If you were wondering, Dashcams are stupid easy to install in the Evora - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By zthang
  • 1 Post By agentdr8
post #1 of 8 (permalink) Old 09-04-2019, 10:47 AM Thread Starter
I didn't have to take apart any of the headliner/A-pillar/glove box for this install and you cannot see any of the wiring. The headliner is pretty loose and you can easily shove the wire under it, and there is rubber door seal/weather stripping down the side that you can easily tuck the wire under. Only the passenger footwell plate needs to be removed in order to access the fuse box.
I'm using the Garmin 45 dash cam with the Garmin Parking Mode wiring kit. This allows the dash cam to utilize Parking mode, which records when there's motion or vibration even when the car is off/you are parked and not in the car. For this to work, it just requires one constant 12v source and one 12v Accessory source to be tapped. I used the radio constant 12v fuse and the cigarette lighter fuse for accessory power.
I'm also changing out the factory head unit which is total garbage (more on that later).
ShadowWulf369 likes this.
zthang is offline
post #2 of 8 (permalink) Old 09-04-2019, 11:00 AM
Happy To Be Here
ShadowWulf369's Avatar
The headliner on my S1 was VERY tight and it was a bit of a struggle to get the wire underneath, but aside from that, agreed, very easy to install and good protection in case someone else drives like a ding bat. I cheated on my install because I replaced the head unit and there was a USB port on the back I used to power the camera. I didnít want the camera to drain my battery while parked, so Iím very happy with the setup. If I wanted full park mode, youíre right that the fuse box is right there. I went with a Viofo A119 V2 for my camera for the capacitor and lack of suction cup mount. Thereís a new V3 that has a better night mode and higher resolution for a few extra bucks. Either way, thereís almost no excuse to not install one in an Evora.
2013 Evora IPS - Carbon Gray
2016 BMW 328xi - Estoril Blue
ShadowWulf369 is offline
post #3 of 8 (permalink) Old 09-04-2019, 11:30 AM Thread Starter
Yeah I have the same concern with the battery drain in park mode, but the garmin website says its 'minimal' and you can set a timer to turn it off after parking. Still a concern but I have the car on a battery tender at home and usually am not out for days at a time so hopefully its ok. They have more info on it on their website here: https://support.garmin.com/en-GB/?fa...iZ66tr4NvYzgd5
zthang is offline
post #4 of 8 (permalink) Old 09-04-2019, 01:32 PM
bfgmovies's Avatar
Did the exact same thing with my Evora 400, was really easy to tuck the wires right under the lining, and then through the door seals to a wire to power the back camera as well.
bfgmovies is offline
post #5 of 8 (permalink) Old 09-04-2019, 01:40 PM
MGB
I can't really tell from the photo. How did you tie into the fuses?
2011 NA Evora
MGB is offline
post #6 of 8 (permalink) Old 09-04-2019, 02:01 PM
agentdr8's Avatar
Circuit taps/piggyback fuse holders work great for this purpose.
2011 chrome orange likes this.
agentdr8 is online now
post #7 of 8 (permalink) Old 09-04-2019, 02:13 PM Thread Starter
Yes these are exactly what I used
zthang is offline
post #8 of 8 (permalink) Old 09-04-2019, 02:28 PM
MGB
Very cool; I didn't know about these, thanks
2011 NA Evora
MGB is offline
