One Off Car Build - Page 3 - LotusTalk - The Lotus Cars Community
 1Likes
post #41 of 97 (permalink) Old 04-22-2017, 06:45 PM
Bugzilla's Avatar
Originally Posted by cgmiller8390 View Post
Mazda Miata front and rear spindles and brakes. The Miata stock brakes will get swapped out for the big brake kit later.
Very cool. I went the same route for my Bug. Ended up going with the Wilwood brake kit from Flyin Miata. 6 piston up front and 4 in the rear. Havent had any issues so far. Not a bad price either. I am very curious to see the outcome of your a-arm design compared to mine. Lets just say my first set wasnt happy after it's first race.
Bugzilla is offline
post #42 of 97 (permalink) Old 04-24-2017, 04:39 PM Thread Starter
cgmiller8390's Avatar
Ok first upper control arm was way to short, I'm talking 3 inches. It was all my fault. When I took my computer plans and put it to the jig I flipped a number in my head. A 9 inch measurement became a 6 inch and the problem started. Really just look at this arm.
Why buy it when I can weld it.
Come join me at Patreon for up to date build info and more.
https://www.patreon.com/cgmiller8390
cgmiller8390 is offline
post #43 of 97 (permalink) Old 04-24-2017, 04:43 PM Thread Starter
Bolted up lower control arm to double check my measurements and design. The arm is adjusted all the way in and will be adjusted out some to get the correct ride height.
post #44 of 97 (permalink) Old 04-24-2017, 04:47 PM Thread Starter
Back to the upper arm and this time do it correctly to the plans. I tacked it up in the jig and then test fit it on the car. Again this arm is adjusted all the way in. Once I make the pushrod shock mounting system. The arms will be adjusted for ride height and camber. The wheel looks really off in the picture but its not.
post #45 of 97 (permalink) Old 04-24-2017, 04:51 PM Thread Starter
Removed the upper arm back off to finish weld it in the jig. One side done and now waiting for it cool before a can unbolt and flip.
post #46 of 97 (permalink) Old 04-24-2017, 05:15 PM
glb
glb's Avatar
For all the people who enjoy seeing this, I highly recommend:
Project Binky ? Bad Obsession Motorsport
again.
glb is online now
post #47 of 97 (permalink) Old 04-24-2017, 07:51 PM
this is amazing
wpeters is offline
post #48 of 97 (permalink) Old 04-25-2017, 05:19 AM
glagola1's Avatar
It looks like you're going to get a crazy amount of camber loss as the wheels goes through it's motion. I suggest checking out books about suspension design and theory.
glagola1 is online now
post #49 of 97 (permalink) Old 04-25-2017, 09:02 AM
Bugzilla's Avatar
I agree with you. That top arm needs to get mounted lower. I would plug in your dimensions to an online calculator to check camber gain/loss while going through the motion. I used the one through Racing Aspirations. Link HERE. It was a great help and free to use.
Bugzilla is offline
post #50 of 97 (permalink) Old 04-27-2017, 01:58 PM
It'll be POSITIVE camber, though - I thought "positive" was better?
mannix is offline
post #51 of 97 (permalink) Old 04-27-2017, 02:12 PM
LiveToDrive's Avatar
This puppy is going to weigh a hell of a lot more than 1400-1500 lbs as you're estimating. It looks like a good candidate for a sports off-road vehicle IMO, but definitely not a canyon carver.
LiveToDrive is offline
post #52 of 97 (permalink) Old 09-25-2017, 03:15 PM Thread Starter
I'm back. Below are updates of what I have done to the car.
post #53 of 97 (permalink) Old 09-25-2017, 03:17 PM Thread Starter
Here's the front control arms all bolted up. Working on getting the ride level just right.
post #54 of 97 (permalink) Old 09-25-2017, 03:18 PM Thread Starter
This was the first steering rack I was going to use. After getting the rack installed and all connected, uh. I used a rack off a car that original mounts to the backside of the tires. Well when you connected it to the first side. Turn the wheel left and you go right. Really good security system but no such thing as GP steering.
post #55 of 97 (permalink) Old 09-25-2017, 03:19 PM Thread Starter
Making the gas tank from scratch. The fuel pump is going to be an inline high psi - high flow.
post #56 of 97 (permalink) Old 09-25-2017, 03:20 PM Thread Starter
Good shot of the baffles and the lower left sump area.
post #57 of 97 (permalink) Old 09-25-2017, 03:21 PM Thread Starter
All welded up and ready for testing. Sealed the tank ports off and did a air pressure and water test. Had to fix a few pin holes.
post #58 of 97 (permalink) Old 09-25-2017, 03:21 PM Thread Starter
Sitting in the frame but not mounted up yet. Going to have to make some modifications to the tank for it go around some tubes.
post #59 of 97 (permalink) Old 09-25-2017, 03:22 PM Thread Starter
Front passenger shock linkage pivot point tacked in.
post #60 of 97 (permalink) Old 09-25-2017, 03:23 PM Thread Starter
First pushrod linkage design. I made a change to it farther down.
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Inspired Cars or Cars with Lotus DNA
