Stuck lug nuts? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 07-14-2019, 11:27 AM Thread Starter
MGB
Stuck lug nuts?
Am I just crazy? I'm using an impact wrench capable of doing 800 ft. lb, and using the star lug nut adapter that came with my car (17mm to the star pattern), but I can't get the damn lug nuts to loosen. Only one will come out on the first wheel I tried, front RH. Did some monkey at a garage torque the **** out of my lug nuts and now I have to take it to a garage?
MGB is offline
post #2 of 8 (permalink) Old 07-14-2019, 11:36 AM
Probably. Have you oiled your impact? Car is on the ground?
esseye is online now
post #3 of 8 (permalink) Old 07-14-2019, 12:22 PM Thread Starter
MGB
Brand new impact, car on the ground. I used my breaker bar again and a new 17mm socket, which was shorter and easier to line up properly. Stomping on the breaker bar *finally* broke the nuts loose! It's insane how tight they were, and only let go with a massive metal creak. The other wheel was at normal tightness.
I think someone at a garage got over-eager at some point.
MGB is offline
post #4 of 8 (permalink) Old 07-14-2019, 12:24 PM
glb
glb's Avatar
Is air hose kinked?
Compressors often have 2 pressure dials:
First for overall psi
2nd for output (ensure this is not turned down)
And, as my friend esseye asked, is gun oiled properly???
glb is offline
post #5 of 8 (permalink) Old 07-14-2019, 12:26 PM
CRG53's Avatar
You should be able to break those loose with a regular cheater bar, definitely does not need a 800 lbs/ft impact. Stupid question, are you sure you are turning the lugs the right way??
As mentioned, oil the impact. How big a supply air line do you have. An impact of that size needs a lot of air to work properly.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is online now
post #6 of 8 (permalink) Old 07-14-2019, 12:32 PM
If it's a brand new impact (pneumatic, air tool) you definitely need to oil it. Without the oil the vanes won't seal, and they are very weak (you'll be stronger with a breaker bar by hand). Oil it up with a good 10-15 drops of oil and try again @90psi.
post #7 of 8 (permalink) Old 07-14-2019, 03:38 PM
glb
glb's Avatar
There is oil made for this, but I've no idea how it differs from any other oil.
glb is offline
post #8 of 8 (permalink) Old 07-14-2019, 03:44 PM
It's thin stuff, and it's cheap enough you may as well use it.
https://smile.amazon.com/Lucas-Oil-P...gateway&sr=8-3
