Jack stands? - Page 4 - LotusTalk - The Lotus Cars Community
 9Likes
post #61 of 122 (permalink) Old 08-21-2014, 03:38 PM
Haha! I actually designed these for my Aston Martin V8 Vantage. I wanted to get the tires changed and do not trust any shop to use the tiny jack points correctly (even though I made jack point blocks).
There was really no way to put the Aston on 4 regular jack stands. Can't get under the front or rear to jack it up. Jack it up on one side, then put one jack stand on the front jack point. Then what? Lower it down on one jack stand, with no keeper for the stand, just smooth aluminum? I think not.
So....I made these..
Jack up one side of the car, take both wheels off, mount these hub stands. Set on ground. Then go to the other side and repeat.
Now I can put new tires on my Vantage!!!
I plan to use the hell out of them on our Exige as well. No more winter flat spots on the R888's.
Can't work on suspension with them (other than leveling the car etc..) but there are many other uses for them.
For those that can't imagine that they'd be stable, here is a video.
https://www.youtube.com/watch?v=XWR9qymv1tk
2006 Exige BWR Supercharged, Solar Yellow
2005 Elise, Chrome Orange
2005 Elise, Arctic Silver (Sold)
2007 Aston Martin Vantage
2008 Ducati HyperMotard
1986 F20C powered AE86
1962 Land Rover Series II
Gabriel Tyler is offline
post #62 of 122 (permalink) Old 08-21-2014, 03:39 PM
JLSELISE's Avatar
They will not work well (or easily) with A-arm suspensions. They are more appropriate for strut suspensions.
With A-arms, when compressing the suspension from full droop to ride height the hub can move "out" (i.e., perpendicular to the chassis) an inch or more. Those stands will not accommodate that motion unless they are on rollers, which kind of defeats the purpose .
Joel
'67 S3 Elan dhc (owned since 1970)
'10 Evora (Carbon Grey/Charcoal)
'13 Volvo S60 T6 R-Design
JLSELISE is offline
post #63 of 122 (permalink) Old 08-21-2014, 04:20 PM
Actually they worked just fine on the Lotus and on the rear of the 510 in the video. I do know what you are talking about though. The foot pads on the stands kinda slid and scooted their way out over the concrete in the shop when putting the car down. Nothing startling though!
post #64 of 122 (permalink) Old 08-21-2014, 05:21 PM
F1 SML8R's Avatar
Not that I'm suggesting a re-design, but you could address that small chance of it slipping out by simply making the base wider/larger overall. That would provide a more stable footprint preventing any possible minor creep.
F1 SML8R is online now
post #65 of 122 (permalink) Old 08-21-2014, 06:28 PM
Originally Posted by sirnonz View Post
saw this earlier today, has anybody tried it? looks like it would work good for those who needs 4 corner off the ground and don't want to deal with jack stands.
https://technotoytuning.com/universa...ing-hub-stands
These are perfect - inexpensive and does what I need. Will definitely have to get a set! It's an extra step to take the wheels off but not a deal breaker for saving a lot of money.
James
2015 Alfa Romeo 4c
2018. Lotus Evora 400
2010 Toyota 4Runner Limited
James33 is offline
post #66 of 122 (permalink) Old 08-21-2014, 07:21 PM
F1 SML8R: These are very stable, as seen in the Youtube video, but I will widen the foot pads by 1.5" all around. Thank you for your input.
post #67 of 122 (permalink) Old 08-21-2014, 07:53 PM
F1 SML8R's Avatar
Agreed, the video definitely got the point across, but the extra surface area definitely couldn't hurt. Overall, great solution.
post #68 of 122 (permalink) Old 10-12-2014, 04:44 PM
XHILR8N!'s Avatar
Time to get the Evora up on stands. Need to remove wheels, and change that vintage brake fluid. Lifted the Elise a zillion times. I like lifting Evora better.
First of all, an Evora has awesome deeply ribbed aluminium pads to lift on.
I stole a bit of Chrome Orange's idea, but a lot simpler (Lotus like?)
Needed:
4 stands. I like these, not cheap but perfect for our cars. And I'm getting under there!
Also, two jacks. I have the small one and a larger one from Harbor Freight. I know that place is quite questionable but these do work.
Hockey puck or wooden pad that size.
Rhino ramp
This is the key: a thick piece of wood about a foot square.
This took maybe 20 minutes, first time.
Here we go.
Use large jack to lift by rear pad enough to place a stand under the front point (all stands are as short as they will adjust).
Place Rhino ramp under rear wheel.
Name:  llkj 004cw.jpg
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #69 of 122 (permalink) Old 10-12-2014, 04:49 PM
XHILR8N!'s Avatar
Remove large jack.
