AIRBAG HELP PLEASE - Page 4 - LotusTalk - The Lotus Cars Community
 50Likes
post #61 of 79 (permalink) Old 05-16-2018, 10:20 AM
Bahrain Lotus's Avatar
Yep, Mine was delivered last week. Used Shakham's idea. 2011 Epic/Tosca Codes could not read the code but could finally reset it... I believed it was caused by low voltage when I went on vacation. Now gone Would have probably cost me more going to the Merc dealer and sure saved me the hassle of dealing with them.... Thank you to everyone that contributed to me buying this scanner.
Had a quick play to see if could read any other codes, but didn't find anything useful to share at this time.
Just fixing my airbag issue at this point was worth the money I paid for the scanner.
Snowphun and \Boost Monkey/ like this.
Evora 2010. Canyon red
Elan M100. Pacific blue
Web page: www.ElanM100.com
Bahrain Lotus is offline
post #62 of 79 (permalink) Old 05-30-2018, 10:12 AM
lotusexige's Avatar
My buddy recently bought a Autel MaxiCheck Pro ($180 new on eBay) and I decided I'd give it a shot today and it worked. Steps
Step 1: plug in
Step 2: Select abs/srs
Step 3: Select Asian
Step 4: Select Daewood
Step 5: Select 2011
Step 6: Select (EP) Epica/Tosca
Step 7: Select Body
Step 8: Select SDM (Sensing and Diagnostic Module)
Step 9: Erase Codes
Step 10: Yes
And your airbag light will disappear! I tried to read codes before erasing them and nothing showed up.
darcivic00si, mgf-martin and Jer like this.
lotusexige is offline
post #63 of 79 (permalink) Old 10-05-2018, 05:40 AM
A big thank you to Bakhterien for the great detective work !!!
For over 2 years, I'm looking for an airbag bugfix tool. (Evora S, 2011)
In Europe, I could not find a Foxwell NT 630 "PLus" Model, so I bought the Foxwell NT 630 Elite.
And it works, the airbag light is switched off !!!
(The same procedure as Autel MaxiCheck Pro)
Step 1: plug in
Step 2: Select ABS & SRS
Step 5: Select (B)2011
Step 7: Select Body
Step 9: Erase Codes
Step 10: Yes
Best wishes from Germany
Martin
mgf-martin is offline
post #64 of 79 (permalink) Old 10-10-2018, 03:20 PM
AndrewS's Avatar
Anyone successfully done this on an Evora 400? Or does this work only on older models?
AndrewS is offline
post #65 of 79 (permalink) Old 10-10-2018, 04:12 PM
If it worked to clear it but it came back on, it's probably an actual problem with a loose connection or such that needs to be fixed.
pharriso and mgf-martin like this.
esseye is online now
post #66 of 79 (permalink) Old 10-16-2018, 05:56 AM
AndrewS's Avatar
Ok I donít understand why this worked but...
Drove car today. Airbag light still on.
Just for kicks when I got home I hooked it up to a canObd2 {Innova) scanner It found no error codes. This model does not do airbags, just a basic obd2 scanner that can reset ecu codes.
I hit erase anyway. Amazingly airbag light went out.
Drove 20 miles, light still out.
My guess is it refreshed the ecu and that somehow shut off the light.
Will see if light stays off long term but so far so good.
AndrewS is offline
post #67 of 79 (permalink) Old 10-16-2018, 06:45 AM
If you have a 400 presumably you're still in warranty, why not take this to a dealer? There is a common problem with a bad connector on the passenger airbag in the S1 models that you want to fix if you have it - the airbags may not function otherwise. There is a secondary problem that if your battery goes dead there is a capacitor standby for the airbag system that discharges and causes a persistent fault, even after it's recharged. That's OK to reset.
In your case you may actually have an issue with your SRS system - you don't want to just go clearing it and find out they don't work when you need them.
post #68 of 79 (permalink) Old 10-16-2018, 02:31 PM
AndrewS's Avatar
Dealer is 3hrs away so will get them to look at next service in spring. Almost end of season here so not worth a special trip.
Am totally convinced it is just the battery getting low caused the issue. Never had problem before and first start after battery went low and then was recharged the light came on. So I doubt coincidentally my airbag connector went bad exactly at same time without moving car from last time it was fine.
If dealer was closer would have had them reset it and check everything already.
AndrewS is offline
post #69 of 79 (permalink) Old 10-17-2018, 06:04 AM
OK - but you said it came back after you cleared it, did the battery completely die twice?
