator
MRDANGERUS's Avatar
When replacing any component of the clutch actuation circuit, the system has to be bled.
Very effective and time saving method is to install a Speed Bleeder (post #23), http://www.speedbleeder.com/, and bleed the slave cylinder "back side up". It is a "one man operation".
If 0.70" dia MC is replaced with 5/8" dia cylinder, then the push rod has to be made longer at the pedal clevis.
BEWARE: DO NOT use 5/8" dia MC without checking specs carefully.
Some 5/8"-ers do not have enough stroke to fully disengage the clutch (working w/standard OE 7/8" SC). They have only 1.25" stroke and 0.39" volume.
0.70" dia Wilwood PN# 260-6579 has a proper 1.4" stroke and 0.53" volume!
Drove the car this week end and can confirm that this MC works fabulously.
carbuff likes this.
