NEW Product: RADIUM Engineering Evora Fuel Rail Kit - LotusTalk - The Lotus Cars Community
post #1 of 1 (permalink) Old 11-02-2011, 09:11 AM Thread Starter
Elise Driver
Radium's Avatar
This twin RADIUM high volume fuel rail kit features two 0.7" inner bore rails to support equal fuel distribution and injector flow capable of well over 1,000 horsepower. This large internal area also serves to dampen the fuel injector pulses preventing fuel pressure fluctuation. All ends of the rail are tapped to a common 3/4-16 (-8AN) thread. Using the appropriate fitting, it is easy adapt to a -6AN, -8AN, -10AN or -12AN fuel lines (-6AN adapter included). The capped end port can be used as a feed inlet, return outlet, sensor or gauge port, etc. All ports use positive o-ring seals instead of tapered pipe threads which commonly damage aluminum threads and lead to fuel leaks. With all of these ports it is very easy to adapt the Toyota/Lotus fuel system into a traditional rising rate fuel pressure regulated return system using a Radium Engineering fuel pressure regulator. This fuel rail kit also makes it easy to install a Radium Engineering fuel surge tank if the vehicle is tracked regularly. Compatible with both Evora and Evora-S
More Info HERE
Radium is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
