Evora 400 dyno test questions - LotusTalk - The Lotus Cars Community
 2Likes
  • 2 Post By Julian73
post #1 of 19 (permalink) Old 05-18-2019, 03:45 PM Thread Starter
I would like to schedule some dyno time at a friend's shop to compare the base 400 power to the Komo Tec EV4-435 reflash that I have installed (I can switch back and forth between the tunes via my laptop). The dyno is a 2WD Mustang dyno.
1) Can the 400 be tested on a 2WD dyno or will the fact that the front wheels aren't turning cause issues with the ECU?
2) I watched JayEmm's dyno video and his car wouldn't rev past 6600rpm - was that a result of it being on a 2WD dyno?
3) Do any undertray panels need to be removed to strap it down?
4) Anything else I need to know about dynoing an Evora 400?
Thank you in advance guys!
Champale is online now
post #2 of 19 (permalink) Old 05-18-2019, 04:55 PM
shay2nak
shay2nak's Avatar
Any dyno for RWD cars will be fine. Front wheels donít have to move.
His car probably wasnít fully warmed up yet to rev passed 6600.
They will likely strap down the car using the control arms.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #3 of 19 (permalink) Old 05-18-2019, 05:43 PM Thread Starter
Hey shay2nak - thank you for the comments. JayEmm's dyno was done at Hangar 111, which is one of the most knowledgeable Lotus shops in the world so I would be surprised if it was something as minor as not being warmed up sufficiently. He mentioned at the end of the video that they weren't sure why it stopped pulling at 6600rpm but that it might have to do with a power limiter when it senses being on a dyno. I have posted on the other forum and maybe JayEmm can chime in.
post #4 of 19 (permalink) Old 05-18-2019, 06:40 PM
Julian73's Avatar
We dyno'd on BOE Fabrications 2-wheel dyno. Without the front wheels rotating, car does not run in sport mode and traction control error limits RPM' to about 6600, in later years (2016) Phil got my car to 7100, but by this time BOE had access to full ECU editing and control, so i'm sure he just temporarily overrode the limits.
'12 Evora S GP (No. 1 of 14) BOE Prototype S 430 **SOLD**
Julian73 is online now
post #5 of 19 (permalink) Old 05-18-2019, 07:06 PM Thread Starter
Well there we go - that's good to know, Julian73!
Any knowledge about using a 4 wheel dyno? I would imagine that could solve the issue, right? I honestly don't want to waste my time if a 2 wheel dyno won't give me complete results.
post #6 of 19 (permalink) Old 05-18-2019, 07:31 PM
The Enforcer
oldmansan's Avatar
No, a four-wheel dyno is for a four-wheel/all-wheel drive vehicle. A two-wheel dyno is what you want.
San
oldmansan is offline
post #7 of 19 (permalink) Old 05-18-2019, 07:47 PM
Julian73's Avatar
A 4-wheel dyno still has an issue in that you will need to spin the front roller to roll the tires, maybe that is a standard alternative operating mode of a 4-wheel dyne, other than the standard assumption that all wheels will be driving.
A 2-wheel dyne with runs up to 6600 is good enough, torque is falling, and power is only slightly increasing and only if the car has a freezer flowing exhaust (headers). running and tuning on a 2-wheel is not a waste.
post #8 of 19 (permalink) Old 05-18-2019, 07:54 PM Thread Starter
Dynojet and others offer 4 wheel dynos in which the front and rear rollers can be linked for exactly the reason we are talking about - wheel speed differences causing ECU freakouts.
I want a full picture up to the rev limiter. JMS Tuning is not far from me so I will check with them - they do a ton of GTRs, Evos, STIs along with Corvettes, Camaros, etc.
post #9 of 19 (permalink) Old 05-18-2019, 07:59 PM
Julian73's Avatar
My last tune back in 2016 on the Series 1 S
Champale and brucemunro like this.
post #10 of 19 (permalink) Old 05-18-2019, 08:03 PM
TachItUp's Avatar
San
Some of the newer single-drive-axle vehicles freak out on normal dynos. For example, it's impossible to run our Abarth 500 on a typical dyno since the car sees a wheel speed difference between front and rear and then cuts power. It takes a specialized dyno that spins both axles at the same rate to get a proper run in.
