2017 Evora 400 simple stereo upgrade DIY - Page 2 - LotusTalk - The Lotus Cars Community
 3Likes
post #21 of 34 (permalink) Old 01-05-2019, 08:04 AM Thread Starter
Docflaco's Avatar
Mobius posted this in a separate thread.
http://vsic.lotuscars.com/system/fil..._Evora_400.pdf
Docflaco is offline
post #22 of 34 (permalink) Old 02-01-2019, 11:57 AM
Slide00's Avatar
On the 400 does it use RCA out to the sub amp in the back or line out?
Slide00 is offline
post #23 of 34 (permalink) Old 02-01-2019, 03:21 PM
Yes it does RCA's (red/white)
Zoomby_U is online now
post #24 of 34 (permalink) Old 02-24-2019, 06:04 PM Thread Starter
Docflaco's Avatar
So I dropped off my E400 and the dealer replaced the subwoofer under warranty, but it still didn’t work so they replaced the amp and it now works. I am looking forward to hearing it for the first time when I pick it up.
If you take your E400 in because the subwoofer doesn’t work, ask them to check/replace the amp first.
Docflaco is offline
post #25 of 34 (permalink) Old 03-03-2019, 08:40 AM
Redsled's Avatar
I find the sound quality to be adequate but am changing head unit so I can have Apple car Play mostly for Waze. Just received this new Alpine head unit https://www.crutchfield.com/p_500INE...avf=N&skipvs=T. Is it a pretty straight forward change I could myself? Sounds like just pop off a couple trim pieces and then 4 screws? Also because it is an Alpine I could just plug in the existing connectors for everything? And once I remove the stock Alpine INE-W960HDMI would there be any value to that? Like would it be an upgrade to an older Lotus? Would be willing to give someone here a good deal.
Current:
2018 Lotus Manual Evora 400
2015 Huracan VF800 Supercharged
2018 Audi SQ5
Past:
2012 R8 Manual V10 VF750 Supercharged
2009 R8 Manual V8 VF550 Supercharged
Redsled is offline
post #26 of 34 (permalink) Old 03-11-2019, 05:14 AM
Following both Docflaco and Mobius97's excellent instructions, as well as the Lotus service notes, I upgraded using the same components listed in the first post here. I was a little familiar with the clips design having removed the interior years ago on my 2009 Elise, but it's still a bit of a shock when they do release. As posted you do not have to remove the
door panels completely but just rotate them and rest them on the floor and against the door.
Two things: the driver's door panel clips were covered in a small tab of fabric or tape, but the passenger side tabs were not. Assuming this was done for better fit, ease of installation. More importantly, I didn't see the 15 piece tool set, so I bought the 18 piece and glad I did, as it includes a plastic rivet removal tool (see photos) which made this part of the job much easier.
You will need a soldering iron, too.
I see that a larger front speaker (deeper) could certainly fit, but these two changes (speaker and amp) make a substantial difference. If I can do it, you can.
Lckitty likes this.
Dylan is offline
post #27 of 34 (permalink) Old 07-13-2019, 12:55 PM
I just purchased a 2017 Evora 400, the manual for the stereo did not come with it... can anyone point me in the right direction? Thanks
Burning888* is offline
post #28 of 34 (permalink) Old 07-13-2019, 01:34 PM
Redsled's Avatar
2017 probably had the Alpine INE-W960, here is the manual for it
http://support.alpine-usa.com/produc...960HDMI_EN.pdf
Or if you have Apple carplay it may be the upgraded Alpine INE-W977HD. My 2018 came with the W960 but changed to W977HD
Current:
2018 Audi SQ5
Past:
Redsled is offline
post #29 of 34 (permalink) Old 07-13-2019, 01:39 PM
Loves to talk
lotusquacious's Avatar
Is the link broken? Seeing this again piqued my interest.
Lew
'17 Evora 400 MT
lotusquacious is offline
post #30 of 34 (permalink) Old 07-13-2019, 02:15 PM
Illegal Alien
Julian73's Avatar
Link is a pay to access site, not much for a 1 hr download session (13 pounds).
Welcome | VSI
'17 Evora Sport 410 GP (No. 1 of 9) Lotus MS alloy pan, SSC harness bar
Julian73 is offline
post #31 of 34 (permalink) Old 07-13-2019, 03:25 PM
Loves to talk
Thanks Julian.
Lew
'17 Evora 400 MT
post #32 of 34 (permalink) Old 08-10-2019, 03:34 PM
I forgot to mention, my subwoofer still isn’t working and I have checked the fuse box as well as the amplifier (green light). While the head unit was out I checked the red-white-yellow AV connections, but they were fine. The one thing I did find behind the radio was a strange green-black wire with a connector that did not have a mate. Does anybody know what this goes to?Attachment 1221496
Where did you find this male wiring harness that goes to the car's factory radio wiring connector? I'm trying to wire up an aftermarket unit and don't want to have to cut up and splice the factory wires and connectors. I can only find the female harness for sale.
zthang is offline
post #33 of 34 (permalink) Old 08-11-2019, 11:04 AM Thread Starter
Docflaco's Avatar
It was in with the mini-amplifier I used for the front speakers. Alpine plug & play.
Docflaco is offline
post #34 of 34 (permalink) Old 08-11-2019, 12:16 PM
Illegal Alien
Julian73's Avatar
I placed my Alpine booster amp here and cut back the wiring harness and I didn't need two 6 ft leads.
Julian73 is offline
