One Off Car Build - Page 5 - LotusTalk - The Lotus Cars Community
 1Likes
post #81 of 97 (permalink) Old 10-26-2017, 06:25 AM Thread Starter
cgmiller8390's Avatar
Turbo mocked up to check for clearance. Going to change the 90 degree connector on the intercooler to a 45 degree. Going to make the intercooler tubing myself. Need to modify the fuel tank for the air inlet on the turbo. Almost ready to take the motor out to send to the machine shop.
Why buy it when I can weld it.
Come join me at Patreon for up to date build info and more.
https://www.patreon.com/cgmiller8390
cgmiller8390 is offline
post #82 of 97 (permalink) Old 10-26-2017, 06:43 AM Thread Starter
Here's the modification to the fuel tank. I'll have to wait until the 45 degree silicone connector comes in the mail to seal it back up. I also cut the corners off at the firewall for mounting clearance. I may need to trim them some more. Going to work on the fuel tank mounts over the next couple days. Yes that's a 4" inlet with anti-surge.
post #83 of 97 (permalink) Old 10-26-2017, 06:45 AM Thread Starter
Cut and welded in the lower frame brace for the fuel tank. Did a last check to make sure nothing else need to be moved or modified. OH Crap! I didn't take into account the starter. So know I have to find the old starter to bolt up and check. Will post my finding later tonight.
post #84 of 97 (permalink) Old 10-26-2017, 06:46 AM Thread Starter
Do you see the problem, LOL.
post #85 of 97 (permalink) Old 10-26-2017, 06:47 AM Thread Starter
Welded all the corners back up that I cut off for clearance problems. Found the old starter and as you can see no problems. Going to finish welding the mounts onto the tank before I pressure it again. After that I have to seal the inside and paint the outside.
post #86 of 97 (permalink) Old 10-26-2017, 06:49 AM Thread Starter
Need to finish up the fuel tank mounts in the middle of the car.
post #87 of 97 (permalink) Old 10-26-2017, 06:53 AM Thread Starter
Taking opinions on paint scheme.
Main Tube Frame
Control Arms
Suspension Pushrods
Shock Linkage
Engine Block
Cylinder Head
Intake Manifold
Exhaust Manifold
Plus everything else.
post #88 of 97 (permalink) Old 10-26-2017, 06:57 AM Thread Starter
I will be starting the front sub-frame for the headlights and crash protection next week. Here's the headlights I'm going to use.
post #89 of 97 (permalink) Old 10-26-2017, 06:57 AM Thread Starter
Also going to make the brackets to hold the inline fuel pump and filter. After that I can make the custom fuel lines. Already have the fittings and breaded stainless steel hose.
post #90 of 97 (permalink) Old 10-26-2017, 06:58 AM Thread Starter
Working on finishing up connecting the steering column to the rack. If you don't remember the first rack I mocked up had a big problem. The wheels would go left when you steer right. Make a great security system.
Here's what the front firewall looks like from the first try.
post #91 of 97 (permalink) Old 10-26-2017, 06:59 AM Thread Starter
Walk around video with commentary.
post #92 of 97 (permalink) Old 10-26-2017, 10:57 AM
glagola1's Avatar
Whoa.
Do you know how much it weighs so far? How are you going to get it off the table? Are you concerned about the proximity of the fuel tank to the turbo and exhaust system?
glagola1 is offline
post #93 of 97 (permalink) Old 10-27-2017, 09:57 AM Thread Starter
Originally Posted by glagola1 View Post
Whoa.
The car will still be around 1400 to 1500 lbs without driver. The exhaust will be routed away from the fuel tank. For the turbo I plan on installing an insulation cover.
post #94 of 97 (permalink) Old 10-27-2017, 09:58 AM Thread Starter
A must have for anyone notching tube with offset notches.
post #95 of 97 (permalink) Old 10-27-2017, 10:00 AM Thread Starter
Another very useful tool to have around the shop.
post #96 of 97 (permalink) Old 10-29-2017, 04:32 PM Thread Starter
Steering wheel linked to steering rack finally. Now have to make the custom inner tie rods.
post #97 of 97 (permalink) Old 10-29-2017, 04:57 PM Thread Starter
Got to thinking if the custom inner tie rods off the steering rack that turned the wrong direction would work. May need to cut some treads off the end but it works. Now just have to paint it and put the boot on.
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Inspired Cars or Cars with Lotus DNA
