Evora Wilwood Clutch Master Cylinder Group Buy - LotusTalk - The Lotus Cars Community
 18Likes
post #1 of 53 (permalink) Old 11-24-2015, 12:28 PM Thread Starter
Elise Guru
GregsRaceParts's Avatar
2011+ Evora Wilwood Clutch Master Cylinder Upgrade Kit
One of the most common issues that plagues the Evora's is the master cylinder. It is only a matter of time before the oem plastic unit fails. The update/recall from Lotus isn't any better either.
This Kit adapts a upgraded Wilwood master cylinder into your stock location, eliminating a chance for plastic failure.
No drilling! Bolts/adapts onto the factory bolts and factory pedal location.
Kit Includes:
- Wilwood master cylinder
- Adapter plate
-Hardware
-Pedal fork
-Clutch line to the LF wheel well Union
-AN to metric adapter for line
We have 6 kits in stock ready to ship!
$419 + shipping retail.
Group Buy price: $395 shipped
Pm me to get yours!
Check out GregsRaceParts.com for all of your Elise, Exige and Evora parts needs!
Email:[email protected]
IG: @gregsraceparts
FB: @gregsraceparts
GregsRaceParts is offline
post #2 of 53 (permalink) Old 11-25-2015, 04:29 AM
brgelise's Avatar
Good to know it exists. Not looking forward to the clam off part for the job, that's all.
phenoyz likes this.
brgelise is offline
post #3 of 53 (permalink) Old 11-25-2015, 08:13 AM
brightoncorgi's Avatar
Will this kit be available in the future?
Past & Present:
2017 Jaguar XE R-Sport
2012 Aston Martin Rapide
2011 Aston Martin V8 Vantage Manual
2011 Lotus Evora - Aspen White
2005 Range Rover HSE
2007 Jaguar XK Coupe
2004 Jaguar XJ350 Vanden Plas
brightoncorgi is offline
post #4 of 53 (permalink) Old 11-25-2015, 05:12 PM
F1 SML8R's Avatar
Future? It's available now.
F1 SML8R is offline
post #5 of 53 (permalink) Old 11-26-2015, 08:39 AM
Carlotus's Avatar
I thought Chaos has already undertaken this project and has kits available.
Carlotus is offline
post #6 of 53 (permalink) Old 11-26-2015, 09:25 AM
F1 SML8R's Avatar
These are his design I believe.
F1 SML8R is offline
post #7 of 53 (permalink) Old 11-26-2015, 11:12 AM
Chaos's Avatar
Yes this is correct, but I don't plan to keep making and selling them one at a time and shipping them out.
Chaos is offline
post #8 of 53 (permalink) Old 01-05-2016, 08:34 PM
Kit Includes:
- Adapter plate
-Hardware
-Pedal fork
Pm me to get yours!
This might be a stupid question but I just got a 2010 and I am curious if this problem will come to me at some point. Does this work for a 2010 model?
vallejoricky is offline
post #9 of 53 (permalink) Old 01-06-2016, 05:20 PM
Chaos's Avatar
No this will not work, the pedal box was reconfigured in 2011 but the good news is the metal earlier ones very rarely fail!
ChaosPerformance.com
2011 Evora S starlight black, gt3076 turbo, Chaos Performance 550hp Built internals package, still the daily driver(weather permitting have an f250) 40kmiles on the car in 2 years!
Chaos is offline
post #10 of 53 (permalink) Old 01-08-2016, 01:31 AM
squidward's Avatar
Chaos is correct. If you have a 2010, you should replace it with the original clutch master cylinder. I have a 2010 and just replaced mine.
The tech had ordered the revised one for me thinking it was covered by the recall, but it turned out to be the wrong part. He had to order the original part and the car feels like new. I kept the original parts for reference. It was just a matter of worn seals, so technically the part could have been serviced too, but they aren't terribly expensive.. The work is what will cost you
If you do it you'll want to do the slave as well, as they wear equally.
squidward is offline
post #11 of 53 (permalink) Old 04-05-2016, 01:12 AM
PLAY-DOH's Avatar
I purchased the kit and am not looking forward to the clam off job ahead. The pedal has only stuck down twice. Once on my wife and once on me. I'm wondering how many times it will stick before it finally fails and leaves me without a clutch? We had nearly 200 miles between the failures before. Will it get worse? What else should I do when the clam is off? Inspect radiator and condenser for sure but what else? Any links on removing the front clam?? Thanks
2011 Lotus Evora N/A Quartz Silver
PLAY-DOH is online now
post #12 of 53 (permalink) Old 04-05-2016, 05:17 AM
Chaos's Avatar
Look at the instructions on gregsraceparts.com, and the clam off job is not much work. Having an S makes it take a bit longer because it's harder to get to the headlight with the coolers. But it's only 5-6 hours to take it off and put it on. While it's off you should inspect the radiator, or just replace it with an aluminum welded one. Also if your vent mesh is warped replace that.
