As far as sway bars go, the difference is nominal at 10% stiffness change. I believe Lotus was more focused on the rear weight increase in the back of the S/C'd car.
Bars and Dampers remained difference between NA and S/C through life of Series 1, what became the same post MY12 was suspension arms (actually the bushings) became the same for NA's automatics as used on the S/c man and auto.
NA man & auto:
rear ARB 21 mm (black) A132D0039F
ARB bushings A132C6013F
Out of shear curiosity, why do you believe your suspension needs to be upgraded?
"Make the suspension adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver." - Colin Chapman
I have been in many Lotus on track. Elises can indeed be made much better than stock. But, I have been in more poorly "enhanced" Elige's than well upgraded ones.
Interesting how original poster goes straight to hardware upgrades, but has made no mention of alignment 'enhancements". This is one of the biggest areas one can improve upon (removing the setup designed to protect the common idiot) without changing a single piece of hardware. Hint-->my recommendation, start here. One can improve both road and track abilities at the same time, depending on your driving style. The magic of these cars is compliance, take it all away and its just another oversprung, twitchy sports car.
Not sure what you are looking for but I have tinkered a little with mine. I have a set of tailored Nitrons fitted on my Evora S. It is an improvement over stock in my mind.
Then again Lotus haven't changed the suspension on any of their Evora's since launch have they? S1 NA same as GT430? >
In all fairness, even if one of us were the genius of our generation, it would almost certainly require years of research and trials and refinements to better some area of human endeavor.
As I understand, changes have been made to compensate for some changes in power and weight.
But the bigger changes came about when there was a change in philosophy as the 400 came along. As best I can tell, they wanted to dumb it down a bit aiming for a broader audience.
It's very unlikely to be worth it to increase the rear bar by 0.5mm. The difference is academic. Tire compound/size/temperature/pressure, road surface, and nut behind the wheel will dominate any small change like that. Lotus Sport makes bigger front and rear bars. I believe the part numbers are: ALS5C0089J (Front), ALS5C0090J (Rear). Some of us contend that even these are too small.
The evora suspension is an interesting compromise between comfort, performance, and *budget*. If you're willing to give up one, you can certainly improve the other. Personally, I'm willing to give up a lot for better transitional response. Therefore I'm a fan of big, big bars. Well that and the fact that the SCCA doesn't let me change springs.
My mechanic once joked with me saying, “If Colin Chapman saw how you drove this car he’d be rolling over in his grave. This car is meant to be driven and driven hard just like Chapman would have wanted”. For me at least I wouldn’t think suspension upgrades would be worth it. That’s not to say, however, everyone should think the same way.
I’m my opinion it’s an individual choice and I’m anxious to see how it turned out for the OP and if it made a noticeable difference.
The front track-rods and rear toe-links are finally up on our website: Suspension | HethelSport :grin2: The v.2 of the rear toe-links include a very useful improvement during alignments and we're pretty thrilled to have initiated the revision with the manufacturer. (v.1 kits can updated so if you have one, ping me for details.)
We're looking into some stiffer sway bars and have chatted with a large capacity US based manufacture plus we've been approached to work with a UK fabricator with lots of Lotus experience. A large part of the decision to proceed is the actually need--sway control on the Evora is pretty dang good so we're a bit hesitant--with our upgraded bushings and Bilstein/Öhlins shocks, were not convinced anything less than a pure competition race car needs more. Plus the front bar is a pain to remove-&-replace.
For front-to-rear balance, We'll also be offering a simple stand-alone kit that can dial out some understeer. The kit's primary function is actually something else but it will have three balance settings: •Stock •Looser •Loosiest. For those of you that like looser cars on the track, this is for you! The kit has been on our test car for a year so we're ready to build more. No pricing yet but probably less than the cost of one R-compound Evora tire. --Sherman
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
