Evora 400 decat pipe - WOW! - Page 8 - LotusTalk - The Lotus Cars Community
 64Likes
post #141 of 149 (permalink) Old 04-30-2019, 07:51 AM
KingkongLotus's Avatar
Originally Posted by pharriso View Post
Just fitted my GRP decat, perfect fit, though i recommend this harbor freight pipe expander to use on the existing exhaust - https://www.harborfreight.com/automo...der-63704.html Best $19 you'll spend.
After installation delighted with the sound & throttle blips on downshift are definitely cleaner.
btw Guy came up to me on the Ferry & asked if the car was as good as it sounds!
Thanks for the tip on the pipe expander! That seems to solve the bigger challenge of this install! And yes, the car it definitely as good as it sounds! Is it the ferry on the Long Island Sounds?
2017 Evora 400, 2006 R53 MINI Coupe, 2010 135i Convertible, 2017 F-Pace S
KingkongLotus is offline
post #142 of 149 (permalink) Old 05-03-2019, 10:37 AM
Spent about 3 hours last night installing the GRP decat pipe and it was successful!! Got a chance to dive the car this morning and the sound is amazing!!! I used the exhaust pipe expander tool and the new pipe went in pretty easy. However, it was a tiny bit too long and I had to cut it to fit...Every exhaust is probably a little different.
If you are working by yourself, find something to support the muffler. It gets heavy after a while. I used a spare rim laying around the garage.
post #143 of 149 (permalink) Old 05-04-2019, 10:28 AM
pharriso's Avatar
Yes, Bridgeport CT --> Port Jefferson, LI, NY
Phil Harrison
1972 Lotus Elan Sprint
2017 Lotus Evora 400
pharriso is online now
post #144 of 149 (permalink) Old 05-05-2019, 05:46 AM
pharriso's Avatar
I just dropped the whole muffler down with brackets - just 4 bolts & makes adjusting the fit easy.
Phil Harrison
post #145 of 149 (permalink) Old 06-08-2019, 02:03 PM
jream's Avatar
Just installed the grp decat pipe today... holy hell this thing screams now! Significantly louder under normal driving circumstances and absolutely ridiculous above 4000 at WOT!
Went over to my buddies house and we knocked it out in a little under an hour. Super simple to do. Basically just remove the bolts holding the rear end cover shield. Undo the clamp that connects the exhaust assembly to the Y pipe. Take off the four screws holding the exhaust assembly in place and it easily comes out to finish the job. Undo the last clamp on the pipe to remove it. We had to beat it pretty good with a rubber mallet to get it to come off. Just working the cat pipe around a bunch to get it to free up to pull out. We picked up a rental pipe expander which you will definitely want to make things go easy. Use it to Open up the pipe where you insert the new pipe into. And simply re-install the exhaust assembly in place and bolt on the new Decat pipe. slap the cover back on and you are all set to piss off your neighbors!
Wasnt sure what to expect with the sound and throttle response, but after done I am extremely impressed!
Few pics
jream is offline
post #146 of 149 (permalink) Old 06-08-2019, 06:34 PM
troyus's Avatar
I didn't find the need to use an expander or much of anything really other than some time with the mallet to disgorge the 3rd cat... and then some graphite spray to install the GRP unit. That said, man this stock exhaust is heavy though....!!! At least the weight is low. One of my best friends is a master tech for Maserati and had harsh words on my OSHA compliance, however.
troyus is offline
post #147 of 149 (permalink) Old 06-09-2019, 06:10 AM
I had the same experience. My 3rd cat was Incredibly difficult to remove from the muffler. I bet it took 30 min of working it back and forth and prying on it. And the new one slipped right in after, no problem.
I also found that the bend radius was slightly different than the original cat. When I first went to install it, it was about 1/2 off from meeting up to the old pipe on the engine side. I had to leave everything very loosely connected to get things together, then gradually tighten it all up.
Sounds amazing
kell211 is offline
post #148 of 149 (permalink) Old 06-09-2019, 09:10 AM
Julian73's Avatar
Originally Posted by Redsled View Post
... Also I lifted up the stock exhaust and Larini exhaust and the Larini was much lighter, i would say felt like half the weight. So at only like $1,500 it's a bargain to change for the weight savings along with a much improved sound. For my R8's and Huracan exhaust changes were $6k-$7k. Again thanks for the help on this Greg.
The Evora How-to section has a thread on weights with a link to google spreadsheet. While these are Series 1 exhausts not the 3" 4xx series I cannot imagine the OEM being any lighter while the Larini's take a BIG chuck of weight out.
I have just hear across the channel that Lotus is now offering a non-valved sport exhaust that's quieter than stock to be able to meet the harsh track sound level limitations, the unit weights about 3 kg less than OEM.
'12 Evora S GP (No. 1 of 14) BOE Prototype S 430 **SOLD**
Julian73 is offline
post #149 of 149 (permalink) Old 06-09-2019, 09:27 PM
Just installed GRP's decat pipe today. As others have said, the pipe expander tool helps, not to mention dropping the whole muffler is the way to go. I tried for awhile to just slide it in to no avail. Ultimately the way I got the correct alignment was to drop the muffler, attach the decat pipe loosely to the v-band clamp, then slide the decat and muffler into place. Lastly tighten everything up.
The sound below 3k rpm is largely similar to stock, but above 4k rpm the shriek is much more raw as well as noticeably louder.
I made a quick comparison video of the sound between stock catted exhaust and with the GRP decat.
zthang is offline