I replaced my fans when mine was off, I would suggest doing that but I created custom bracketry for mine. You should be able to find a solution that drops in though.. Not sure.
If you need any help or questions shoot me a pm.
James33, phenoyz and PLAY-DOH like this.
Chaos is offline
post #13 of 53 (permalink) Old 05-22-2016, 07:30 PM
Richw1314's Avatar
Are any of these kits still available? Looks like my master cylinder has gone out again, but this time out of warranty.
Richw1314 is offline
post #14 of 53 (permalink) Old 05-23-2016, 11:40 AM
Spinner6996's Avatar
Ditto....I need one!! Any available?
2011 Evora S with BOE CAI, Larini race pipe,Top Speed Pro-1 resonated exhaust, Tech and Premium
2007 AMV8 (Sold-never driven after the Evora S!)
2017 Range Rover Sport SVR
Spinner6996 is offline
post #15 of 53 (permalink) Old 05-23-2016, 11:41 AM
And if someone can post a DIY with pics it would be much appreciated!
post #16 of 53 (permalink) Old 05-23-2016, 11:45 AM
agentdr8's Avatar
I think they can be ordered directly from GRP (unless maybe stock is gone?) @Chaos provided a how-to doc which is linked on that page, and also here.
If there's another group buy for this m/c, I'd be in for 1 too.
agentdr8 is offline
post #17 of 53 (permalink) Old 05-23-2016, 11:55 AM
Bobsy Racer's Avatar
My 2011 NA Evora is a June 2010 build.
I have never had any problems with my Clutch Master Cylinder or Slave Cylinder.
Is there a way to tell if I have the early Metal Master Cylinder ?
Is the Master Cylinder visible if you remove the front under-tray ?
BTW, I've heard that Lotus went to the Plastic Master Cylinders when they came out with the S Evoras, since the Plastic ones were supposed to be rated for a higher pressure. Then, they just used the Plastic ones on ALL of the Evoras at that point.
Bobsy Racer is offline
post #18 of 53 (permalink) Old 05-23-2016, 12:28 PM Thread Starter
Elise Guru
Hey Guys,
Sorry i wasnt on here all weekend and missed these!
These are still avaiable through us at GRP.
The instructions write up is available for download here: https://gregsraceparts.squarespace.c...e-kit-11-evora
These kits ship typically in 3-5 business days.
Let me know of anymore questions. Feel free to pm me as well.
IG: @gregsraceparts
FB: @gregsraceparts
post #19 of 53 (permalink) Old 05-23-2016, 01:01 PM
Chaos's Avatar
If you take a picture of the bolt configuration by the clutch master cylinder shaft, that comes through the footwell and connects to the clutch pedal, then I can tell you if the kit will work or not
Chaos is offline
post #20 of 53 (permalink) Old 06-05-2016, 06:02 PM
PLAY-DOH's Avatar
Well, I removed the clam today and much to my surprise I found I had the METAL MC....not the plastic unit! I was determined to make the Wilwood kit work so I had to do some modifications.
The factory metal MC has a short rod compared to the kit from GRP. First I thought I'd make the GRP billet adapter work by turning it over and just using it as a spacer. This would have required a relief to be cut on one side to allow the spacer to sit perfectly flat on the firewall and a trip to the hardware store for some longer 8MM bolts.
It turned out it was easier to remove the rod from the Wilwood unit and adding about 5/8" more thread to the new rod and not using the spacer. This allowed me to run the clevis in farther to get me back to the original length throw. Now doing that, made me cut off about 3/4" from the new rod so it wouldn't interfere with the pedal bracket where the pin goes through. I was able to use the factory bolts but had to drill out the clevis because my factory pin was larger at the pedal.
Other modifications included opening up the hole in the firewall to approx 1-1/4 so the MC would sit flat and opening up the gasket as well.
It seemed every turn I took there was a new obstacle but with enough persistence it mounted beautifully. I crammed the small rubber hose over the new plastic barb on the MC. It had to be spun around so it didn't hit the brake servo. The clamp was spun as well to make it more friendly to tighten. I got my neighbor to help me with the nuts up top while I went in and contorted myself to fit under the steering wheel to access the pedal box. I swear this is harder than pulling the clam off. I tightened everything up and reinstalled the potentiometer to the pedal which is held to the servo by two bolts. After the blood rushed back to my head I was able to crack a beer and start on the new brake line and filling the system.
Bleeding was straight forward and I did it in several places. I had my wife help me on that and we finalized it with a fresh system filled with Castrol racing fluid. I used my bleeder and got it all done without having to take the bottom pan off. It is possible but you have to work blind to do it
This kit is top notch although I don't think Greg intended it to fit the earlier years. The new line is a stainless braided piece that has quality fittings on it. He even threw in the adapters for the MC and the firewall union. The first couple pushes was a delightful surprise with MUCH less effort to move the pedal.
Here are a couple photos of the before and after. I'm also going to tackle the cracked windshield while I'm here
Thanks CHAOS for the helpful hints!