TachItUp is offline
post #11 of 19 (permalink) Old 05-18-2019, 10:02 PM
The Enforcer
oldmansan's Avatar
Didn't realize that. My former C6 and current Exige S were only ever on a two-wheel drive dyno, but obviously they're older cars. I'm surprised there isn't some way to disengage the functionality temporarily.
San
post #12 of 19 (permalink) Old 05-19-2019, 03:54 AM
I'll be once you get past 'traction control' and into 'stability control' you cannot do the 2 wheel thing
exigegus is offline
post #13 of 19 (permalink) Old 05-19-2019, 07:02 AM
bruss's Avatar
Not a 400 , but rear wheel only turning on my S. Turn off tc and make sure the steering wheel is straight, turn on sport mode.
Some runs testing air box configs. 6800 ish rpm seen. Figures are taken at the wheel ( bolted on to the hub)
bruss is offline
post #14 of 19 (permalink) Old 05-19-2019, 08:26 AM Thread Starter
Thank you guys for posting up those charts and all of the other information! I have dyno'd various cars and motorcycles over the years but this one doesn't seem as straightforward all the way around!
Bruss and Julian73 - do you recall if the dyno operators had to take any undertray panels off for the straps? To my eyes, it looks like the suspension is exposed enough to be used as strapping points. I am trying to save the dyno shop some time (and money) so that if panels need to come off, I will do it at home and then take the car over to the dyno.
post #15 of 19 (permalink) Old 05-19-2019, 08:38 AM
bruss's Avatar
No undertrays were removed. However mine wasn't strapped down. The wheels are removed and the hub dyno is attached directly to the hub replacing the wheels. In this way the hubs are suspended above the floor by the dyno itself.
The main thing, as you probably know, is that if making comparison runs keep an eye on intake temps.
bruss is offline
post #16 of 19 (permalink) Old 05-19-2019, 08:45 AM Thread Starter
Ah yes I have seen those types of dynos online but never in person. Thank you for letting me know.
post #17 of 19 (permalink) Old 05-19-2019, 01:20 PM
tye-bo's Avatar
I had the same issue today, it wouldn't rev over 6800rpm. And my buddy just bought the dyno, so we are still trying to figure it out. Not sure how accurate the HP numbers are.
Current:
2018 Evora 400 Metallic Black Manual
1998 Volvo V90 silver L59/4L60 swapped
1970 Honda CT70 Red
Sold:
2017 Audi R8 Silver V10/DCT
2010 Evora Carbon Grey Manual
12 others...
tye-bo is offline
post #18 of 19 (permalink) Old 05-19-2019, 10:40 PM
shay2nak
shay2nak's Avatar
interesting... fully warmed up?
I forgot to say to also turn off the traction control.
WTC 2
shay2nak is offline
post #19 of 19 (permalink) Old 05-20-2019, 04:18 AM
tye-bo's Avatar
Yes, it was fully warmed up, 45 minute drive (mix of highway/stop and go) to my buddy's shop, in TX where ambient temps were 80-85įF.
It consistently held the 6800RPM red line, ESP was commanded off, but kept interfering, so that leads me to believe I didn't turn it off correctly. (put it in Race mode, then push the race button for 1 sec) Eventually the ABS light and ESP OFF lights were illuminated and stayed on.
After I do the exhaust/intake mods, then I'll be back on the dyno and try the ESP off again.
Current:
1970 Honda CT70 Red
Sold:
12 others...
tye-bo is offline
Similar Threads
Evora 400 Shrugs Off R&T's Torture Test glb Lotus Evora 11 05-02-2018 11:45 AM
Baseline Dyno Plots. Post Your Dyno Plots here fzust Powertrain (Engine, Transmission, etc) 131 08-29-2017 07:08 AM
VISIT GATOR MOTORSPORT & TEST DRIVE THE NEW LOTUS EVORA 400! APRIL 15TH & 16TH! GatorMS_Sales Meets and events 2 04-08-2016 01:53 PM
Evora 400 Test Drive ACE51 Lotus Evora 22 01-10-2016 09:50 AM
test test test Donbecker Lotus Talk Forum Feedback and Site Issues 3 09-19-2006 05:13 PM
