Would Pulling the Exhaust Valve Fuse Leave it Permanently in "Loud" Mode? - LotusTalk - The Lotus Cars Community
post #1 of 11 (permalink) Old 09-13-2019, 02:29 PM Thread Starter
I've heard of this being done on Aston Martin Vantage's, where you can pull a fuse and leave it permanently on loud mode.
The first thing I do every time I get in the car is press the exhaust or sport button anyways.
I was wondering if this would work on our cars (400's) if you turn the car on, press the exhaust button to open the valve, then pull the fuse out. Do you think this would leave it permanently in the open exhaust mode?
zthang is offline
post #2 of 11 (permalink) Old 09-13-2019, 04:01 PM
Happy To Be Here
ShadowWulf369's Avatar
I don’t know how the 400 works, but I believe I know how the S1 Evoras work. The S1 muffler system has a valve that is open when in the muffled mode and then closes when in loud mode. On my Larini exhaust it is much more obvious as the bypass “loud” pipe is outside of the muffler. When the car starts, there is no vacuum so the valve is spring loaded to be in the shut position, leaving the car in “loud” mode, then it will open moments after ignition. When open, some exhaust will pass through the muffler and less through the straight pipe, causing the car to be quieter. When the sport button is pressed, the vacuum turns off and the valve closes, causing all exhaust to go through the straight pipe which has less back pressure and no further restrictions. When the car is turned off, the valve has a spring that will return it to the closed position.
TL-DR - the car starts in “loud” mode and if the vacuum line to the valve were simply disconnected and plugged (with something like a golf tee), you will always be in loud mode.
This is how I believe the system works, and if I’m wrong, I would love to be corrected.
2013 Evora IPS - Carbon Gray
2016 BMW 328xi - Estoril Blue
ShadowWulf369 is offline
post #3 of 11 (permalink) Old 09-13-2019, 04:27 PM
brgelise's Avatar
They usually operate by vacuum. Whenoff they are open, when started that is why they are loud till vacuum builds to close valve. Do yourself a favor and get rid of that obese stock exhaust if you want sound. There are much better ways to enjoy the noise , be lighter, handle better etc. All you had to do on an S1 was cut the hose and , volia, valve always open if i remember right.
brgelise is offline
post #4 of 11 (permalink) Old 09-17-2019, 04:10 AM
tye-bo's Avatar
I actually built my own valved exhaust to get rid of the 40+lb monster. @brgelise is correct, when the car is off there is no vacuum applied, so the valve is open. You could unplug the connector to the vacuum switching valve on the side of the airbox, which would keep it permanently off and you don't have to go under the car. (I'm all for the laziest approach ) While testing my exhaust I ran a golf tee in the vacuum line, since I was already under the car, and that resulted in no degradation to the performance.:
Current:
2018 Evora 400 Metallic Black Manual
1998 Volvo V90 silver L59/4L60 swapped
1970 Honda CT70 Red
Sold:
2017 Audi R8 Silver V10/DCT
2010 Evora Carbon Grey Manual
12 others...
tye-bo is offline
post #5 of 11 (permalink) Old 09-17-2019, 04:24 AM
brgelise's Avatar
Golf tee is indeed a way to go.
brgelise is offline
post #6 of 11 (permalink) Old 09-17-2019, 08:52 AM Thread Starter
Golf tee...genius would never have thought of that.
You wouldn't happen to have a picture of where it's located on the side of the airbox would you?
zthang is offline
post #7 of 11 (permalink) Old 09-17-2019, 08:56 AM
brgelise's Avatar
orange/red hose
brgelise is offline
post #8 of 11 (permalink) Old 09-17-2019, 11:09 AM
tye-bo's Avatar
If you block the orangish hose on the side of the airbox at the airbox, you'll have a vacuum leak when the ECM is trying to keep the valve closed.
The golf tee trick should be done either at the valve itself or where the orangish line meets the hard line mounted to the body. If you don't want to crawl around on the ground just unplug the VSV on the side of the box and it will hang the valve open with no detriment.
Current:
1970 Honda CT70 Red
Sold:
12 others...
tye-bo is offline
post #9 of 11 (permalink) Old 09-17-2019, 11:41 AM
Dylan is offline
post #10 of 11 (permalink) Old 09-17-2019, 02:36 PM
Illegal Alien
Julian73's Avatar
if you pull the hose off the muffler valve, the hose must then be plugged. Pipe at muffler valve is left open to atmosphere, however hose feeds back to engine and will be a vacuum leak if not pulled.
'17 Evora Sport 410 GP (No. 1 of 9) Lotus MS alloy pan, SSC harness bar
Julian73 is offline
post #11 of 11 (permalink) Old 09-18-2019, 03:48 AM
tye-bo's Avatar
Ah, I see where my advice could be misconstrued. Plug the orangish line in the engine bay, where it meets the hard line or where the orangish line goes into the valve.
Current:
1970 Honda CT70 Red
Sold:
12 others...
tye-bo is offline
