Adding Valved Exhaust - Page 2 - LotusTalk - The Lotus Cars Community
 11Likes
post #21 of 28 (permalink) Old 05-01-2017, 09:58 AM
Originally Posted by Kukadog View Post
Can the oem valved exhaust from the S be used on a NA Evora? It seems like some cars (Elise) have different exhaust for SC vs NA cars but others are interchangable.
If the S exhaust can be used, how could I switch the valve?
Yes, in a NA Evora you can use every Evora S and even every V6 Exige S exhaust and vice versa. Minor adjustaments might be needed as follows:
- the Exhaust Hanger (silencer mounting). From MY12 they changed the diameter of the silencer mountings (from p.n. B132S0088F to B132S0088F) . You can buy new rubber mountings or add or remove the metal cylindrical spacers as needed, very simple.
- the main catalitic converter (or downpipe to sliencer assembly). Here is the problem, keep your original one and you'll be sure it will work with every silencer. If you plan to change it (e.g. if you want to remove you catalitic converter for a simple pipe) keep in mind that there are at least 3 different versions:
1 The early NA's pre MY12 (tilted flange)
2 the S and IPS every MY (horizontal flange)
3 the Exige V6 (horizontal flange but different S shape)
Horizontal and tilted versions are hardly interchangable, you should cut and weld back the flange with the correct tilt, very difficult. The third is interchangable with a small cut and weld, as I did.
- You have to find a way to make the valve work. You can use an electronic wireless control kit (look on ebay) or connect the valve to the vaacum lines as I did.
ienrj is offline
post #22 of 28 (permalink) Old 07-04-2017, 04:31 AM
PLAY-DOH's Avatar
Originally Posted by ienrj View Post
I did it 6 months ago. Do that and resonation with the car's diffuser and flat bottom will occur. You will experience loud noise inside the car and uncomfortable vibrations too. Furthermore the car was too loud or too quite (i had the standard exhaust). I suggest you to go for a model S, Larini or plack exhaust.
After this failure I upgraded my NA Evora with a model S valved exhaust. The valve was initially operated by a wireless remote control kit bought on ebay. But, as i didn't like to have chinese electronic crap on my car, I recently managed to control it from the sport button. I had to remove the small airbox solenoid air filter, invert a couple of vaacum tubes, add a "Tee-pipe" and... A scooter carburetor idle jet!!! It's fully mechanic and works perfectly.
When SPORT mode is OFF, airbox flap and exhaust valve are closed up to 2.500 RPM, making the car quiter.
When SPORT mode is ON, airbox flap and exhaust valve are always open.
Well I just finished the electric cutout project and I'll have to say that I'm not disappointed at all. It's exactly what I imagined it would be. Loud as crap with the remote opened and super quiet with the valve turned off.
I never intended on driving long distances with it open, only letting crowds at shows and gatherings hear how cool the V6 really sounds. Mission accomplished. Now I probably should buy another one for spare parts just in case
It took a total of 12 hours from start to finish for me to fab it all up and wire it in. Believe it or not the wiring was pretty difficult because I had trouble fishing it from the back of the car to the interior. I didn't realize how sealed up the Evora is! Also I had no idea how to take the rear interior loose to get to the wire I fed in back there. I had to break out the manual and it said to just "pull forward" on that rear glass surround"!! Arrg
Now I did hack my Cat up for the flanges and elbows because none of my local shops could mandrel bend that close. I ended up welding a couple custom pieces because of the close quarters back there. I actually lost a little weight dropping the 3rd Cat and installing the cutout which will make brgelise happy....probably not. Yes it's still a boat anchor but I have the best of both worlds now and that makes ME happy. Maybe one day I can get a Larini setup after-all.
So to answer your question kukadog, this is definitely doable and the results are what you would expect. Find someone with a bunch of patience, a good welder and don't forget to disconnect the battery when welding.
I still need a 3rd Cat for a 2011 n/a just in case I ever need to go back stock, so if anyone out there has one they'd like to sell or give away (and I know you do) I will be happy to pay for any shipping expenses
phaphaphooey likes this.
