Nifty new engine lid contraption: The LIDbone - Page 6 - LotusTalk - The Lotus Cars Community
post #101 of 175 (permalink) Old 05-08-2006, 09:01 AM
mdotpoker's Avatar
initial building of lidbone
i noticed that the nuts don't screw on my hand when putting the lid bone together, has this happened to anyone else
___________________
M. (pronounced M dot)
2003 Mercedes SL 55 AMG
2005 Lotus Elise (R.I.P)
2002 Yamaha R6
2001 Acura CL Type S
mdotpoker is offline
post #102 of 175 (permalink) Old 05-08-2006, 03:57 PM
saudio's Avatar
On order. Nobody has mentioned how much easier it will be to stow the roof in a hurry with this gadget.
Well done!
saudio is offline
post #103 of 175 (permalink) Old 05-08-2006, 04:37 PM
JnC
JnC's Avatar
The nuts are 6mm locknuts and can't be tightened by hand. Use a 10mm socket.
2007 Cross Country Travelblog
11 Lotus Elise Final Edition :: Chrome Orange
16 Honda CR-Z EX
76 Porsche 912E
95 Porsche 911
JnC is offline
post #104 of 175 (permalink) Old 05-08-2006, 09:42 PM
srwhitman's Avatar
I installed mine over the weekend. I have to say, the picture perspective made it a little difficult for me to get it right first. In fact, I had the second "piece" up on the left side instead of the right and I also put the nuts facing the wrong way. It still worked but one end of the nut did scrape a little paint when I closed it the first time. I fixed it by removing the nuts and re-attaching while the lidbone was on the car (I just used my head as a prop). Really had to make sure not to loose any of the little washers or nuts/bolts. Ok, it works great like everyone says.
But, here's my catch. I now have driven with it a couple times and when I come to idle and then stop, I do notice a rattle. I have each of the lock nuts loose enough and not tight. Thats kind of how they said to do it. There is a tiny bit of play - not really something you can see much of. I tried to make it so that it would play without tightening too much. When I tighteneed it too much, it didn't move much so I didn't think that was a good idea. Well, now I don't know what is causing the rattle. I suspect it is the back part resting on the engine. It seems like it is not "off" the engine but resting on it when the lid is closed. Any ideas how to fix? I don't think I have any other part upside down (otherwise it wouldn't work).
The other, more general question - is this thing going to need to be removed for engine work?
srwhitman is offline
post #105 of 175 (permalink) Old 05-09-2006, 06:06 AM
mdotpoker's Avatar
Installed last night
I never worked with self locking nuts before. The Lid bone is sweet and really puts a nice touch to the car
___________________
2002 Yamaha R6
post #106 of 175 (permalink) Old 05-09-2006, 07:14 AM
insert clever title here
MattG's Avatar
I don't have one yet so can't comment for sure on where it's rattling, but you could try installing a spring washer at each joint. From the pics that shaggy posted, I'm not seeing anything like that in the design. I'm not sure what would work best in this case, but I'd start by looking at belleville washers and wave washers, though if all else fails a simple split lock washer might do. You'd be looking for something that will keep a force applied to the joints, while still allowing them to rotate.
Just a theory at this point...as I mentioned, I don't have one myself yet!
'05 Elise, Magnetic Blue / Biscuit / Hardtop
MattG is offline
post #107 of 175 (permalink) Old 05-09-2006, 07:43 AM Thread Starter
Modern Wedgie's Avatar
I honestly don't know what the rattle could be coming from either, since every version that we tested, including the final version, do not seem to rattle. Or if it does, the rattling sound is dulled by all the other rattling sounds in my car.
The LIDbone should NOT be resting on the engine. There should be atleast a cm of clearance between the two.
I would again just check to make sure it is installed properly. I was hoping the drawings would help the install...if anyone is having troubles please let me know so I can modify the installation instructions.
Long live the
Modern Wedgie is offline
post #108 of 175 (permalink) Old 05-09-2006, 07:59 AM
Forum Founder
Randy Chase's Avatar
As Matt said, the normal method for not having things rattly loose and still allow sliding rotation, is to use a wave washer. I have not seen the lidbone yet, so I can't comment otherwise. If I was having a rattle, I would put a video camera inside the compartment and drive.
#somethingwickedthiswaycomes... the new Origin Noble M and the Origin 7
Zenos E10S for Sale! www.zenosforsale.com
There are some very shady dealers in the Lotus business.
