engine subframe difference (s1, 400) - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 06-10-2019, 04:47 PM Thread Starter
Does anyone know if the rear galvanized engine subframe is interchangeable between the S1 and the 400?
Incase I'm asking for help with something: 2011 Evora N/A C/R 6sp with BOE TVS 1900 S/C kit
John Z is offline
post #2 of 3 (permalink) Old 06-11-2019, 04:18 AM
Sorry, no direct experience. Looking at the part numbers and compatibility info on parts sites, I would think it's not a direct replacement. S1 updated part # H132A0012J, 400/410/430 part # C132A0605J.
Curiously the S1 part new looks to be a bit more expensive than the 400 part - salvage/used may be the way to go if you're in need of one.
-Spaghettipie
spaghettipie is offline
post #3 of 3 (permalink) Old 06-11-2019, 11:54 AM
Illegal Alien
Julian73's Avatar
Their was a lot of cost reduction engineering done on the 400's Im not sure these doesn't fall into that catagory.
Bottom line suspension points, engine mounts and tie in points to the main chassis have not changed so the parts may well be interchangeable.
For example the main chassis bolts and intermediary shim palms are the same PN's between Series 1 and $xx cars, as is the under tray shear plate and rear clam is also the called out as the same PN but admittedly a different Rev. Number. S1 A to F on 400's, bumpers are oblivious different, and use different brackets to subframe but such hardware is interchangeable between the submodels. so again much have common attachment points.
Julian73 is online now
