CEL with DTC P0133 and P0153 - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By Don262
  • 2 Post By bruss
post #1 of 14 (permalink) Old 04-11-2019, 05:04 PM Thread Starter
o uncola o's Avatar
Talking CEL with DTC P0133 and P0153
Hello brothers!
I am experiencing two DTCs based off of oxygen sensor readings. Car is stock other then cold air intake, headers, and cat-back exhaust. Did not throw the trouble code for the first 2000 miles with this setup. Curious if anyone has any experience and/or thought on the best way to troubleshoot.
2014 Evora S in Autumn Bronze. BOE headers and high flow cat, BOE cold air intake, otherwise stock. Hoping to install a new exhaust soon. New owner, new to the brand, and very excited!
o uncola o is offline
post #2 of 14 (permalink) Old 04-11-2019, 09:56 PM
BayAreaEvora's Avatar
I'm in a similar predicament. I installed a BOE CAI, cat delete and Larini exhaust and now get a P0137 code every few months. I clear it and it's fine for a few months then comes back. I'll keep an eye on this thread. Not sure how to fix the issue.
BayAreaEvora is offline
post #3 of 14 (permalink) Old 04-11-2019, 10:24 PM
It could be that the Lambda sensor, pre-catalyst on bank one is on its way out.
Lckitty likes this.
Don262 is offline
post #4 of 14 (permalink) Old 04-11-2019, 11:10 PM
bruss's Avatar
It could be that your cars are not stock.
West-of-Hethel and SL1DE like this.
bruss is online now
post #5 of 14 (permalink) Old 04-12-2019, 03:04 AM Thread Starter
o uncola o's Avatar
Thank you, I will take a look.
post #6 of 14 (permalink) Old 04-12-2019, 03:15 PM Thread Starter
o uncola o's Avatar
What have you tried so far?
post #7 of 14 (permalink) Old 04-13-2019, 09:41 AM
Illegal Alien
Julian73's Avatar
The following is pulled from the Factory Service Notes.
P0113 & P0153 are "slow response" from Bank 1 and Bank 2 - pre catalysts O2 sensors. Potential failure modes are:
1) Sensor Connector and wiring issues, corrosion, loose connection ... likelihood of issue on both banks unlikely as they don't share wiring.
2) Sensor contamination from fuel, engine oil, coolant, or improper use of RTV. ... more probable. as these causes could affect both.
Problem will not be a failed Catalyst, as these errors come from upstream of the Cat unit .. besides, BOE's "hi flow" Cat is the same type core as OEM (Magnaflow OEM long life replacement), just in a more streamlined housing.
Likelihood of O2 simultanious sensor failures, slime to none, except from external contamination.
As to BayAreaEvoea's code P0137 this is "Low voltage" Bank 1 post catalyst error.
Potential Failure modes:
1) fix any pre-cat code errors first
2) sensor wired shorted to GND
3) failed Catalyst
Julian73 is online now
post #8 of 14 (permalink) Old 04-13-2019, 02:29 PM Thread Starter
o uncola o's Avatar
3) failed Catalyst
Thank you so much! This is extremely helpful. At least I know where to check now.
post #9 of 14 (permalink) Old 04-18-2019, 03:10 PM Thread Starter
o uncola o's Avatar
Still completely at a loss. This is a tough one.
3) failed Catalyst
post #10 of 14 (permalink) Old 04-18-2019, 06:13 PM
3) failed Catalyst
Thanks for your help. I'll have to take check it this weekend. If I need to replace it, will a Denso 02 sensor for a Camry work? Or do I need to stay with the Lambda brand.
post #11 of 14 (permalink) Old 04-19-2019, 01:56 AM
pharriso's Avatar
Lambda isn't the brand, its the name of the sensor (aka Oxygen Sensor). Lamda is the ratio of Air: Fuel.
Phil Harrison
1972 Lotus Elan Sprint
2017 Lotus Evora 400
pharriso is offline
post #12 of 14 (permalink) Old 06-15-2019, 02:03 PM Thread Starter
o uncola o's Avatar
I am losing my damn mind! Nothing has worked. Now I am also getting code P0154. Not sure where to go from here...
post #13 of 14 (permalink) Old 06-15-2019, 03:14 PM
Illegal Alien
Julian73's Avatar
P0154 is O2 Sensor 1 Circuit No Activity Detected (Bank 2)
Potential failure modes:
Sensor connector and wiring should be checked for corrosion and loose connections
Gas leak in exhaust system
Again common error to P)153. a loose connection. Pull plug, clean, add dielectric grease and plug back together, make sure it snaps .. if that doesn't would then plug may have gotten damaged thus purchase a new O2 sensor (specific to car, they are not universal)
post #14 of 14 (permalink) Old 06-16-2019, 05:06 AM Thread Starter
o uncola o's Avatar
Thank you! I will purchase another 02 sensor.
Where is it most likely the exhaust leak would be? Pre or post cat?
Similar Threads
CEL Code P0133 & Poor idle - Resolved Felgacarb Maintenance and Repairs. 3 06-01-2018 01:32 PM
P0133 Code Help thp Check Engine Codes 4 07-04-2013 10:28 AM
FS: Brand new Hawk DTC-30 brake pads, front and rear marcinr Parts For Sale 6 10-10-2012 08:49 PM
New to me Lotus Elise - Lots of problems (P0133, rough idle, stall) thp Powertrain (Engine, Transmission, etc) 2 06-01-2012 02:01 PM
P0133 & P0153 error codes set MIL Wayne Ellison Lotus Esprit 0 05-06-2012 07:08 PM
