High beam donít work - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 05-04-2019, 04:59 PM Thread Starter
Hi. Car is always with the lights on. Donít know if are day lights or low beam. Previous owner went to the dealer and during the inspection they found a broken fuse. They replaced and the high beam works but broke the check schematics and wiring and found the ďfuse control the (ICM) that is a module that controls the high beam in the headlights with internal circuit fail in the front (LH) head lampĒ.
Help here, is a fuse/relay think of some control inside the headlight. The ICM is the black box right?
Thank.
Xattica is offline
post #2 of 7 (permalink) Old 05-04-2019, 08:43 PM
agentdr8's Avatar
The ICM is the black box in the passenger foot well area, near the fuse panel.
I would check fuse C2, which should be a 5A. If that's fine, check C19, which should be a 15A.
The headlamps themselves don't have any fuses or relays inside of them. They do have a ballast, and the solenoids though. If the fuses are fine, then check pin D13 on the ICM when the high beams are turned on and see if +12V is present, and if not, then there's an issue with the ICM or your LH column switch/stalk.
agentdr8 is offline
post #3 of 7 (permalink) Old 05-05-2019, 05:22 AM Thread Starter
Thanks! I will check!
Xattica is offline
post #4 of 7 (permalink) Old 06-06-2019, 02:39 PM Thread Starter
Where is the Fuse box? On the white area or below the other carpet?
Xattica is offline
post #5 of 7 (permalink) Old 06-06-2019, 03:31 PM
agentdr8's Avatar
Behind the passenger foot panel (the vertical carpeted piece in your picture). There are 4 quarter-turn fasteners; 2 in the upper corners, and 2 in the middle "hump" of the panel near the edges.
agentdr8 is offline
post #6 of 7 (permalink) Old 06-06-2019, 03:31 PM
Happy To Be Here
ShadowWulf369's Avatar
Itís below the other carpet, closer to the nose of the car. I believe itís held on by four quarter turn fasteners.
2013 Evora IPS - Carbon Gray
2016 BMW 328xi - Estoril Blue
ShadowWulf369 is offline
post #7 of 7 (permalink) Old 06-06-2019, 05:26 PM Thread Starter
Thanks a lot!!!!
Xattica is offline
Similar Threads
High Beam Upgrade reganfin Lighting 4 01-23-2009 03:56 AM
high beam fixed swtich doesn't work ummagawd Electrical 4 12-31-2007 05:04 PM
Installing Fog/Driving Lights without High Beam On GetBoost Electrical 12 03-24-2006 01:11 PM
Left high beam, doesn't want to turn off Genjuro Electrical 10 03-30-2005 12:57 PM
The high beam and traffic. Allan Gibbs Lotus Elise 63 11-23-2004 04:06 PM