Use small jack to raise enough to remove Rhinoramp. This is about as tall as it will go
Name:  llkj 005cw.jpg
Place the wooden piece on the large jack, position under rear wheel, and lift enough to remove small jack and place a stand.
2016 370Z Nismo
XHILR8N! is offline
post #70 of 122 (permalink) Old 10-12-2014, 04:52 PM
XHILR8N!'s Avatar
Remove large jack with wooden piece
Name:  llkj 009cw.jpg
Repeat on other side.
Name:  llkj 010crw.jpg
Name:  llkj 011cw.jpg
Proceed as you desire. She's all yours now!!!
roarf and Jer like this.
2016 370Z Nismo
XHILR8N! is offline
post #71 of 122 (permalink) Old 10-12-2014, 04:57 PM
XHILR8N!'s Avatar
With permission of the OP, might want Moderator to rename this thread something like "Placing Evora on jack stands" to make it easier to search.
I thought about doing a separate thread but there are several good solutions here, esp the one Julian uses.
2016 370Z Nismo
XHILR8N! is offline
post #72 of 122 (permalink) Old 01-20-2015, 07:09 PM
texevora is online now
post #73 of 122 (permalink) Old 01-21-2015, 06:45 AM
KCZ
KCZ's Avatar
Those look pretty tall even when they're lowered all the way down. I don't know if they'll fit under the Evora without placing shorter stands on the corners first then exchanging them out. The biggest problem with a lot of these methods is that they require jacking each corner multiple times to exchange out different size jacks, stands, boards, etc. then lowering each corner multiple times to remove the stuff again.
2011 Evora S 2+2 in Persian Blue with Oyster
2003 350Z, Track edition
2013 Boxster S 981
2014 Xterra, for 6 months of winter and mud season
KCZ is offline
post #74 of 122 (permalink) Old 01-21-2015, 07:17 PM
Illegal Alien
Julian73's Avatar
I'll stick with my method one lift up on each side, ending on 4 jackstands.
'17 Evora Sport 410 GP (No. 1 of 9) Lotus MS alloy pan, SSC harness bar
Julian73 is offline
post #75 of 122 (permalink) Old 03-18-2015, 04:05 AM
ramy w's Avatar
Has anyone tried these - considering getting a set for my Exige...
Tampa, FL
2008 Exige S240
2007 BMW 550i
2008 Elise SC - Sold
ramy w is offline
post #76 of 122 (permalink) Old 03-21-2015, 09:24 AM
squidward's Avatar
The big downside with those are they do not have rollers. So they're actually quite dangerous if you don't take the necessary precautions, when jacking up another point.
squidward is offline
post #77 of 122 (permalink) Old 03-21-2015, 11:26 AM
Nessal is offline
post #78 of 122 (permalink) Old 03-21-2015, 11:52 AM
Illegal Alien
Julian73's Avatar
Originally Posted by Nessal View Post
Not to be an ass, but jacking the Evora onto stands is not so simple.
Before I received my car I purchased 4 nice ESCO jackstands, with a stable tripod base and flat rubber tops, well recommended for the Elise, I was all set for maintenance, the day the car arrived, WRONG.
Spent more than my other 12 jackstands put together and almost worthless on the Evore, the lift points are one and the same as the only stand points, thus the significance of the thread. No it ain't rocket science, but then the solutions are not shop & beer talk either.
Solutions range from put car up up on ramps, wheel hub stands or the direction I went after my 1st misfire, then 2nd ramp pat, I now use 2 Jackpoint stands (http://www.jackpointjackstands.com/) at back lifting point and the ESCO's slide under the front points. Jackpoints are not cheap, but 2 will not break the bank and will guarantee a stable base, suspension free work space and no risk of chassis break.
Julian73 is offline
post #79 of 122 (permalink) Old 03-21-2015, 08:23 PM
I was looking at making something similar to these but with 4 castor wheels on the bottom of each hub stand. Anyone see a problem with lifting or moving around the car on this type of setup?
It would allow me to remove/store the wheels for winter and push the car into the corner of the garage out of the way. I don't think I could just put the car on the stands and have it far enough out of the way for peace of mind
ScarecroW is offline
post #80 of 122 (permalink) Old 03-22-2015, 02:29 AM
I tried putting wheel casters on Evora to move it and it was to hard to push .
No real place to grab it like Model A Truck that has real steel and not plastic on Evora that if you grab it and tug or push real hard would do some real damage to it.
The bolt on axle lift would not be good for front because you can not lock front wheels and if you put wheel on them and push your axle will turn with pushing pressure .
You could put bar from front to rear but seems like to much in the way to work on Evora..
Either lift or few heavy duty jacks to get it high enough for jack stands.
harleyujoe is offline
