Service Bulletins - Page 2 - LotusTalk - The Lotus Cars Community
 2Likes
post #21 of 48 (permalink) Old 03-26-2014, 12:43 AM
Stilling doing God's work
comptalk's Avatar
Originally Posted by Cantdecide View Post
I dropped my car off at Manhattan Motorcars today. Towing into Manhattan from Jersey City was easier than I expected and the flatbed driver was great. I was able to get the clutch a bit of pressure after I pumped it 20 times or more, and was able to drive it out of the parking garage and up the bed of the tow truck.
I'm still waiting to hear the status from the dealer, but they confirmed there was a TSB for some clutch components and they said they might need to order some parts.
Car came back with other things wrong. It went back and forth four times, at least. Will never go back there again.
comptalk is offline
post #22 of 48 (permalink) Old 04-18-2014, 06:05 AM
Is there a list of all recalls/service bulletins available in one spot? Only found two in this sticky thread.
Thanks!
James
James33 is offline
post #23 of 48 (permalink) Old 08-28-2014, 08:29 PM
EFE EVS's Avatar
After pulling the bottom engine pan and preparing to change to a Speed Bleeder on the clutch actuator, I noticed that the recall and added dealer insulation to the fluid pipe is totally inadequate, they only insulate 5 inches of a 20 inch metal pipe, no wonder owners still had problems after the so called dealer fix. That whole pipe needs to be insulated being deep down in the engine compartment where there is a tremendous amount of heat being generated. Only covering 5 inches closest to the heat shield is not going to stop the rest of the exposed pipe from heating up, thus the reason the dealer fix didn't do the job, it's like putting a 1/2 inch band-aid on a 5 inch wound, utterly ridiculous!
So I searched and found some high heat insulation made by a company called Helix Racing Products. It is a self adhesive 1 1/2 inch wide aluminum backed high heat insulator tape (3ft long piece) that can be cut to the length of the entire pipe, folded around and glued to itself, I added some nylon zip straps to make sure it'll never come off. This insulator tape is made for this exact application, covering pipes or other things that are close to exhaust manifolds. Adding the insulation to the entire pipe and going to high temperature (600+ degree) synthetic racing fluid should eliminate the problem for good, I doubt you would even need to change the fluid again unless perhaps you're doing some heavy racing.
Installing the Speed Bleeder was fairly easy once you know how to position your arm and hand to get to the clutch slave. I'll try to post a couple of pictures before and after the insulation was installed.
EFE EVS
2012 Evora S (2+2 6sp. man)
EFE EVS is offline
post #24 of 48 (permalink) Old 09-19-2014, 10:07 AM
EFE EVS's Avatar
***IMPORTANT UPDATE***
I finally got around to changing to the Speedbleeders on my brake calipers. After removing the stock bleeders from one caliper, I proceeded to install the SB1010 Speedbleeders but the first thing I noticed was the hex head screwed all the way down and bottomed out onto the brake caliper, this is not right. I continued to hook up the pressure tank and started to bleed the first caliper. That pressure tank actually allows you to bleed your stock bleeders without the need for the Speedbleeders, you just open the stock bleeders and the brake fluid flows easily, a one man job. But since I already purchased the Speedbleeders I figured I'd just install them. After draining the dark fluid and seeing my more clear racing fluid flowing, I closed the Speedbleeder. Then I noticed the bleeder leaking a little around the hex head, so I proceeded to tighten a little more, realizing the hex head was already bottomed out against the caliper. Then I knew the SB1010 was also a little too short for the Evora calipers, these weren't the shorter SB1010S but the longer SB1010. I released the pressure on the brake system and removed the Speedbleeders to compare them to the stock bleeders, my suspicion was correct, the SB1010 is a little shorter than the stock bleeder from the tip to the hex head, about 3/32 of an inch. So I reinstalled my stock bleeders, pressurized the system and bled the system again.
I called Whitney at Speedbleeder and notified her of the problem, hoping she had a bleeder that was a little bit longer, she didn't. She is going to talk to the engineers and see if they can cut a little of the hex head down, if not, she'll have to give me a refund.
Bottom line, the SB1010 will work but is not long enough to give clearance between the bottom of the hex head and the caliper it screws into. Whitney agreed, there should be at least 1/16 to 3/32 of an inch clearance and the hex head on the bleeder should not touch the caliper when screwed all the way down.
