Really Light Stuff - Supercharger Pulley Mk II - Page 5 - LotusTalk - The Lotus Cars Community
post #81 of 125 (permalink) Old 09-24-2010, 08:48 PM Thread Starter
The RLS Mk II pulley is now available in 3.1", 3.0", and 2.9" sizes.
The new owner of RLS is Austin, you can contact him at: Austin0Barrett <<<< @ >>>> gmail <<<< dot >>>> com
Thomasio is offline
post #82 of 125 (permalink) Old 10-22-2010, 04:17 AM
HKFEVER's Avatar
How to remove the pulley if you don't have pulley puller?
What is the torque spec. for the pulley nut?
S240 Exige S with BOE FW300 + over 40 mods
HKFEVER is offline
post #83 of 125 (permalink) Old 10-22-2010, 07:40 AM
robains's Avatar
Get a puller $30 new -- most any Auto Parts store will rent them out for a day or two or three. You can try to pry it off, but then you could damage the shaft and most certainly will damage the pulley.
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
robains is offline
post #84 of 125 (permalink) Old 10-22-2010, 07:47 AM
HKFEVER's Avatar
I asked dealer how to do it? Dealer called UK, and UK told them to take off the supercharger then use the factory pulley puller. There is not enough space to place the factory pulley puller.
Can anyone post the picture of the pulley puller that you use? So I can show it to the dealer
HKFEVER is offline
post #85 of 125 (permalink) Old 10-22-2010, 07:52 AM Thread Starter
Remove the supercharger?! LOL! What kind of "medicine" are they smoking?
There are low profile pullers... that's the easiest.
I've removed stock pulleys many times without a puller, but you need to take your time. I used a plastic mallet to tap back and forth from the back side of the pulley until it lets loose. Don't hit it too hard you could damage the shaft or bearings of the supercharger. Best bet is to find a low profile puller.
Thomasio is offline
post #86 of 125 (permalink) Old 10-22-2010, 07:57 AM
HKFEVER's Avatar
Hong Kong is a hardware desert, can anyone post the low profile puller picture?
HKFEVER is offline
post #87 of 125 (permalink) Old 10-22-2010, 07:59 AM Thread Starter
THAT is an understatement!! I was there for a big installation on a client's Exige S, and took 1/2 a day to find a BSP tap in Hong Kong!
You should contact Tony Woo, I'm sure he can assist.
Thomasio is offline
post #88 of 125 (permalink) Old 10-22-2010, 08:01 AM Thread Starter
This might do it:
Low Profile Pulley Puller OTC4544 -
Thomasio is offline
post #89 of 125 (permalink) Old 10-22-2010, 08:07 AM
HKFEVER's Avatar
As far as I know, Dealer has damaged at least 2 pulley previously. And they don't have the right size puller. So, if I can get one, I will simply give them for good. Tony, you need to wait couple weeks.
HKFEVER is offline
post #90 of 125 (permalink) Old 10-22-2010, 08:21 AM Thread Starter
Who cares about damaging the OEM pulley... it is the SUPERCHARGER that you don't want to damage! Let me know if you would like me to purchase that tool and send to you.
Thomasio is offline
post #91 of 125 (permalink) Old 10-22-2010, 08:32 AM
robains's Avatar
Absolutely NO need to remove the SC. Go in thru the wheel well (RH side), removing the plastic liner, remove belt. Note: pending on how much of size change you go with in the pulley you might need a smaller/shorter belt -- it's a tight fit but this puller works (3 set for $27):
robains is offline
post #92 of 125 (permalink) Old 10-22-2010, 08:35 AM
HKFEVER's Avatar
Dealer mentioned there is not enough space to place regular puller. That's why I am searching for solutions
HKFEVER is offline
post #93 of 125 (permalink) Old 10-22-2010, 08:57 AM
robains's Avatar
There is space, I've done this about 10 times. Dealer is on crack , probably the same dealer that quotes 32 hours to remove front clam when it only takes <2 hours.
robains is offline
post #94 of 125 (permalink) Old 10-25-2010, 02:19 AM
HKFEVER's Avatar
Trust me, Hong Kong don't have good nor well trainned mechanic. If I have space and tools in HK like I have in Vancouver, I will do all the mods that I did in HK in my own home may take longer time, but sure I can do it right.
I have to teach dealer to install the shift cable, teach a shop to install quick shifter, teach another shop to install the oil cooler & O2 sensor, teach a audio shop to re-wire the cables, teach a body shop to mix the paint
But they are so call Lotus specialist in HK
And the so call Lotus specialist that always track in so many different evens, they don't do aligment and corner weight in shop
HKFEVER is offline
post #95 of 125 (permalink) Old 10-25-2010, 08:40 AM
Ali.M's Avatar
Move out of HK!
Reduce Weight // Improve Reliability http://www.ChimeraBatteries.com
2007 Lotus Exige S // 2009 Ferrari 430 Scuderia 16M // 2012 Chrysler 300C
2005 Maserati Gransport SOLD // 2006 Chrysler 300C R.I.P.
Ali.M is offline
post #96 of 125 (permalink) Old 10-25-2010, 09:29 AM
shay2nak
shay2nak's Avatar
haha!
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #97 of 125 (permalink) Old 10-25-2010, 06:44 PM
HKFEVER's Avatar
Shop's in HK only do installation. I mean put mods on the car, but not follow the spec. A shop striped the thread of a big bolt that hold the rear diffuser, as they used different bolt size. Then another shop did the same thing . That shop changed all my stainless steel bolt with steel bolt at the rear bottom panel + diffuser , and told me that the stock bolts are steel.
I personally changed to stainless steel bolts by myself because the noise from loose bolts long long time ago.
HKFEVER is offline
post #98 of 125 (permalink) Old 10-25-2010, 09:16 PM
Ali.M's Avatar
Move to LA
Ali.M is offline
post #99 of 125 (permalink) Old 10-25-2010, 11:20 PM
HKFEVER's Avatar
Originally Posted by Ali.Maadelat View Post
Move to LA
But I only pay max 16.5% income tax here.
HKFEVER is offline
post #100 of 125 (permalink) Old 10-26-2010, 06:05 AM
Ali.M's Avatar
Move to LA and get a good tax attorney!
Ali.M is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
