Exterior mirror loose (housing) - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 05-15-2019, 05:34 PM Thread Starter
roarf's Avatar
My driver's side mirror feels rather loose. It's the actual housing that wobbles about the pivot point, NOT the mirror glass. I searched and found a few threads but they were mostly with regards to the mirror glass shaking. Are there a couple of screws behind the glass that might have come loose, or could it be something loose within the power fold mechanism? The passenger side feels pretty tight, no issues there. I do not have a power fold switch yet nor do I manually fold them in. Any help is appreciated.
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black (gone but not forgotten)
'08 RS4 - Imola Yellow/Black (gone but not forgotten)
roarf is offline
post #2 of 8 (permalink) Old 05-16-2019, 09:27 AM
agentdr8's Avatar
If it seems loose around the pivot point, there's a few screws that hold the mirror part to the mount from the bottom, underneath the lower plinth. If it feels loose at the triangular intersection near the window, there's a pair of screws that hold it from the inside, underneath the upper plinth that's held on by 2 plastic scrivets.
Either way, you'll have to remove one or both of the plinths to get to the screws to tighten them up.
agentdr8 is online now
post #3 of 8 (permalink) Old 05-16-2019, 06:48 PM Thread Starter
roarf's Avatar
It's loose about the pivot point, or in other words, it's loose between the housing and the base (part that bolts to the door). The base is firmly secured to the door.
Which part is the lower plinth? I see one screw on the bottom of the mirror housing and it's already tight. I can peek behind the mirror glass and see two black screws on a silver block and neither of those look loose when I wobble the housing. Not sure if those screws have any impact on this though...
roarf is offline
post #4 of 8 (permalink) Old 05-16-2019, 08:24 PM
agentdr8's Avatar
The lower plinth comes off by removing that lower screw on the bottom. There's another set of smaller screws that hold the mirror to the pivot point from below.
It's probably easier to get the lower plinth off if you unbolt the whole thing from the car since it kind of tucks in behind the door skin.
post #5 of 8 (permalink) Old 05-21-2019, 07:47 AM Thread Starter
roarf's Avatar
I suspect those are the screws that are loose. Think the lower plinth can flex enough to at least get a look in there? Getting the mirror off means the door panel has to come off, right?
roarf is offline
post #6 of 8 (permalink) Old 05-21-2019, 08:38 AM
agentdr8's Avatar
I've never tried removing the mirror without taking the door panel off, so I don't know if that's possible.
The panel comes off easily enough. I believe there's a how-to posted. You shouldn't need to disconnect the interior door handle cable, just the electrical connectors.
post #7 of 8 (permalink) Old 05-27-2019, 03:11 PM Thread Starter
roarf's Avatar
So I took the single screw off and flexed the lower plinth down enough to peek in and sure enough, 2 of the 3 screws are clearly not tightened down all the way. Going to order a power fold mirror switch before I pull the door panel off so I can install that and fix the mirror at the same time. Will report back once I'm done.
roarf is offline
post #8 of 8 (permalink) Old 06-15-2019, 02:55 PM Thread Starter
roarf's Avatar
Finally took care of this. Here are a couple of pictures for anyone else that needs to do this. Note that there is a second screw holding the lower plinth on, which is covered by a thin foam seal. Peel it back to reveal the second screw. These are Pozidrive screws, NOT Phillips, as are the two screws under the door panel air duct boot. None of the 3 torx screws underneath were actually "loose", so to speak. Not entirely sure if they thread into plastic or metal but they appeared to just not be threaded deep enough (self-tapping, I think..). Tightened all 3 down as far as they would go and now the mirror is nice and solid.
roarf is offline
Similar Threads
noisy mirror housing bfm01 Lotus Evora 8 10-31-2014 12:21 PM
FS: Exige S, S Decals, and Mirror exterior black stickers mc21 Parts For Sale 3 04-22-2014 10:56 AM
WTB: Passenger Side Mirror Housing (Ardent Red) boardkat Parts Wanted 0 12-01-2011 11:22 PM
Passenger side mirror is loose and Rattles. Canyon Red Elise General Discussion (Lotus related) 4 06-25-2007 10:13 AM
Broken Mirror Housing Wanted Thomasio General Discussion (Lotus related) 3 02-25-2007 07:53 AM
