Any experience BOE headers and Moroso oil plan - LotusTalk - The Lotus Cars Community
post #1 of 13 (permalink) Old 04-15-2019, 07:41 PM Thread Starter
DLO
Evora '10
DLO's Avatar
Hello,
Had Moroso oil plan on Evora NA and just installed BOE headers and finding there is extremely little clearance between exhaust and side of oil pan (0.33 MM). BOE hadn't heard of any feedback for this combo so checking if anyone else has had experience and if so, how did you resolve?
I don't see way to 'move things' so can leave and monitor (I did ceramic coat from Swain Tech so that will reduce heat transfer). Can have pan notched, pain. Or go back to stock. On stock I found a baffled insert from Wilhelm Raceworks that looks interesting but no feedback/comments from others that I could find (though he does post some interesting oil pressure performance testing results).
I don't know what other oil pan brands are out there, Moroso clearly looks like the most popular. I want to do occasional track days and hence the extra safety goal.
DLO is offline
post #2 of 13 (permalink) Old 04-15-2019, 09:31 PM
Bobsy Racer's Avatar
I found that the engine mounts flex enough that my 2bular Headers hit the belly pan where I had filled in the factory openings.
See Post #46 : https://www.lotustalk.com/forums/f17...64/index3.html
There was clearance when standing still, but it banged when accelerating and decelerating.
I had to dome the filled in patch to clear and allow movement, so I would worry about your header hitting the oil pan.
Bobsy Racer is offline
post #3 of 13 (permalink) Old 04-16-2019, 01:21 AM
Your problem is different from this one. The engine and headers will flex as 1 unit on his car. Yours the undertray is stationary.
I would modify something in the OPs case. The moroso oil pan is aluminum any rubbing that takes place will put a hole in the pan eventually.
As for your gap .3mm is feeler gauge distance. You sure it's not more?
Incase I'm asking for help with something: 2011 Evora N/A C/R 6sp with BOE TVS 1900 S/C kit
John Z is offline
post #4 of 13 (permalink) Old 04-16-2019, 06:41 AM Thread Starter
DLO
Evora '10
DLO's Avatar
Yes I did measure with feeler gauge. Yes this is in relationship to the oil pan... Given the reference you had Bobsy Racer, I will reinstall the undertray as well to see if any other challenges come to light.
I can take the pan off and have it notched. It is next to the corner edge as you can see in the picture. Need to also find someone in north dallas area. I liked the 'simplicity' of the Wilhelm Raceworks solution I just don't know about the reliability.
DLO is offline
post #5 of 13 (permalink) Old 04-16-2019, 06:57 AM
tye-bo's Avatar
I'm in the north Dallas Area, what are you looking for?
Current:
2018 Evora 400 Metallic Black Manual
1998 Volvo V90 silver L59/4L60 swapped
1970 Honda CT70 Red
Sold:
2017 Audi R8 Silver V10/DCT
2010 Evora Carbon Grey Manual
12 others...
tye-bo is offline
post #6 of 13 (permalink) Old 04-16-2019, 08:32 AM
Based on that bit if information.i would definitely have something done.
As for the boe headers and the under tray, you will have to open that up too. The boe under tray would be a nice addition as it will help keep things cool
John Z is offline
post #7 of 13 (permalink) Old 04-16-2019, 08:41 AM
Race & Pamper
Kubera's Avatar
That's virtually no space in between, that header will be hot enough to get the oil pan warm...
Kubera is offline
post #8 of 13 (permalink) Old 04-16-2019, 09:37 AM
invictusmaneo's Avatar
The moroso pan gets very hot on its own, but the headers will definitely increase that. FWIW, my early-run 2bular headers didn't clear the moroso pan at all and required some modification of the radius to get it to clear, and even then it was tight.
Given how close that one is, I would worry that as parts expand (namely the headers) with heat, you might get contact. I am sure Phil will weigh in.
I also had to dome out my undertray on the 2bular headers-these are likely better but I would check clearance.
2016 AMG GT-S
2012 Caterham R400 (sold)
2010 Chrome Orange Evora (Sold )
2005 ST Elise (sold)
2002 MB G500 lifted etc.
2003 Cooper S (track)
we'll see what Lotus comes up with next...
invictusmaneo is offline
post #9 of 13 (permalink) Old 04-16-2019, 09:56 AM Thread Starter
DLO
Evora '10
DLO's Avatar
Given where the conversation heading, looks like I'll need someone good at aluminum metal work and welder (think TIG) to notch the pan. Open to referrals. I'm actually in Richardson.
Still interested in feedback on the Wilhelm Raceworks option, he has baffle kit that goes inside the stock oil pan (though being the stock pan already has more clearance).
Aside, have seen the new BOE vented under tray, that looks like very useful upgrade in Texas heat, its only money!
DLO is offline
post #10 of 13 (permalink) Old 04-16-2019, 10:24 AM
tye-bo's Avatar
Cool, I'll ping my buddy and see if he's interested in helping.
Current:
1970 Honda CT70 Red
Sold:
12 others...
tye-bo is offline
post #11 of 13 (permalink) Old 04-16-2019, 08:30 PM
Julian73's Avatar
Take it to Regogo Racing/Sports Car World on Butler.
'12 Evora S GP (No. 1 of 14) BOE Prototype S 430 **SOLD**
Julian73 is offline
post #12 of 13 (permalink) Old 04-16-2019, 08:34 PM
Julian73's Avatar
I use the old Lotus Motorsport baffled aluminum pan. I see Lotus now uses the Toyo steel pan with modified with internal baffles on the GT430, this should be available for sale.
Julian73 is offline
post #13 of 13 (permalink) Old Yesterday, 04:28 AM
tye-bo's Avatar
PM'd.
Current:
1970 Honda CT70 Red
Sold:
12 others...
tye-bo is offline
Similar Threads
BOE Headers Before and After o uncola o Lotus Evora 51 09-26-2018 10:59 PM
Moroso oil pan . Oil drain plug Cramec Lotus Elise 1 03-20-2016 07:04 PM
WTB HEADERS, decat, larini se dual tip, BOE rev300 or rev400 ,aluminum rad, Wheels Ziker Parts Wanted 8 10-21-2013 08:53 PM
WTB Moroso Oil pan, or any other aluminum oil pan with a turbo oil return line! ruggedbert Parts Wanted 0 11-26-2012 11:32 AM
Any Hawaii Lotus owners want a Moroso Aluminum Baffled Oil Pan? 143hawaii Pacific Region 0 07-15-2008 10:15 PM