2011 Lotus Evora N/A Quartz Silver
PLAY-DOH is online now
post #23 of 28 (permalink) Old 08-02-2017, 08:12 AM Thread Starter
Kukadog's Avatar
Thank you for the information! This is very helpful but as a (very) amateur DIY mechanic, I could use a little more help/education:
1) Connecting valve control to vaccuum lines- I saw in your earlier post that you used a T valve to connect to the air filter solenoid. Can you share pictures or DIY for dummies instructions? To reference my abilities, I don't know how to find the air filter solenoid. I have the BOE CAI installed if that makes a difference.
1a) Am I correct that using the T valve will open the exhaust with the sport button?
1b) In an earlier post you mentioned inverting the vaccuum line and using a carburator part. Why and how?
1c) Any downside to adding the T valve (e.g. Reduced air filtration, insufficient vaccuum, overtaxed vaccuum system)?
2) I do plan to install a decat pipe. My car is a 2011 NA (tilted flange) and I may buy an OEM valved exhaust from a 2012+ car (horizontal). Does the decat flange need to match my car or the exhaust? I am guessing my car but want to confirm. In other words, if I added a tilted decat for my 2011, would that mate to all exhaust options?
3) If I buy the correct decat pipe, is there still a need to cut and weld?
4) Would the install be easier or better if I ordered and installed the new silencer mountings? If so, it looks like the 2012+ is actually PN A132S0171F.
I love working on my own car but still have a TON to learn. This forum is a wonderful resource! Thanks!
Kukadog is offline
post #24 of 28 (permalink) Old 08-02-2017, 12:18 PM
agentdr8's Avatar
Then it's the solenoid that the BOE instructions mention that you should zip tie somewhere. Not unplug, but just keep connected electronically, but no vacuum lines.
agentdr8 is offline
post #25 of 28 (permalink) Old 08-02-2017, 07:19 PM
smokin orange's Avatar
Originally Posted by agentdr8 View Post
I think only the S cars came with the valved exhausts, and vary between late-model 11s and 12+. Take a look at section EJ in the service notes, pages 15-23. The valve is actuated via VSV/solenoid, and controlled by the ECU, opening after ~4700 rpms. If Sport mode is enabled, the valve is held open.
The solenoid appears to be connected to the ECU pin CB4, per the circuit diagram sheet C5A in section MR.16a. It doesn't look like this pin would be active on a non-S ECU per sheet C5 in MR.16 (non-S diagrams).
The information you get from this site is increadable
2008 Exige S 240
2010 Toyota FJ TRD
2015 BMW M235 Convertible
2000 Jeep Wrangler Sahara
1978 Toyota FJ40
2008 Beneteau Oceanis 40 Sailboat
1973 Colombia 26 MK11 sailboat
smokin orange is offline
post #26 of 28 (permalink) Old 08-03-2017, 03:35 AM
Hi! So, let's start from the beginning:
1. I'll post some pics (it's a T-pipe, not a valve).
1a. Correct. Sport button on opens the exhaust. Exhaust opens itself above 2500 RPM even if sport mode is off.
1b. The carburettor jet is used to skip a little problem. Basically the airbox flap and the exhaust valve works vice versa: vacuum closes the airbox flap but opens the exhausth valve.
1c. No downsides, it's a fully mechanical mod. Anyways you should use a very small air filter because the jet is a screw with a small hole in it: everything smaller than jet's hole would be sucked and pass straight after the main air filter into the engine. No big deal, but... I used a Dell'Orto PHBG idle jet n.30 (0.30 millimeter hole), but everything with a small hole would do the job.
2. Yes, the right decat for your car will fit every OEM exhaust
3. No cut and weld with the right decat (apart from point 4.)
4. Yes but a grinding tool would do the same job for cheaper.
ienrj is offline
post #27 of 28 (permalink) Old 06-13-2019, 09:16 AM
So I need to order two of these rubber mounts (PN: B132S0088F) to get the Larini exhaust installed on my 2011 NA Evora. My favorite source Hangar111 does not have it. What's the next best place to order?
Octonion is offline
post #28 of 28 (permalink) Old 06-13-2019, 09:39 AM
Happy To Be Here
ShadowWulf369's Avatar
Probably from Gator. See the link below.
https://www.lotusparts.com/p/Lotus_2...132S0088F.html
Octonion likes this.
2013 Evora IPS - Carbon Gray
2016 BMW 328xi - Estoril Blue
ShadowWulf369 is online now
