Near complete gear slippage - LotusTalk - The Lotus Cars Community
 3Likes
post #1 of 25 (permalink) Old 07-25-2019, 08:31 PM Thread Starter
I was driving today and there was a burning plastic smell out of no where. No smoke, just a burning plastic smell. In addition, shifting was very hard as it would seem to slip out of gear around 3, 4th and 5th. I would already be in gear and it would rev, but move and still rev. It only has around 7k in miles.
Any ideas/
AdamsWorld is offline
post #2 of 25 (permalink) Old 07-25-2019, 09:22 PM
Bobsy Racer's Avatar
Any ideas/
What Year ?
Model ?
6 speed or IPS ?
Julian73 likes this.
Bobsy Racer is offline
post #3 of 25 (permalink) Old 07-25-2019, 09:25 PM Thread Starter
Originally Posted by Bobsy Racer View Post
What Year ?
Model ?
6 speed or IPS ?
2012 Evora S
six speed manual
Around 7k in miles.
post #4 of 25 (permalink) Old 07-25-2019, 09:59 PM
SOWEAK's Avatar
Seems a little early at 7k, but this was my same symptoms for a clutch master cylinder failure.
What Year ?
Model ?
6 speed or IPS ?
2012 Evora S
six speed manual
Around 7k in miles.
SOWEAK is offline
post #5 of 25 (permalink) Old 07-26-2019, 06:33 AM Thread Starter
Was it expensive to fix?
post #6 of 25 (permalink) Old 07-26-2019, 06:51 AM
I was quoted $1800 to $2000 at the shops near me to fix the master cylinder when the issue cropped up. I ended up spending the weekend doing it myself. $350 for the part and I outsourced the clutch bleed for $150. BOE has a good guide on their website if you want to undertake that. Make sure you buy an aftermarket cylinder from GRP or BOE since the OEM is highly prone to failure.
hdho1 is offline
post #7 of 25 (permalink) Old 07-26-2019, 07:11 AM Thread Starter
That's a bit over my pay grade. I called the service center in NJ, and they think it's the clutch and quoted 9k to replace the clutch. Anyone know of any other options in the NY/NJ area?
post #8 of 25 (permalink) Old 07-26-2019, 07:34 AM
I would absolutely start with the master cylinder first since its a common issue and will save you lots of money if that is what is indeed the problem. $9k does seem very pricey for a clutch change. I think the average is about $6-7k. Was it Lotus who quoted this amount?
Europa TC likes this.
hdho1 is offline
post #9 of 25 (permalink) Old 07-26-2019, 07:40 AM Thread Starter
It was RS Motorsports. Great work, but very expensive and he cannot see me for a few months as well. I am also wondering if the clutch work would be covered under Lotus due to the service bulletin released a few years ago (attached).
post #10 of 25 (permalink) Old 07-26-2019, 07:42 AM
Unfortunately, service bulletins aren't recalls or warranty extensions, so it's unlikely.
Your failure sounds more like the clutch to me personally than the MC. MC failures I would generally expect to go the "other way" - in that you can't disengage the clutch. It sounds like your clutch can't be engaged.
esseye is offline
post #11 of 25 (permalink) Old 07-26-2019, 08:27 AM
hdho 1 is spot on about changing the slave cylinder 1st. It's relatively inexpensive, that crappy slave cylinder has some plastic components that are subject to melting (ring a bell?), and it's going to need replacement soon anyway. My 2012 has a Wilwood unit that should last two lifetimes, but you need to adjust it for the cruise control to work. If it turns out you still need a new clutch, then you haven't lost anything by changing the slave cyl first.
Europa TC is offline
post #12 of 25 (permalink) Old 07-26-2019, 08:39 AM
Illegal Alien
Julian73's Avatar
Believe you are meaning the master .. ie the cylinder connected to the pedal
'17 Evora Sport 410 GP (No. 1 of 9) Lotus MS alloy pan, SSC harness bar
Julian73 is offline
post #13 of 25 (permalink) Old 07-26-2019, 09:40 AM
To the OP, are you saying that driving in a high gear, and your foot not on the clutch pedal, you can rev up the engine without increasing road speed?
West-of-Hethel is offline
post #14 of 25 (permalink) Old 07-26-2019, 10:04 AM
Parts Finder
Partsfinder's Avatar
Yes OP seems to say slipping while already in a gear. The only way this could be clutch master or slave cylinders would be if they are holding clutch particularly disengaged. Is that the issue with those of you that had a cylinder failure.
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
Partsfinder is offline
post #15 of 25 (permalink) Old 07-26-2019, 10:33 AM
Mobius97's Avatar
That's quite an expensive quote. Mine was repaired at my Lotus dealer under warranty but on the service order it was listed out $800 for parts and labor. Most will tell you it is a clam off job, it is not. Dropped the car off late in the day and picked it up early afternoon next day. If it ever fails again I will definitely be going aftermarket with BOE's or Gregs options.
I would get the car in and have them diagnose it. When my MC failed I did not have the typical symptoms of a MC failure (spongy clutch pedal or dropping to the floor) and I too thought it was the actual clutch going out. I had severe slippage and climbing rev's when accelerating, ya know typical clutch going out symptoms. As it turned out for me the MC was not relieving pressure and causing a cascade effect down the line.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #16 of 25 (permalink) Old 07-26-2019, 10:41 AM
glb
glb's Avatar
You withhold important info.
Where in NJ? N? S? What?
Yes, I know places.
glb is offline
post #17 of 25 (permalink) Old 07-26-2019, 01:34 PM Thread Starter
I am already in gear and driving and it just revs. My foot is not touching the clutch. I've been driving a manual for 20+ years, never destroyed a clutch. RS Motorsports serviced it not too long ago and all was good. So, no idea what's going on.
post #18 of 25 (permalink) Old 07-26-2019, 01:36 PM Thread Starter
Yes, I know places.
My apologies. Fort Lee, NJ area.
post #19 of 25 (permalink) Old 07-26-2019, 02:06 PM
Mobius97's Avatar
Read my post above. I had the exact symptoms and mine was the MC. Much easier and cheaper than a clutch job. I hope that is the case with yours as well.
Mobius97 is offline
post #20 of 25 (permalink) Old 07-26-2019, 07:35 PM Thread Starter
I hope so. I called two mechanic shops that I was referred to, no return calls yet.
Years ago, the master cylinder went in my Mustang. I was still able to drive, but the breaks were shot. I had to use my emergency break to stop. This is much different. However, that was an auto, not manual transmission. I do not recall a burning smell though. This was 20+ years ago.
