Evora 400 Trunk latch release - LotusTalk - The Lotus Cars Community
 5Likes
  • 1 Post By dogtag114
  • 2 Post By lotusquacious
  • 1 Post By Rahl
  • 1 Post By Redsled
post #1 of 17 (permalink) Old 09-06-2019, 04:24 PM Thread Starter
RWLott's Avatar
It takes too many button presses to get the trunk latch release mechanism to make a noise, let alone open the trunk. Most of the button presses there is nothing, no response whatsoever. Eventually it opens.
Anyone else experience this?
Makes no difference with a new key fob battery.
SOLD-2005 Elise Starlight Black, hardtop, touring pack (36K+miles). SOLD 2012 Evora IPS 2+0 Starlight Black Larini Sport Valved (40K+miles). 2018 Evora 400 Starlight Black 2+2, purchased June 2018. 2012 Elantra, 2005 Astro Van.
RWLott is offline
post #2 of 17 (permalink) Old 09-06-2019, 04:27 PM
Yes I have this issue. Even the button on the door has to be pressed a few times for it to click open.
xxaarraa is offline
post #3 of 17 (permalink) Old 09-06-2019, 04:36 PM
nintense's Avatar
Usually takes couple weeks practice to figure the right sequence of the double click
nintense is offline
post #4 of 17 (permalink) Old 09-06-2019, 05:37 PM
dogtag114's Avatar
Agree on the timing... you have to press once... count to 2 quickly and press again
nintense likes this.
dogtag114 is offline
post #5 of 17 (permalink) Old 09-06-2019, 06:21 PM
Loves to talk
lotusquacious's Avatar
Click...one Mississippi....click. Don't dawdle on Mississippi.
nintense and dogtag114 like this.
Lew
'17 Evora 400 MT
lotusquacious is offline
post #6 of 17 (permalink) Old 09-07-2019, 07:07 AM
Rahl's Avatar
I’ve found through a bit of trial and error that holding the fob over the left side of the trunk near the quarter panel usually works.
And pushing it about 15 times with a curse spread here and there will get the car to lock and beep.
xxaarraa likes this.
Rahl is offline
post #7 of 17 (permalink) Old 09-07-2019, 08:53 AM
ByJoveByJingle's Avatar
Originally Posted by Rahl View Post
Iíve found through a bit of trial and error that holding the fob over the left side of the trunk near the quarter panel usually works.
I do all that, then give up and go press the release button inside the cabin.
2017 Lotus Evora 400 (6-speed) Yellow on Black
2014 Lotus Evora S 2+2 (6-speed) Verde Ithaca paint with Ebony Black/Red piping interior {Sold}
2010 Lotus Evora, White with Paprika interior, (6-speed){Traded-in}
ByJoveByJingle is offline
post #8 of 17 (permalink) Old 09-07-2019, 09:04 AM
wfink's Avatar
Me too.
Sent from my iPad using Tapatalk
wfink is offline
post #9 of 17 (permalink) Old 09-07-2019, 10:23 AM
Redsled's Avatar
I had a lot of trouble with mine when I first got car but much better now after dealership took a look at it. They put a camera in truck and saw where it was striking the latch when you pushed button was not quite right and they made an adjustment. Also what they found interesting was my friends car was in there at the same time and his was having problems also so they went to apply fix. Then they noticed his setup was a little different than mine, seems Lotus made a change to get it to work better. And according to VIN# my car is only 11 vehicles newer than his. They ordered the newer part that was on my car for his and it fixed it
dogtag114 likes this.
Current:
2018 Lotus Manual Evora 400
2015 Huracan VF800 Supercharged
2018 Audi SQ5
Past:
2012 R8 Manual V10 VF750 Supercharged
2009 R8 Manual V8 VF550 Supercharged
Redsled is online now
post #10 of 17 (permalink) Old 09-07-2019, 05:37 PM
dogtag114's Avatar
That may be an example where the certificate of provenance may have some value... if you are in the earlier part of the years batches, you may have some different parts... and can be aware of trouble areas from these forums before your warranty expires. One weird change is the base of the supercharger. Mine is black but earlier and later ones are bare metal... no pattern that I've seen.
post #11 of 17 (permalink) Old 09-08-2019, 01:24 AM
bruss's Avatar
Iíve found through a bit of trial and error that holding the fob over the left side of the trunk ntear the quarter panel usually works.
All the while standing on one leg and facing east?
bruss is offline
post #12 of 17 (permalink) Old 09-09-2019, 08:31 AM
Rahl's Avatar
No........west.
Rahl is offline
post #13 of 17 (permalink) Old 09-09-2019, 01:54 PM
pharriso's Avatar
There were some parts upgraded, my December 2016 built had the latch replaced & no issues since.
Phil Harrison
1972 Lotus Elan Sprint
pharriso is offline
post #14 of 17 (permalink) Old 09-10-2019, 05:10 AM
tye-bo's Avatar
With mine, I figured out that if I slow down my presses to about one second it works first try every time (as long as I'm <6ft from the car). So I press the button and hold for one second, wait one second, press and hold the button again for one second, then it pops every time. Key fob range is another story, and the fob has a brand new battery.
Current:
2018 Evora 400 Metallic Black Manual
1998 Volvo V90 silver L59/4L60 swapped
1970 Honda CT70 Red
Sold:
2017 Audi R8 Silver V10/DCT
2010 Evora Carbon Grey Manual
12 others...
tye-bo is offline
post #15 of 17 (permalink) Old 09-10-2019, 06:12 AM Thread Starter
RWLott's Avatar
trunk latch
I never had this trouble with the '12 Evora.
Once again the engineers at Lotus got involved making things more complex. Why?
I still cannot get over the programming that went into the ECU generating unnecessary CEL codes, e.g., transmission error when the car is in park.
Experimenting with the timing between button presses appears to work!? At least now I can get to the golf clubs.
RWLott is offline
post #16 of 17 (permalink) Old 09-10-2019, 06:35 AM
bfgmovies's Avatar
This is exactly what I do on mine and it works every time, haven't tired longer distances though
bfgmovies is offline
post #17 of 17 (permalink) Old 09-10-2019, 08:02 AM
WestCoastLotus's Avatar
I did the Push Button dance for months. The Dealer worked on it Three times, now it works with one push of either button. Have the trunk adjusted!
2017 Evora 400 - Drop Dead RED
38,000 Km - 23,600 mi.
WestCoastLotus is offline
