Vision Function ECU Reflash (Gotham Technology) - Page 4 - LotusTalk - The Lotus Cars Community
post #61 of 84 (permalink) Old 05-02-2012, 05:12 PM Thread Starter
Crazy Car Guy
Originally Posted by czero View Post
Well a perfectly stock N/A Elise before and after would be neat.
If I decide to decat the car I am guessing I will need a retune.
I would also have an exhaust at the same time so how would I order that on the website?
Stock with Intake vs Intake & Flash
www.VisionFunction.com - Site Under Construnction - Stay Tuned
post #62 of 84 (permalink) Old 06-22-2012, 06:59 AM Thread Starter
Crazy Car Guy
PM's replied Happy Friday!
post #63 of 84 (permalink) Old 06-28-2012, 07:20 AM
Nex
PM'd
Nex is offline
post #64 of 84 (permalink) Old 07-02-2012, 06:03 AM Thread Starter
Crazy Car Guy
Pm's replied!
post #65 of 84 (permalink) Old 07-02-2012, 06:33 AM
So if I'm reading this correctly, the combination of a new intake plus the reflash is about a 10% increase in torque from about 2700 to about 6500 rpm for a NA car. What should be expected in terms of CEL's, idle, etc., assuming a 2009?
Dylan is offline
post #66 of 84 (permalink) Old 07-02-2012, 06:58 AM Thread Starter
Crazy Car Guy
On this particular car that is what we did see. Car was a 2005. You shouldn't have any CEL's or idle quality changes. Although I haven't applied this map to a 2009 rom of yet.
post #67 of 84 (permalink) Old 07-30-2012, 04:40 AM Thread Starter
Crazy Car Guy
Pm's replied!
post #68 of 84 (permalink) Old 08-01-2012, 09:12 PM
Bender Unit's Avatar
Thumbs down
Case Closed for Me: Fixed it by ditching my 2 weeks old VF Stage2 ECU Reflash.
Good Lucky to others
BU
Last edited by Bender Unit; 08-24-2012 at 01:59 PM. Reason: FYI, BOE fixed my problem
Bender Unit is offline
post #69 of 84 (permalink) Old 08-01-2012, 09:34 PM Thread Starter
Crazy Car Guy
Originally Posted by Bender Unit View Post
Hello,
I got my ECU reflashed with a Vision Function Stage 2 on my 2008 Exige S220 and received my ECU back this past Monday.
In the same time, my car was installing new Denso spark plugs, Denso 255lph fuel pump, RC 550cc injectors, 3.0" pulley & belt, 2bular Header, 2bular Sport Cat.
It already has Cup Intake, RLS IC with 3 camber duct, 2bular exhaust on before that.
Car started up find in cool, but when it warm up after 15mins.
It will start stalling without moving.
I tried drove around the block, but it was stalling whenever I shift into neutral.
It ran great when it was in gear (in accelerating)
My car never stalled before the reflash. I drove my car back home tonight and it got less than 25km after the reflash so far.
No CEL
My mechanic done the following to solve, but without success:
- clean MAF
- clean TB
- Replace new MAF, tested ... same result
- triple check any vacuum & exhaust leak.
- finally did a smoke test this afternoon with no sign of leaking.
My mechanic contacted Jermaine from VF this morning and he stated it is rare be ECU reflash related problem
Any other suggestion will be appreciated
Thanks in advance
BU
For that same reason is why I check to make sure every ecu is working on a car before it is shipped. Try it with the factory air box.
post #70 of 84 (permalink) Old 08-01-2012, 09:45 PM
Lotus F1's Avatar
Hey Jermaine is there any way my tune can be adjusted for 850cc Injectors instead of the 660cc I currently have? I got new injectors I want to upgrade to.
Lotus F1 is offline
post #71 of 84 (permalink) Old 08-01-2012, 09:55 PM Thread Starter
Crazy Car Guy
This would require a complete retune.
post #72 of 84 (permalink) Old 08-01-2012, 10:04 PM
Lotus F1's Avatar
Ok gotcha thanks
Lotus F1 is offline
post #73 of 84 (permalink) Old 08-06-2012, 03:15 PM
dcreech0's Avatar
Hey jermaine,
Picked this flash up from you a while ago for the Exige s 2bular manifold/decat. Was thinking about picking up RLS 3 ich pulley. Wondering if it would work safely.
dcreech0 is offline
post #74 of 84 (permalink) Old 09-24-2012, 02:47 PM Thread Starter
Crazy Car Guy
Up for September...
post #75 of 84 (permalink) Old 01-07-2013, 07:14 AM Thread Starter
Crazy Car Guy
pm's replied.
Happy New Year!
post #76 of 84 (permalink) Old 01-07-2013, 08:22 AM
Green Hornet's Avatar
Upgrade ?
I have an '05 Elise with a VF Stage 2. It is running the VF intake along with a Tubular exhaust system built as follows;
Tubular header
Tubular 2 3/4" decat pipe
Tubular 3" muffler
What would be the benefit of the new tune?
Thanks -
Life, Liberty and the Happiness of Pursuit
I can help you move TO anywhere in the USA FROM anywhere in the USA - ask me how...
Green Hornet is offline
post #77 of 84 (permalink) Old 01-07-2013, 09:02 AM Thread Starter
Crazy Car Guy
Tubular header
Tubular 3" muffler
Thanks -
Nothing particular for that model. Unless you having a cel codes.
post #78 of 84 (permalink) Old 01-28-2013, 11:35 AM Thread Starter
Crazy Car Guy
Pm's replied!
post #79 of 84 (permalink) Old 03-02-2013, 08:43 AM
chiarov's Avatar
Hi folks -
Are most of you NA guys going with the I-ONE flash or the V2 NA Flash?
Is the difference just a matter of whether or not you have the stock intake?
2012 Porsche 991.1S white
2014 Audi Q5 3.0T scuba blue
chiarov is offline
post #80 of 84 (permalink) Old 03-04-2013, 05:49 AM Thread Starter
Crazy Car Guy
Originally Posted by chiarov View Post
Hi folks -
If you have any aftermarket intake i usually recommend using the V2.
Jermaine
  LotusTalk - The Lotus Cars Community > Marketplace > Aftermarket Suppliers