To me the SRS system is very much "worth the trip" to a dealer - I'd contact them and see if they'll pick the thing up for you or something.
post #70 of 79 (permalink) Old 10-21-2018, 06:39 PM
AndrewS's Avatar
Agreed,
Definitely getting evaluated at dealership.
AndrewS is offline
post #71 of 79 (permalink) Old 10-29-2018, 12:59 PM
JerseyGirl's Avatar
Anyone in the central or south Jersey area got a magical scanner I could borrow? I've tried a few Innova scanners with no luck.
JerseyGirl is offline
post #72 of 79 (permalink) Old 11-03-2018, 08:06 AM
2Ravens's Avatar
I think the 400s don’t have the same problem as the previous gen. I’ve had my battery die several times and the airbag light has never come on. My guess is that if you’re seeing the light on your 400 there is a genuine SRS problem. The only time my light came on was after I replaced the stock seats with Recaro Profis. I had to add a resistor to the circuit that connected the side airbags in the factory seats to trick the system into thinking they were still attached. Even then, as soon as I added the resistor the light went off without having to reset anything in the OBD.
2Ravens is offline
post #73 of 79 (permalink) Old 11-03-2018, 06:33 PM
AndrewS's Avatar
Yes I think my battery issue has turned out coincidental. Light has randomly gone on and off over last few weeks Plan getting addressed next time can get to dealer.
AndrewS is offline
post #74 of 79 (permalink) Old 12-03-2018, 02:15 AM
2012Evora's Avatar
bakhteria,
Are you in Northern VA?
I have a 2012 Evora with the same issue! If you would be open to it, I'd drive to you to get rid of this code. And buy you lunch. I'm new to this site and couldn't figure out how to PM. I made an account just to message you.
Originally Posted by bakhteria View Post
SOLVED
So let me help all my fellow Lotus Evora owners.
I was ready to drive all the way to NJ for this but I wasn't giving up. I knew that Lotus would not have enough airbag development money to make something so unique that not even the best scanners could figure out. Well after speaking to a few dozen lotus mechanics who reiterated that in fact you have to use the lotus scanner, I got no where.
But then I bought a scanner off of Amazon Foxwell NT 630. It does not have Lotus anywhere in the menu but after doing some deductive reasoning I narrowed it down to Vauxhall, Toyota, Chevy, and Ford Europe. One after another failed to communicate. Then I figured who is the cheapest Asian car maker that would have a bin-full of airbags for the US market but no cars and I remembered Daewoo. Well on this scanner they have Daewoo. And two choices. the correct choice was Gentra. And sure enough not only did it recognize the car and connected to it, then I get the beautiful message "Do you want to erase?" what beautiful words.
So anyone out there that has this issue, here you go. BTW I bought mine from Amazon Prime because I wanted it quickly so I probably paid too much for it ($150). You can probably be more selective.
2012Evora is offline
post #75 of 79 (permalink) Old 12-06-2018, 03:39 AM
2012Evora's Avatar
Whoever figured this out is AWESOME. I live in VA and there are no dealers within 250 miles. This saved me a TON of drive time, and even after the scanner purchase, it still cost less than what the dealer wanted to clear it.
I'm in Stafford if anyone needs a hand.
post #76 of 79 (permalink) Old 08-15-2019, 12:01 PM
Orange
Oranje's Avatar
Finally my airbag light came on , usually during the holidays on a roadtrip. Got my Foxwell with my and yes! the airbag light went off. At first I had the language on Dutch but then the menu is not working correctly, the language has to be English. Thanks to Bakhteria.
2011 Lotus Evora S Storm Titanium
Oranje is offline
post #77 of 79 (permalink) Old 08-16-2019, 08:28 AM
brgelise's Avatar
Step 1: plug in
Step 5: Select 2011
Step 7: Select Body
Step 9: Erase Codes
Step 10: Yes
BEING THAT THIS MAY BE THE SINGLE MOST COMMON ISSUE ON AN EVORA, MODERATORS, COULD WE PLEASE MOVE THIS FANTASTIC INFORMATION TO THE TECH/HOW TO ZONE!!! This is almost easier than black tape!
lotusexige likes this.
brgelise is offline
post #78 of 79 (permalink) Old 08-17-2019, 02:23 AM
Orange
Oranje's Avatar
Good thought, I would go for the Foxwell NT630 Elite much cheaper.
https://www.ebay.com/itm/Foxwell-NT6...-/153015580642
Oranje is offline
post #79 of 79 (permalink) Old 09-16-2019, 11:09 AM
brgelise's Avatar
Autel Maxicheck Pro
Foxwell NT 630
This is also great info as my OBD2 COM program is ancient, though it still works and the XP laptop is also ancient and only thing it is kept for.
brgelise is offline
