SSC ECU - looking for basemap for forged engine CR 9.0:1 - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 09-19-2019, 11:38 PM Thread Starter
frenchy's Avatar
hello
last year i fitted the SSC TVS1320 kit and ECU to my Exige S240 , the car ran fine for several thousands kilometers
back in may, i noticed i lost compression in 1 cylinder, it was to forge the engine
i installed new Mahle pistons changing the CR from stock 11.5:1 to 9.0:1
i'm now looking for a basemap for an engine with this CR 9.0:1, because with my actual map i can't start it, i fouled the engine and wet the spark plugs
i managed to start it once, the car ran fine for 20min,* and i stopped it to check the oil and water levels.
but i can't start it anymore
can someone with an engine CR 9.0 share his map?
SSC PnP ECU using WARI
injectors 720cc
so i can at least start the car and may be do the break in of the engine
thanks
frenchy is offline
post #2 of 4 (permalink) Old 09-20-2019, 04:55 AM
Rizzydee's Avatar
Try emailing SSC 1st, Adaptronics 2nd, and Monkey Wrench Racing 3rd. When I was tuning my SSC I reached out to SSC for a base map. They sent me the closet they had to my build. I did the same for Adaptronics and MWR. Free of charge. That said, you're going to have to get it on a Dyno and I'd have a professional tune it off the map you get.
Rizzydee is offline
post #3 of 4 (permalink) Old 09-21-2019, 12:00 AM Thread Starter
frenchy's Avatar
hi rizzydee
i got already in touch with SSC, they should provide me a basemap next week , but already told me they never worked on a 2ZZ with CR 9.0, only 1ZZ
i have access to a dyno with lambda measurements and i should have a tuner for the fine tune
frenchy is offline
post #4 of 4 (permalink) Old 09-30-2019, 09:20 AM Thread Starter
frenchy's Avatar
hello
the basemap is not the problem at this point
i have an issue with the VVT
topic to follow up
https://www.lotustalk.com/forums/f15...4/#post5983202
frenchy is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Engine Control (ECU)
