Nifty new engine lid contraption: The LIDbone - Page 9 - LotusTalk - The Lotus Cars Community
post #161 of 175 (permalink) Old 05-24-2006, 12:04 PM
m3m750's Avatar
Originally Posted by Shaggy
I ended up wrapping some electrical tape around points of contact (when lid is closed) and playing with the adjustments to try and cease the rattling but it hasn't cured it (although its slightly muffled). It sucks because it only rattles at idle, at least as far as I can tell, but that gets annoying as hell when the cars warming up in the morning or your sitting at a long stop light.
Any ideas?
Stage II
Ways to get to the office:
2005 Elise, AS, Stage II, Fujita intake, better speakers
2005 Acura MDX
2012 MB CLS550
2001 Ducati Monster 750
2003 Porsche 996tt
m3m750 is offline
post #162 of 175 (permalink) Old 05-24-2006, 12:07 PM
m3m750's Avatar
definitely don't overtighten the bolts. Got back from WCLM on Sunday and opened the lid to get stuff out, but the heat from the 5 hours drive caused expansion that made the joints to sticky, and heated the aluminum enough to where it bent when I tried to open the lid. Got the piece straighted and loosened the bolts a bit more and now all is well, though admittedly I haven't tested it yet with another 5 hour drive.
2005 Acura MDX
2012 MB CLS550
2003 Porsche 996tt
m3m750 is offline
post #163 of 175 (permalink) Old 05-24-2006, 04:44 PM
ZTEC's Avatar
Got mine today and installed it, Nice product but took the time to sand down the sharp edges from the product being stamped out - Also, just by looking at the design I knew it needed some nylon washers between the metal - to -Metal pivot points (3) so I cut three out of some larger washers I had laying around using the supplied larger metal washers as a template for the nylon washers then just added a little lock-tite and viola it works perfectly,
I like it but highly recommend the the nylon washer routine!
NZ
Oh yeah, no rattle with the nylon washers
ZTEC is offline
post #164 of 175 (permalink) Old 05-26-2006, 04:26 PM
babak's Avatar
Thumbs up
Ding on a great product and +1 on the sanding and the rubber gromets between the metal at the pivot point. You have to play a bit with the loose/tight of the nuts at to get it to work properly.
Babak
Club111 Central Plains Coordinator
'05 Elise - Touring, HT, StarShield
'99 Ducati 996 Bip
'05 Freelander SE
babak is offline
post #165 of 175 (permalink) Old 05-26-2006, 04:56 PM
Buz
Any chance on getting them clear anodized for durability and a lasting finish?
Buz is offline
post #166 of 175 (permalink) Old 07-15-2006, 06:41 PM
BTW, if you're looking for nylon washers in Home Depot and can't find any in hardware, go over to electrical and get a 4-pack of Gardner Bender (GB) 1-inch white plastic clamps.
The long flat end of the clamp can easily be trimmed into a makeshift washer. The hole is already the right size for the LIDbone bolts.
And as others have mentioned the edges on the LIDbone parts are a bit sharp, so some sort of deburring tool (sandpaper, metal file, etc) will be useful.
dododge is offline
post #167 of 175 (permalink) Old 07-31-2006, 04:28 AM
Trickster's Avatar
I had to go this route for mine (uk s1)
Trickster is offline
post #168 of 175 (permalink) Old 08-23-2006, 07:32 AM
Guest
LotusDeux's Avatar
thanks sector, love this thing
LotusDeux is offline
post #169 of 175 (permalink) Old 08-23-2006, 08:15 AM
ZakSkiGuy's Avatar
Talking
Right on, add me to yoru interested list, please!!!
ZakSkiGuy is offline
post #170 of 175 (permalink) Old 11-09-2014, 01:10 PM
Is this still being sold, or is there similar/different/better product available now?
EZ PZ is offline
post #171 of 175 (permalink) Old 11-09-2014, 03:03 PM
Tire abuser
jefrac's Avatar
I have the Lidbone (I believe it is still sold). It's "OK". I had to modify mine so it would not score the top of the coil pack cover. I have also added teflon washers so it does not rattle.
If I were doing it now... would probably try this item: GRP Trunk Support - Elise ? On Rails Engineering
I have not seen a review of it though....
'06 Arctic Silver Elise | Touring |Traction Control |Supercharged | ST exhaust | Nitron singles | BWR anti-sway bar | RTD brace | V2 Arms | SS brake lines | Harness bar and Schroth harnesses | sys.6.pack |shifter reinforced | Ultralite lines | cup air box | Sport inserts | DBW Pedals | TALLrails | Team Dynamics 1.2's | TOC Oil Pan | ProRad | FW Torque tune | BOE surge tank and catch can | Radium Clam Kit
jefrac is offline
post #172 of 175 (permalink) Old 11-09-2014, 03:09 PM
Probably Lurking
Keeper's Avatar
LIDbone Deck Lid Prop for the Lotus Elise and Exige - Sector111
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #173 of 175 (permalink) Old 11-09-2014, 03:14 PM
I Have Commitment Issues
Lowtush's Avatar
We have sold a bunch of these and run these in all of our cars. They make things so much more convenient.
Lowtush is offline
post #174 of 175 (permalink) Old 11-10-2014, 06:48 PM
Joshrose's Avatar
I bought the GRP hydraulic trunk support and I HIGHLY recommend it! It's easy to install, looks great, and works just like it should. I can easily open my trunk one handed (while carrying something to put in the truck in my other hand). It lifts higher then the original trunk support, but protects the roll bar from getting hit from lifting the trunk lid too high. THIS IS A MUST HAVE ITEM, along with a sector 111 bootie! 2 items that should have come stock from the factory and don't really add much weight.
2008 Lotus Elise California Edition - Red
2009 Land Rover LR2 - Black
2011 Volvo XC90 - Charcoal
2000 Toyota MR2 Spyder - Red (sold)
Joshrose is offline
post #175 of 175 (permalink) Old 11-14-2014, 09:24 PM
Saffron Yellow is Lighter
XtinctElise's Avatar
I absolutely agree the strut works perfectly and there's no more leaning over the edge to lock or unlock the lidBone.
XtinctElise is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