If you are all using a pressure tank on the system and not having to pump the brake pedal, there really isn't any need to buy Speedbleeders in the first place, the pressure tank eliminates the need to pump the brake pedal. You simply hook up the pressure tank, pressurize the system to about 15 pounds and open the stock bleeders, it's that simple! It'll save you $60 by not needing the Speedbleeders which really do not fit properly.
EFE EVS
EFE EVS is offline
post #25 of 48 (permalink) Old 09-19-2014, 11:56 AM
EFE EVS's Avatar
Whitney at Speedbleeder just called and stated they are shaving the bottom of the hex head a little to make the SB1010 a little longer. They are sending me a new set of modified stainless steel bleeders that should work, I will install as soon as I receive them to make sure they work and confirm with them. Stay tuned!
EFE EVS
EFE EVS is offline
post #26 of 48 (permalink) Old 11-20-2014, 03:36 AM
Illegal Alien
Julian73's Avatar
Anyone know what TSB 2012/15 is ? It involves installation of a clip/spacer
'12 Evora S GP (No. 1 of 14) BOE Prototype S 430 **SOLD**
Julian73 is online now
post #27 of 48 (permalink) Old 11-20-2014, 05:05 AM
scv
Perhaps this helps?
2012 Lotus Evora (pws) Service Bulletin 341509
NHTSA: Action Number: 10047599 Service Bulletin Number: 341509
Report Date:
Oct 19, 2012
Component:
(pws)
Summary: Lotus: the retaining clip is retrofitted for rh cylinder bank variable valve timing (vvt) pipe to increase durability and to retain engine assembly. Models 2012-2013 evora s and s-ips. *pe
scv is offline
post #28 of 48 (permalink) Old 02-19-2015, 01:23 AM
EFE EVS's Avatar
Had to take my Evora to the dealer to have a new clutch master cylinder installed, the second unit replaced since the car was bought and only has 6500 miles on it. The dealer had changed the first one before the car even left the dealership. I changed to the racing fluid a few months ago thinking that would solve the problem but the clutch pedal started dropping again shortly after, even though I never race the car and drive it quite easy around town. I'm thinking the old fluid might have damaged the master cylinder seals before I changed to the new fluid. Within a few weeks of changing to the new fluid, the clutch pedal started dropping to the floor if I didn't drive the car for three or four days, I would have to pump the pedal a dozen times to get it to come back up. Then after a couple of months it started dropping to the floor every day after sitting overnight.
The new mc works great and when I change my engine oil from now on, I will probably bleed the clutch fluid at the same time, depending on how it looks. Since I found out the new clutch mc is plastic, that may be the reason why they won't take the heat from the hot fluid over time? I do believe the seals in the mc are probably getting damaged when the fluid boils and becomes corrosive. I hope Lotus gets smart and starts installing racing fluid from the factory. At least I have two more years of warranty in case another goes bad, I'm hoping they've improved the units.
EFE EVS is offline
post #29 of 48 (permalink) Old 03-16-2015, 02:13 PM
Bobsy Racer's Avatar
How have the Nylon Tie Wraps, holding the insulation on the clutch tube, held up to the heat ??
It seems like any heat that would boil 500 degree fluid, would destroy nylon tie wraps.
EFE EVS
Bobsy Racer is online now
post #30 of 48 (permalink) Old 03-17-2015, 10:48 AM
EFE EVS's Avatar
Not a problem so far. I think the heat may make them brittle but I don't think they melt. The insulation has self sticking adhesive on it but I'm not sure how well it would hold up if the tie wraps weren't around it. I'll give a report if the wraps don't hold up over time.
phenoyz likes this.
EFE EVS is offline
post #31 of 48 (permalink) Old 03-17-2015, 12:24 PM
F1 SML8R's Avatar
Same here Bobsy, I've had this type of wrap for over a couple of years now and I look under there every couple of months when I change the oil(yeah, I drive it a lot!). So far, it pretty much looks new.
F1 SML8R is online now
post #32 of 48 (permalink) Old 11-09-2015, 07:46 PM
Gunpilot's Avatar
This thread needs to be renamed "clutch line heat wrap".