2005 Lotus Elise, 1993 MR2, 1995 MR2, 125cc Shifter Kart, Toniq (in build), 2018 Origin 7 (waiting), 2018 Origin Noble M (waiting)
Randy Chase is offline
post #109 of 175 (permalink) Old 05-09-2006, 08:24 AM
Shaggy's Avatar
I actually just noticed this on Sunday, meant to email but forgot about it. Theres a gray mark on the plastic piece (that says "Lotus") on top of the valve cover, it looks like its from the top section of the lidbone just barely resting on it. I'm not too worried about it though, I'll have that piece painted before too long and afterwards I can just run a small slip of foam up that edge of the support.
I'll try and grab a photo later tonight to better illustrate what I'm talking about.
2005 KG Lotus Elise (Gone )
Sector111 Lidbone || Sector111 Front towhook || Sector111 Rear Boomerang towhook || Alpine CDA-9856 & iPod || 111R Decals || Zoom Carbon Fiber Rearview Mirror || Green Filter & de-snorkel || ForcedFed Half Carbon Front Lip Spoiler || ChaseCam window mount
2001 Laguna Seca Blue BMW M3 (the replacement)
Shaggy is offline
post #110 of 175 (permalink) Old 05-09-2006, 02:00 PM
srwhitman's Avatar
I'm pretty sure the rattle isn't from the nuts and washers but from the device hitting the engine. I don't have a video camera small enough to fit in the engine. I suppose I could put a still camera in there with a timer and delay and close the engine.
I do have to say though that this thing is worth getting. I didn't get the bootie as I just leave a bag in the trunk to hold things that might move around but next to that, the LidBone and a drink holder seem like virtual necessities (for us lazy Americans!).
Scott
post #111 of 175 (permalink) Old 05-09-2006, 02:22 PM
Forum Founder
You can see it thru the vents with the engine lid closed. It looks like it was designed to contact the plastic cover (see the angled flat section that contacts?).
A bit of foam tape would solve this.
post #112 of 175 (permalink) Old 05-09-2006, 03:01 PM Thread Starter
It does'nt touch on my car Darn Lotus variability.
Long live the
post #113 of 175 (permalink) Old 05-09-2006, 03:16 PM
MickOpalak's Avatar
It touches on my car and is rubbing a little paint away.
Another issue with the Lidbone: its right above a very hot engine. After a spirited drive don't attempt to touch it.
2007 Exige S - Krypton Green - VF Stage 2 - RLS Intercooler - Volk TE37s - B&M Shifter - 2bular header & exhaust - Sector111 motorsport engine mounts - stripes - harnesses - Pagid pads - Green air filter
MickOpalak is offline
post #114 of 175 (permalink) Old 05-09-2006, 04:09 PM
MattG's Avatar
Good point, but being aluminum, it should cool off pretty quickly, right? If the engine cover is open, at least?
MattG is offline
post #115 of 175 (permalink) Old 05-09-2006, 04:26 PM
Yet another lidbone install!
I figured I'd post a picture of the lidbone installed in my Elise. It was incredibly easy to install.
<BR>
<img src="http://gambit.dyndns.org/lidbone.jpg">
Kagetsume is offline
post #116 of 175 (permalink) Old 05-09-2006, 04:40 PM
Forum Founder
Lillie, we need a boneSTICK to push it.
Seriously... always carry a towel.
Edit to add, I just got back in from a spirited drive so went out and tested it. Yes, it is pretty hot. But the thermal mass of the alum is pretty low so it was not a big deal to nudge it for closing. On the other hand, it acted differently when opening. It would not open correctly without some help, getting past that last little bit. I think the thermal expansion affected it. I guess I could loosen the nuts, but I think I will go in a different direction for other reasons. I am going to put some high-temp teflon washers in the assembly for lubrication and wear points.
post #117 of 175 (permalink) Old 05-09-2006, 06:02 PM
Shaggy's Avatar
Which side were you lifting the cover on? With my car it won't lock into place easily at all if my hand is holding the right side of the cover, but if I hold the left it works perfectly.
er, Or was it just not wanting to move as easily?
Shaggy is offline
post #118 of 175 (permalink) Old 05-09-2006, 06:06 PM
Green Hornet's Avatar
Cool It Works ust Fine
I installed mine last weekend. Easy - It's a slick addition to the car.
Life, Liberty and the Happiness of Pursuit
I can help you move TO anywhere in the USA FROM anywhere in the USA - ask me how...
Green Hornet is offline
post #119 of 175 (permalink) Old 05-09-2006, 06:13 PM
choi0706's Avatar
I polished mine.. the joints move nice and smoothly
Jay-05' ST, HT, Touring Red
choi0706 is offline
post #120 of 175 (permalink) Old 05-09-2006, 08:52 PM
Forum Founder
Not sure what is going on. When I raise the lid, the bracket just stops in a mostly vertical position, it does not "fall" into the locked position. Does not matter where I raise it. I tried loosening up the fasteners, but it did not help. I will take another look at in the daylight tomorrow.
  LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