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #33 of 48 (permalink) Old 03-03-2016, 02:09 PM
I own a 2014 Evora S manual transmission, I have done a few searches on LT and Google, but I have not found any service bulletins or recalls for the 2014. The manufacture date for my car is May 2013, do the 2013 service bulletins apply to my car? I just purchased my car and like most of us live far from the dealer, so I am trying to get all my ducks in row, so when I take my car in for it's first service, I can leave it, and try and get as much done as possible. As of right now the airbag light is on, the star shield is coming off in several places and the clutch- brake fluid is contaminated and needs changed, other than that she is lovely. Thanks in advance for your help.
carnut1 is offline
post #34 of 48 (permalink) Old 03-04-2016, 11:06 AM
EFE EVS's Avatar
Just make sure you purchase your own high temperature brake fluid and take it in with you when you have the car serviced, the dealer will only replace the fluid with the factory fluid and you'll have the same problem again. They also do not insulate but the last 5 inches of the clutch line as the factory suggest, so if you want the entire line insulated, you'll need to do it yourself or pay them when they change the fluid.
Once the fluid has been overheated and contaminated, there is a good chance it hurts the master clutch cylinder seals and eventually that's the reason why I believe I've had to have the master cylinder changed twice. Once out of warranty this can be an expensive repair.
EFE EVS is offline
post #35 of 48 (permalink) Old 03-04-2016, 11:35 AM
KCZ
KCZ's Avatar
FYI, here's the official NHTSA recall website. Keeping You Safe | Safercar | National Highway Traffic Safety Administration (NHTSA)
2011 Evora S 2+2 in Persian Blue with Oyster
2003 350Z, Track edition
2013 Boxster S 981
2014 Xterra, for 6 months of winter and mud season
KCZ is offline
post #36 of 48 (permalink) Old 03-04-2016, 05:27 PM
Thanks for the replies. I can insulate the clutch line myself. What I do not understand is how a car with only 200 miles on it has contaminated brake and clutch fluid unless it did track sessions. I assume that I do the service bulletin and recall look up as a 2014 then even though the car was manufactured in May of 2013.
carnut1 is offline
post #37 of 48 (permalink) Old 07-15-2016, 07:45 PM
EFE EVS's Avatar
Going on my third clutch master cylindar!
In the last couple of months, Prescott has had hotter than normal temperatures (90-99 degrees during the day) but nowhere near as hot as Phoenix (105-112). It's been a little over a year since the clutch master cylinder was replaced (2nd one) and I installed the high temp fluid thinking this would solve the problem in the future, NOT! I only have 12k miles on the car and drive it pretty easy, no tracking or racing. Now the clutch is starting to fail again just as the last one did, the pedal is falling to the floor after the car has been driven and parked overnight. As this earlier thread entails, I even insulated the entire fluid line in the engine compartment so as to protect it from the high heat the engine puts out. I'm convinced the master clutch cylinders being used in the Evora are not handling the amount of heat produced in hotter areas of the country. I was told the last mc installed was an updated version but here is just one year later and this one is failing. I wonder if they improved it on the 400? I hope so and if so, perhaps they can put a newer improved version in my car? I'm still under warranty but now I'm worried this will be an ongoing problem even after my warranty runs out? Not only is the clutch mc shot again, but my air conditioning just instantly went out last week, the little wrench icon came on and indicates there is an electrical problem. Then my fuel gauge went dead and stopped working but has since came back on. I've got 8 more months of the factory warranty and if these all happened after the warranty ran out, this would be major expenses for a car with only 12k miles. I've loved the car but now am totally gun shy that the clutch mc will go out again after the warranty runs out. Has anybody else discovered a permanent fix for this problem?
EFE EVS is offline
post #38 of 48 (permalink) Old 07-15-2016, 08:17 PM
agentdr8's Avatar
I'm pretty sure no one has had a Wilwood m/c failure, so if/when my stock one ever gives up the ghost, that's what I'm installing.
agentdr8 is offline
post #39 of 48 (permalink) Old 07-15-2016, 08:50 PM
EFE EVS's Avatar
Thanks agentdr8!
EFE EVS is offline
post #40 of 48 (permalink) Old 07-17-2016, 10:03 PM
geez dude I feel for you. please let me know if you figure out the cause of the wrench icon (and how lotus scans for it). I have one come on every now and again and it affects my start up...sometimes I have to turn the key a few times to get the started to fire.
2011 Lotus Evora NA 6spd. White with red/black interior
Conan O'Brien is offline
